LG 32 lcd not always turning ON
+ More Options
Posts
  • nathaniel
    • 35
    • israel
    Re: LG 32 lcd not always turning ON
    i added a picture of what i did:
    1k resistor ( rated 1/4w hope its ok) from the 5.2v to pin - inverter on/off
    1k resistor from the same 5.2v to pin - power_on
    with the a/c plugged in and the main board disconnected
    the power_on cam up to2.9v but still no other voltage beside the 5v
    am i doing it right?
    the board model: EAY4050440
    thank you guys
    • nathaniel
      • 35
      • israel
      so... does it mean the pson voltage is correct ?
      and the power board is at fault
      should i replace the capacitors or there is furhter checking to do?
      • newtothis
        • Mar 2013
        • 1556
        • england
        With jumpers in place check one of the main caps voltage with meter set to 600VAC, Careful HOT side of board. Take note of polarity
        • nathaniel
          • 35
          • israel
          just to make sure ... i'm testing the two large capacitors marked c608 and c609
          and i still get 330v dc
          • newtothis
            • Mar 2013
            • 1556
            • england
            Do you want to repair the boards or replace them?
            Your PSU is faulty BTW
            • nathaniel
              • 35
              • israel
              #26
              i would like to repair it if possible
              ordering a board will take 4-8 weeks with our %@@#$ post service
              do you think this is a capacitor symptom or somthing more compicated?
              • CapLeaker
                Leaking Member
                • 8325
                I am hoping that this is the schematic for your board
                Does your board have the relay option?
                • nathaniel
                  • 35
                  • israel
                  #28
                  no i don't have the relay option ...just the two jumpers instead
                  • CapLeaker
                    Leaking Member
                    • 8325
                    What kind of tools do you have? Do you have an ESR meter?
                    Try this: Heat up or cool the board and see if it turns on. If you need heat to turn on the PSU there is a bad cap somewhere.
                    Check the PSon circuit and the PFC circuit. Problems in either could do that. Make sure that the PSU is working correctly before you put that main board back on.
                    • victor_cj
                      • May 2015
                      • 90
                      • Romania
                      #30
                      Check or replace NCP1396AG and SG6961SZ and will work again.
                      The art of fighting without fighting
                      • nathaniel
                        • 35
                        • israel
                        #31
                        update:
                        and an hour of heating and cooling the ps
                        i maneged to get it start twice ( while cooling)
                        i tried to freeze on area at a time with no success , only when i freeze the all board it will start. :/
                        victor- i don't believe ican test this components with a multimeter , can i?
                        if this is the case i think i would be better ordering a replacment board i'm not 100% i can properly solder such a part
                        • victor_cj
                          • May 2015
                          • 90
                          • Romania
                          #32
                          You can test it, depends on the your level of experience. At NCP1396AG check voltage pin12 Vcc, pin11 Mlower, pin9 Slow Fault. At SG6961SZ check voltage pin8 Vcc, pin7 Gd, pin1 Inv, pin5 Zcd.
                          • nathaniel
                            • 35
                            • israel
                            #33
                            thank again victor
                            i tried testing these i started testing this time the tv was on
                            NCP1396AG (test dc between a pin and the chip GND - don't know if it's correct)
                            pin 9- 65 mV
                            pin 11 - 7.2V
                            pin 12- 14.9V
                            SG6961SZ
                            pin 5 -2.8V (and pin 6 as GND) also when i touched with only one probe at pin 5 got a little buzzing from the board.
                            when tring to test pin 7 i accidently touched both 7+8 the main fuse got blown...
                            replaced it with another one and... blow again
                            probably shorted somthing else :/ hopefully on the same board so i'll only need to replace this one.
                            having fun learning electronic repairs
                            i'll update when i'll get a new board so i won't waist your time.
                            • victor_cj
                              • May 2015
                              • 90
                              • Romania
                              #34
                              Check Q601, Q602.
                              Another SMPS board it is best for you.
                              • nathaniel
                                • 35
                                • israel
                                #35
                                update:
                                got a replacment PS board from a local technician (didn't found the parts victor mentioned available here- so that was my only option)
                                just wanted to thank you all for your time - the TV WORKS AGAIN!!
                                THUMBS UP
                                • victor_cj
                                  • May 2015
                                  • 90
                                  • Romania
                                  #36
                                  Same EAY4050440 from 32LG2000 with PFC low, caused by R609, R610, R611, R612 620K ohms resistor.
                                  https://www.youtube.com/watch?v=uwWdRsMAcJU
                                  • fredaelsadany
                                    • Jan 2016
                                    • 66
                                    • EGYPT
                                    #37
                                    Hallo every one
                                    please measure r613(15k)/r614(820ohm)
                                    thanks
                                    • Alastair E
                                      Chief Womble
                                      • Mar 2013
                                      • 1963
                                      • U.K.
                                      #38
                                      There's a number of capacitors on the Mainboard along with some tiny inductors that can cause an Intermittent Dead LG...
                                      There's kits available showing whats needed, try googling the set model-number....
                                      An Observation--
                                      I notice in one of your pictures--Only Two Screws mounting the PSU.
                                      Make Sure you fit ALL screws to ALL boards Particularly on any Plasma set--Before trying to make the set work....
                                      Plasmas particularly can self-destruct if they have a missing earth screw....
                                      TELEFIX
