Panasonic TX-P42S30B - 6 blinks
  • MikeFloutier
    • May 2015
    • 42
    Re: Panasonic TX-P42S30B - 6 blinks
    Thanks Tom, my word it does take some doing but I have finally got a full clean picture.
    Very many thanks to you all for your help and support and hardware.
    There is no way I'd have even taken the back off (a first for me) without you guys.
    • MikeFloutier
      • May 2015
      • 42
      Special thanks to TW2005 for your faithful support and for encouraging me in what, with hindsight, was the best course.
      Flocko, thanks for your excellent soldering.
      Thanks also to Alastair E and others for chipping in.
        Nice! Enjoy your TV They are excellent TVs, so we should try and preserve them for as long as possible now you can only buy LED-backlit crap
        P.S. Since you know the main board was not at fault, consider selling that on eBay or to a member on here who may need it to fix another set.
        • flocko
          • Nov 2012
          • 1121
          • uk
          #84
          Sorry I missed your post this morning (shopping day ) but good to see Tom helped you though it. I thought you had it sorted yesterday anyway all good now, as Tom says put your main on eBay got to be worth a shot, send your faulty SN back to me for your refund and I hope you enjoy your viewing once again Flocko
          • MikeFloutier
            • May 2015
            • 42
            Many thanks Flocko, it's by the front reading for the post office
            • flocko
              • Nov 2012
              • 1121
              • uk
              #86
              Mikes faulty SN board arrived yesterday, so I tested the board and found Q401/2/21/441 and 422 shorted, D401and 421 test shorted, after lifting legs on Q401/2/21/441and 422, diodes D401/421now tested fine, when I tested Q531and IC502 I found them to be reading low ohms not the high Meg ohms they should read. After replacing all the above with the exception of the two diodes the board is up and running, and will be available to some lucky punter on eBay, A tip that may be of help ,when fitting this type of board trying to get the ribbons to line up can be a pain, I have found that if you leave the fixing screws loose with that extra movement on the board they do go in and line up better, but don't forget to tighten the screws before you power up the set. Flocko
              • tw2005
                • Oct 2011
                • 6458
                So bad Q531, IC502 is more the norm on these?
                  That's what I had on mine. If you get them wrong either the SN blows up or you get a brief panel glow then 6 blinks.
                  • flocko
                    • Nov 2012
                    • 1121
                    • uk
                    #89
                    Hi TW I would not say these need to be replaced every time (Q531/IC502)as I have had one or two boards that they have been fine, I also find some have blow the diodes some don't, the same with the resistors for Q401/02/21and Q422.But I would point out to anyone wanting to try a repair, to just be aware that they may need to replace them . and I have seen damaged boards that could not be repaired no matter what you tried Flocko
                    • tw2005
                      • Oct 2011
                      • 6458
                      Interesting the variations. The 5081 boards seem more consistent
                      Only done 2 of this series 50" S & ST30 and been blessed with just IGBTs needing replacement.
                      does prove the point that seeing all these kits assuming they will automatically fix it is a risk without any technical fault finding.
                      most kits seem to just have the 30f131, 2 diodes + resistors.
                      • flocko
                        • Nov 2012
                        • 1121
                        • uk
                        #91
                        TW that also a good point if you think a kit will fix it all, its not always the case ,I keep a stock of parts for these and other repairs, that as you know I get from overseas to keep costs down, so if its one of these and four of those it does not matter to me , I see some kits are running at over £30 on eBay that would not have all the parts that you may need, but these kits could when fitted clear the common short that is seen on Sn2 for it to fail as soon as you power up the set and as Tom says blowing the SN and back to six blinks Flocko
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          #92
                          Originally posted by sordids999
                          Im trying to fix the same problem 6 blinks
                          on mine Q401,Q402,Q421 are shorted but
                          but...... ? lol
                          • sordids999
                            • May 2013
                            • 2161
                            • uk
                            #93
                            ok lol my fingers pressed the wrong button so here we go again
                            on mine i have Q401,Q402,Q421,D461,D401,D642,D641 all shorted so my question is replace these will hopefully fix the problem or more testing to be done ?
                            thanks
                            • sordids999
                              • May 2013
                              • 2161
                              • uk
                              #94
                              sorry after testing again via this video https://www.youtube.com/watch?v=uIyHr13b5w8
                              i now have only Q401,Q402,Q421,Q422 shorted but do i have to also replace R401,402,421,422 ?
                              thanks
                              • flocko
                                • Nov 2012
                                • 1121
                                • uk
                                #95
                                The resistors can be checked with your meter if they read ok then no need to change them, I hope you have checked all the diodes (RF1501+RFN10) and the DG302s these don't all ways show as being short they can just be leaky, in most of the boards I have repaired this has been the case, and don't forget IC502 +Q531 these can also be tested you are looking for high Meg ohms for them to be good any low ohm will be bad, take your time replacing all the SMD parts as pads and tracks lift real easy Flocko
                                Just looked at that video WTF!!if you want to cock it up that's the way to do it should read how to toast your board in one easy lesson ?
                                • robertpearce4
                                  • May 2017
                                  Hi Guys. I'm chasing a fault I think I have on the SN Scan recovery H side (6 Flashes). I have replaced Q441, Q421, Q422, Q401 which were short.
                                  I want to replace IC 501 by substitution but what is generic part number? Panasonic part number is COZBZ0001812. The tiny 8 pin SMD has D86 93 NZ printed (possibly 2 characters missing).
                                  Is it possible to scope any of the waveforms or part run the SN board (no SC IGBT's or diodes) with some current limiting?
                                  • Mr Williams
                                    • Oct 2022
                                    • 6
                                    • Wales UK
                                    #97
                                    Good Evening forum,
                                    First post here as a DIY fixer and someone who hates throwing things out. Im a generally a mechanical person with some electrical understanding but always keen to learn.
                                    I have a problem with our Panasonic TX-P42S30B - 6 blinks (green) and I found this forum and corresponding thread.
                                    The TV has been excellent in 11 years of ownership and has a first class picture however it now fails to switch on with the characteristics described at the start of this thread (clicking relay followed by 6 green led blinks). I think the TV may have been switched off on the wall and not on the unit which may or may not have attributed to the cause. This was a change to routine due to percieved power costs when left on standby or not completely isolated.....
                                    I have removed the cover, cleaned the little dust there was inside and looked for obvious signs of stress but found nothing. I tried checking the torque of the earth screws and all generally firm and only having to tighten a few. I have now and focused on the transistors detailed earlier in this thread. I have checked these against the list of results provided by Mike Floutier and the values are very similar so Im guessing its the same failure mode.
                                    Many years ago I would have tackled this myself but now struggling with eyesight and manual dexterity so I was looking for a reccomendation for someone I could send the SN board to for checking to confirm problem and hopefully replacing the defect components.
                                    I'm located South Wales UK so someone local would be great.
                                    Appreciate any advice.
                                    NeilW
                                    • nomoresonys
                                      • 12276
                                      • U.S.
                                      #98
                                      So there's nobody in Wales that can help Mr. Williams out???
                                      • nomoresonys
                                        • 12276
                                        • U.S.
                                        #99
                                        came up with this, check out Williams Television Caerphilly, wonder if that could be your distant cousin or sum such, might be able to get a family discount, lol, maybe just take your boards in and see if they can test or fix them for a reasonable rate: https://www.google.com/search?client...ales+tv+repair
                                        • nomoresonys
                                          • 12276
                                          • U.S.
                                          #100
                                          Some testing you can do, be very careful if you do, heed the WARNINGS, there are some voltages in places that can EASILY KILL, warning is for those that may not be aware, safety first: https://www.youtube.com/watch?v=GFE14ElXz7g
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            11-20-2024, 08:52 PM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • jm1234
                                            Panasonic plasma TX-P42ST50 - 6 blinks
                                            by jm1234
                                            anyone able to provide the service manual for old plasma Panasonic TX-P42ST50E?
                                            It turns off almost immediately (0~5 seconds after pressing the on/off button) and starts flashing the red diode 6 times.
                                            I disconnected the left-hand side board (SC?, both the ribbon cable and the power cable to it) and also another ribbon going to bottom left board. Then the led signal is 8 flashes. According to service guide to another Panasonic plasma it would mean the left-hand side board is faulty. But I'm not sure it 100% applies to my model.
                                            I checked that board for any obvious faults...
                                            05-22-2024, 06:59 AM
                                          • Alicat
                                            Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                            by Alicat
                                            Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                            Model number is TH-50PZ85U
                                            Power comes on and the red power light stays on solid.
                                            Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                            I also hear a few clicks.
                                            I also think my parents said there was a thunderstorm and the TV failed after that.
                                            Section 6 in the service manual talks about power and no screen,...
                                            10-30-2024, 10:09 AM
                                          • CrewmanRedShirt
                                            Looking for assistance troubleshooting a Panasonic TC-P65ZT60 with 3 LED Fast Blinks
                                            by CrewmanRedShirt
                                            Hello all,
                                            As the title states, I followed the troubleshooting guide located here: https://www.manualslib.com/manual/23...page=53#manual, which concluded the 'A' board needs to be replaced. Looking around the net and eBay, I see that there are repair services for the board (TNPH1043UE? Not sure if it is a 'UE' as the suffix grid does not appear marked). What additional troubleshooting can be performed to ensure 1) this board is the problem and 2) since there are repair services, what are they fixing on the board?) I expected 3.3V not to be available anywhere...
                                            07-13-2024, 11:02 AM
