Vizio va22lfhdtv10t no backlight.
  • erickeri1234
    • May 2013
    • 98
    • usa
    Picked up this vizio TV. It powers on flashes the screen but backlight isn't staying on. Checked with a flash light and was able to see the no signal image... Found one bad cap on the main board. Still no backlight. Changed the 2x 16v 470uf by the inverters but still nothing. I'm getting the correct voltage to the main board.. (12v and 5v) power and inverters are on the same board.
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: Vizio va22lfhdtv10t no backlight.
    What is happening to the BL_ON signal when the backlights cut off?
      Any good clear pictures of the boards and how they are all connected together?
      • erickeri1234
        • May 2013
        • 98
        • usa
        I will check the bl_on.
        • erickeri1234
          • May 2013
          • 98
          • usa
          The inverters are on with the power board. Will get pictures up soon
          • erickeri1234
            • May 2013
            • 98
            • usa
            OK sorry for the late reply. I'm getting 4.9v on the bl_on signal wire.
            • newtothis
              • Mar 2013
              • 1556
              • england
              Ok we need pictures now as budm asked
              Can you list the voltages from the PSU - Main cable like this :
              Pin 1 - PS_ON - 5v
              Pin 2 - 5v STBY - 5v
              Pin 3 - BL_ON - 4.9v
              etc etc
              Obviously the order of pin names will be marked on the board
              • erickeri1234
                • May 2013
                • 98
                • usa
                Ok finally was able to get some pictures.
                PIN 1 - PID - 5.0v
                PIN 2 - Bl_on - 4.9v
                PIN 3 - Bright - 4.6v
                PIN 4 - 5v - 5.1v
                PIN 5 - 5v - 5.1v
                PIN 6 - Ground - Ground
                PIN 7 - Ground - Ground
                PIN 8 - Ground - Ground
                PIN 9 - 12v - 13.3v
                PIN 10 - 12v - 13.3v
                PIN 11 EMPTY
                PIN 12 - STandby - 0.0v
                • jetadm123
                  • 2169
                  Can you please post a good focused straight down photo of the bottom of the power supply board? There are some switching mosfets that should be checked.
                  • newtothis
                    • Mar 2013
                    • 1556
                    • england
                    Standby pin has no voltage yet the set is switched on?
                    • erickeri1234
                      • May 2013
                      • 98
                      • usa
                      Updated with more pictures
                      • erickeri1234
                        • May 2013
                        • 98
                        • usa
                        I just doubled checked the Standby volts and Still get 0.0v
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          Ok this makes no sense, Without the standby voltage the set would be completely dead.
                          Confirm you are testing using VDC and using the chassis as ground?
                          • erickeri1234
                            • May 2013
                            • 98
                            • usa
                            Agree, I'm useing a fluke 115 on DC. I have to put ground on a heatsink. Power comes on front light is amber then lights up white when I hit the power button. I'm going to probe at it a little more in 10 minutes.
                            • jetadm123
                              • 2169
                              When I said photos of the bottom of the board, I meant turning the board over. We need to see what's underneath. Your photos need to be in better focus.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                Also use the chassis for grounding (Screw etc)
                                  "PIN 12 - STandby - 0.0v" STBY on this board is the same as PS-ON pin, it is not being used on this board because this is an always on power supply.
                                  There are two 8-PIN SMD power MOSFETs on the bottom side of the board that need testing as mention by the other.
                                  Pictures are provided by SHOPJIMMY.
                                  • erickeri1234
                                    • May 2013
                                    • 98
                                    • usa
                                    Sorry jetadm you did say bottom. I read it to fast.
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      Cheers for clearing that up
                                      • erickeri1234
                                        • May 2013
                                        • 98
                                        • usa
                                        OK I tested the two SMD power MOSFETS.
                                        There are three of them The two I tested are close under the inverters. On both of them pins 1 throu 4 have 0.0 v , pins 5 throu 8 have 13.3v .
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                          Design of CCFL Backlight Inverters with Frame & Bar Cores
                                          Summary
                                          Portable devices, such as notebook computers and personal digital assistants are developed rapidly nowadays, which places an increasing demand on display technology. The LCD with cold cathode fluorescent back lighting satisfies the requirements on display performance, size and efficiency.
                                          The backlight inverter plays a crucial role in supplying the power to the lamps of these flat-panel displays.
                                          The frame and bar ferrite cores, described in this brochure, are especially designed...
                                          10-07-2024, 04:26 AM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
