Re: Transistor for TV problems
No pic and probably no backlight but will have the 5v STBY as set "attempts" to power.... So will be missing the 12v and 24v.
Can you give me a close up pic of the connector that goes from the PSU to main (Top left of your image) so I can see the labels for voltages please.
Need to confirm voltages at this connector to confirm the missing voltages and see what's going on.
Does it remain white? If you get a flashlight and try to put some light on the TV can you make out an image?
there maybe other posts on Vizio E470VL. tried a search on model yet?Leave a comment:
Chances are that FET is ok
And like newtothis said, click on advanced, manage attachments and upload direct, max size of image is 2000 x 2000 so you may need to resize the photosLast edited by tw2005; 05-14-2015, 07:12 PM.Leave a comment:
How is it tested out? Shorted? What circuit section is it in?Leave a comment:
TOSHIBA Field Effect Transistor Silicon N Channel MOS Type (DTMOS II)
TK15J60U is the full number
600V 15A
http://alltransistors.com/mosfet/crs...=0.3&caps=SC65
https://www.digikey.com/product-sear...words=tk15j60u
UTSOURCE is in china, will take weeks
http://www.utsource.net/TK15J60U.htm...FREDvAodGXsAjQ
http://www.ebay.com/dsc/i.html?_from..._odkw=TK15J60ULeave a comment:
Image is broken, Please upload using the attachment function under "Go Advanced"Leave a comment:
I'm a noob when it comes to these types of things, I have a transistor that i tested, it seems to be a bad one. I'm trying to order a new one from Amazon but i don't know which one I should get, can someone please post a link from Amazon on which type of transistor I should get,here's a pic of the bad transistor.
http://imgur.com/17ya9AeLast edited by Cue; 05-14-2015, 05:18 PM.Tags: None
on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
i don't understand the reasons of the white stripe at the bottom of the screen below the task... -
by HondamanRecently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
(I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...-
by magnehHello
Got this speaker from a friend , defective. Power led comes on and off , in a loop.
Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
Still, I need to replace this transistor.... -
by clabrNeed help to solve some problems with this laptop.
After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
Before this had happened I observed some other problems:
When I tried replacing original mecanical HDD with a SSD HDD could not get them... -
by elsomerhi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...1 Photo
- Loading...
