Re: LG 32 lcd not always turning ON
The set wouldn't start at 1.5v though and I would be surprised if he had 12v and 24v if the PFC cap did indeed only have 330v
Can you take a picture of what setting you are testing on the meter pleaseLeave a comment:
whats the power board model number? maybe theres a schematic aboutLeave a comment:
I am still not convinced that 1.5v on PSon is correct.
I'd disconnect the main board from the PSU and "force" the PSU on. Check if all the rails come up on the PSU.
Usually it is done by using a 1k ohm resistor from STBY to PSon and another one from STBY to BLon (backlight). As soon as you plug it in, the backlight should be on and all the voltage rails should be on as well.
Also the 330V on the filter cap is low. Should be more than 360V. Not sure if you meter is good or not...Last edited by CapLeaker; 05-30-2015, 01:14 PM.Leave a comment:
update:
the set turned on today and i get this readings:
power_on is 1.5v as when not turning on
but then i get all the other 12v , 16.5v and 24v
at the big caps i get 329v when on and 310v when off
is the problem in the power board ?
* i do not have a capacitance test on my multimeter
If so please change your meter battery, I think its bad.
PS_ON should be higher than 1.5v and the PFC cap should be >360 when 12v etc are presentLeave a comment:
update:
* i do not have a capacitance test on my multimeterLeave a comment:
If you have replaced the caps on the secondary side of the P/S, I'd check the values of the capacitors around the regulators on the mainboard. Also the two diodes around the switcher, D1100 and D1102.
I've seen the mainboard sit and play dumb when the standby circuits could not startup the main processor because of odd waves coming out of the mainboard switchers. Leaky blocking diodes caused the voltage wave to rise but then fall back again, unsuccessful starting the switch mode off. Cooling the parts with freeze spray identified the faulty circuit area (lowered the threshold to maintain pulsing), but not the exact parts.Leave a comment:
Voltage at main filter cap (The big cap rated 450v) .. Red to + and Black to - : Meter at 600VDC. Careful as working on HOT side of the board.
What reading do you get when attempting to power the set on?Leave a comment:
i'm get this resaults:
1.5v - power_on
5.2v- to logic board
no 16.5v to " "
no 12v " " "
no 24v " inverter board
i hope i get lucky tomorrow so i can test and compare
when it does go on.
victor sorry i don't know what PFC status mean or how to test it.
*excuse me for my poor knowlege in electronics , but i'm learning quickly
thank you all for your patienceLeave a comment:
Yes PS_ON should be >2.5v to start the set.
Can you confirm how you are testing and also your meter battery pleaseLeave a comment:
So what is the PSon voltage if there is a picture? To me, the PSon voltage is low. But any how, when the TV is turned on, check all the power rails. See if one or all voltage rails are there or missing.Leave a comment:
Check 12V, 16,5V, 25,2V when PSon is 1,5V. Check at C609 PFC status.Leave a comment:
verify PSon voltage in both conditions. If you don't get PSon signal from the mainboard, then there is trouble there.Leave a comment:
hello everyone
my lcd started to make trouble turning ON .
it goes on once a while mainly when i plug out the ac and let it sit for acouple of hours.
when it's not turning ON the led acts normally (blinks a few time red then solid blue) just display or sound wont .
it a 32LG32R
can you please help me out here
thank you for your time !Tags: None
by SparklingxHP 450 g1 keeps turning on even tho I shutdown/sleep . one way to stop the turning on cycle is pressing the power button few seconds thus force powering it off. But then sometimes it does not turn on at all but next day I try again to turn it on and it turns on....
by khelaneHello
A device with specifications
Toshiba Satellite PRO A50-A is here to replace the hard drive.
The hard drive has been replaced and there is no problem, but there is another problem, but the customer does not care to fix the problem.
The device enters Windows without any problem and works, even I put pressure on the CPU and graphics, but when I turn off the system through Windows, if I want to turn it on again, the system switches, but it turns off quickly within a second, and this routine continues. It is turning on and off within a second and soon it turns off.... -
by RabitRecently staring turning off more often, brightens set at 50% - monitor back side in PSU area is very warm to touch, also at front left corner getting hot.
When changed brightens set at 30% no longer turning off , and no longer I can feel any heat in this areas.
This can be signs of bad capacitors causing overheating PSU ?-
by shakib200Laptop turns on only on battery but if I plugged the adapter with battery, it is not turning on. After turning on the laptop using only battery (no adapter plug in), then plugging the adapter everything works fine also charging ok. Anyone have any clue what’s wrong?...
by Francesc V.Hi:
I am trying to repair this modular ATX PSU. It only has the 5V Standby and PSON enabled (3.33V).
PSON is delivered by (ST9S429-PG14) in pin4. This chip is a Voltage controller but it doesn't seem to trigger any PWM signal to pass it to primary through coils and "move" the big mosfets. Also next to it there is a EST7618 that it also seems a voltage controller.
Not sure if in the right direction, but trying to find where PWM signal is generated.
Green section seems that could be the "PWM section". It's driven by a... - Loading...
