toshiba 50L1350U no backlight
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    did some troubleshooting. i have picture and sound but no back light
    the power supply is obviously bad bc i dont have all my voltages
    this is a LED LCD tv and i found 68V going to the LED's
    Is it safe to say there's definitely a blown LED?
    has anyone messed with this model and replacing or jumping bad LEDs?
    dont want to spend money or time repairing power supply if tv is shot.
    Can provide pics of the board and voltages if necessary
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: toshiba 50L1350U no backlight
    I would probably put money on a shorted led or bad driver, have you checked the blon voltage ?
    • sdinelli
      Sdinelli
      • Aug 2014
      • 152
      yes sir, here are my voltages
      PWM - 3.25V on start then to 232mV ( with LED unplugged. plugged in screen flashes once)
      5.1V - no wire
      bl_on/off - 3.236V
      power_tv - 3.31V
      AC - Detect - 3.48V
      5.1V - 5.13V
      GND
      12V_LNB - no wire
      GND
      12v_AUD - 12.47V
      GND
      12Vcc - 12.46
      So it actually seems all my voltages are correct
      Also, i was wrong its 76V going to the LED connections
      • newtothis
        • Mar 2013
        • 1556
        • england
        Watch the voltage going to the LEDS when you turn the set on... Does it go high then settle back at 76v?
        • sdinelli
          Sdinelli
          • Aug 2014
          • 152
          actually i get 77V as soon as i plug the plug into the outlet, then it slowly lowers to zero, then kicks back upto 77V when i press power putton and the BL comes on.
          Then slowly declines when i press power off again.
          I found a bad diode measuring .200 and a rising voltage with reverse leads
          and 4 that look a little low at .389. < is this too low?
          Also, found a few questionable resistors.
          I havent gotten a chance to test anything out of circuit tho.
            Is this your board?
            http://www.shopjimmy.com/toshiba-750...upply-unit.htm
            If it is the board, check the DCV between L1+ (ANODE of string 1) & Chassis, L2+ (ANODE of string 2) & chassis.
            There are two strings of LEDs and two LED drivers circuits.
            I will not be surprised if it has bad LEDs.
            Please up load the pictures of the whole back side of the TV so we can see all the board.
            • sdinelli
              Sdinelli
              • Aug 2014
              • 152
              Originally posted by budm
              Is this your board?
              yep thats it,
              i may try to repair first and see if i can get that backlight voltage back to normal. is there a way to see if theres a shortage in the LED's?
              i dont want to put the time and money into fixing if LEd's are bad.
                I updated the thread.
                You did not see if the backlights even flash on for seconds?
                • sdinelli
                  Sdinelli
                  • Aug 2014
                  • 152
                  thank you sir,
                  and yes BL flash's on start up for a split second.
                  unfortunately im headed out of the house, i wont be able to play with this any more today .
                  thanks for all your help. will update and add pics when i can.
                    I just notice this 'PWM - 3.25V on start then to 232mV"
                    Try removing just that PWM wire and see if the backlights will stay on.
                    • dcaron614
                      • Apr 2014
                      • 30
                      • US
                      I just had an issue with this same TV/model .. mine would flash the back lights for a hot second then nothing, you could see the image with a flash light. I tested the PSB and L1+ and L2+ were only giving 77.5v. I brought a used PSB of ebay for $31 and replaced the board and TV powered right up... back lights work fine now. I retested the L1+ and L2+ and now they are pushing out 117v
                      • sdinelli
                        Sdinelli
                        • Aug 2014
                        • 152
                        so after testing a bunch of stuff. i found 2 bad resistors
                        i have trouble figuring out the value. i think its 5.38M ohms?
                        does that look right to you?
                        They measured .6 ohms
                        Can anyone recommend a better or equivalent replacement?
                        why do you think they went bad?
                        two bad resistors are on the lower left by diodes and caps
                          Red, Yellow, Silver? That will be 0.24 Ohms resistor. They are resistors for the Source pin of the Power MOSFETs of the LED driver circuit.
                          So did you remove the PWM signal wire from the connector as I suggested?
                          • sdinelli
                            Sdinelli
                            • Aug 2014
                            • 152
                            Red, Yellow, Silver? That will be 2.4 Ohms resistor. They are resistors for the Source pin of the Power MOSFETs of the LED driver circuit.
                            what about the rest of the colors? gold and green
                            and i didnt know silver can be the 3rd band. maybe its grey?
                            im using the resistor calculator on digikey.
                            do you think those 2 mosfets are bad?
                            http://www.digikey.com/en/resources/...or-code-5-band
                            i didnt remove the pmw connector
                            i did test L1+ and L2+
                            both 77V
                            • sdinelli
                              Sdinelli
                              • Aug 2014
                              • 152
                              i dont understand why LEd's need so much voltage.
                                both 77V
                                My typo, it is 0.24 Ohms which is typical value for the Source resistor. The PWM Voltage should not drop down like that, the female pin on the the connector for the PWM line can be removed for the connector body.
                                • sdinelli
                                  Sdinelli
                                  • Aug 2014
                                  • 152
                                  also, if i remove the pmw connector, what should i look for?
                                    LEDs are connected in series, each LED requires about 3~3.5, so for 50" TV there will be many LEDs connected in series just like Christmas lights.
                                      To see if the backlights will stay on.
                                      • sdinelli
                                        Sdinelli
                                        • Aug 2014
                                        • 152
                                        ok ill put these two resistors back in and pull that wire, and report back.
                                        thanks.
                                        so without the pwm, the screen will just be at the max brightness or what?
                                        just curious
                                        • buchman
                                          Toshiba 40L2400VQ No backlight but LEDs are fine
                                          by buchman
                                          I have a Toshiba LED tv model number 40L2400VQ.
                                          I don't receive the correct voltage at the output to the LEDs.
                                          I disassembled the front panel and checked all leds and they are fine. Then I checked the voltage to the leds on the power board and it flactuate in milivolts.
                                          Tested all caps with esr meter and they are fine.
                                          The diodes are fine and the resistors too.
                                          Where should I concentrate on?
                                          Thanks in advance....
                                          03-13-2021, 12:43 PM
                                        • hollox123
                                          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                                          by hollox123
                                          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                                          1. Laptop keyboard doesn't work
                                          2. The backlight on the laptop keyboard doesn't work
                                          3. The x2 side LEDs (red) on the laptop don't work
                                          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                                          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                                          But I am strongly aiming that it is somehow a BIOS-related problem,...
                                          05-11-2025, 08:05 AM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • signal.quest
                                          Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                                          by signal.quest
                                          I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                                          03-17-2024, 10:14 AM
                                        • Boyxba
                                          TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                                          by Boyxba
                                          I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                                          05-13-2023, 11:47 AM
