toshiba 50L1350U no backlight
  • PC_gamer_5150
    • May 2016
    Re: toshiba 50L1350U no backlight
    Can anyone help me out?
    Since i have the same exact TV and same symptoms i did not want to start a whole new thread.
    I was gaming today on the L1350U and after about 1 hour screen went black?
    still have audio and i did the flashlight test and can see a faint image of what is on the Screen.
    There is one thing that was NOT mentioned with the other L1350U TV's in this thread,
    Before this happened today, i had noticed when the screen was on my PC's desktop for windows 7 there was a subtle flickering in the upper right hand corner of the TV's screen?(approx a area of 3"x3" that flickered)
    I had noticed this a few days back and did not give it much thought until it went black today!
    Does this diagnose bad L.E.D's? or something else?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      #82
      Possibly bad connections in the Led strips here. Take the panel apart and get us some images of the Led.
      • PC_gamer_5150
        • May 2016
        Is the back panel pretty easy to take off? I have seen some that are a real pain to get off?
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          #84
          where are the LED's located?
          Please watch my video:
          https://www.badcaps.net/forum/showth...Stacking+video
          • PC_gamer_5150
            • May 2016
            Great thanks
            • osheam
              • Jan 2017
              • 9
              I know this is an old thread but did anyone fix this issue?
              • pni
                Backlight panel diffuser melt by backlight leds broken
                by pni
                Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                10-12-2025, 12:08 AM
              • buchman
                Toshiba 40L2400VQ No backlight but LEDs are fine
                by buchman
                I have a Toshiba LED tv model number 40L2400VQ.
                I don't receive the correct voltage at the output to the LEDs.
                I disassembled the front panel and checked all leds and they are fine. Then I checked the voltage to the leds on the power board and it flactuate in milivolts.
                Tested all caps with esr meter and they are fine.
                The diodes are fine and the resistors too.
                Where should I concentrate on?
                Thanks in advance....
                03-13-2021, 12:43 PM
              • hollox123
                ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
                by hollox123
                Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
                1. Laptop keyboard doesn't work
                2. The backlight on the laptop keyboard doesn't work
                3. The x2 side LEDs (red) on the laptop don't work
                The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
                I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
                But I am strongly aiming that it is somehow a BIOS-related problem,...
                05-11-2025, 08:05 AM
              • maneatingmonkey
                Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                by maneatingmonkey
                I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                03-27-2024, 07:17 AM
              • signal.quest
                Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
                by signal.quest
                I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
                03-17-2024, 10:14 AM
