Vizio E550i-a0 no turning on
  • gfbjr52
    • Mar 2016
    • 7
    Re: Vizio E550i-a0 no turning on
    I will try to get a picture posted. The boards are barely visible, and I've never posted an image to a forum before
    • jetadm123
      • 2169
      #42
      Board in question is probably the T-Con board. To post a photo: when you reply to a post, select "manage attachments" under the "Additional Options" section.
      • gfbjr52
        • Mar 2016
        • 7
        I haven't tried removing these yet. I want to make sure I can get them replaced before I venture into that
        • johns1mj
          • May 2015
          • 242
          I have the same tv. My tv powers on my backlight but no picture.
          1,2 is 5.13
          3,4,5 gnd
          6,7 11.8
          8,9 3.2
          11-14 2.7
          Voltages indicate everythings fine with the power board if I am reading correctly.
            Do you have 12Vdc at both ends of the SMD fuse on the T-CON board with ref. to the chassis GND?
            • CapLeaker
              Leaking Member
              • 8036
              water damage... that sux... problem is you just can't switch out that board, because it is tab bonded to the panel.
              • vinceroger69
                • Mar 2012
                • 6714
                #47
                Good on spotting that i missed it the first time i glanced at the pictures but as you say fluid damage usually un fixable requires a new lcd.
                • CapLeaker
                  Leaking Member
                  • 8036
                  I sat on my computer, not on my tablet, so I was actually able to see something.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    #49
                    same as too be honest on my laptop now so can see a lot more tablets/phones are good but cant beat a laptop or pc at times.
                    • johns1mj
                      • May 2015
                      • 242
                      Installed a used pcb/main board. It took care of my issue.
                      • Hrs_tvgurus
                        • Jun 2014
                        • 3
                        I have same model with no stby light & only voltage I have is on pins 1-2 5.16 stby No voltage on any other pins even when I hit power command. Safe to assume I need a main. Thanks
                        • liberatorx2
                          • May 2017
                          • 6
                          • usa
                          #52
                          I have the same tv that will not turn on. When I looked at the power board I found part ic901 had the corner chipped off ? Cant read the actual # on the part cause of the chip missing. Does anyone know what part this is ? Could it cause the tv to not power on ?
                          • liberatorx2
                            • May 2017
                            • 6
                            • usa
                            #53
                            Sorry , its a vizeo E550i-b2E
                            • Louis82
                              • Feb 2012
                              • 240
                              Please provide the part number that is printed on your board. I might have it.
                              • Larry_Ellison
                                • Sep 2014
                                • 9
                                Good evening and pardon me for jumping on this thread. Since the pictures are already here I thought I would ask a question someone may know the answer to. I'm having a heck of a time finding a schematic. Connection CN103 (4pin on right above main a/c plug) on the power supply is connected to connection JP3 (4pin just above speaker connector) on the main board. Can anyone tell me what this circuit is on the main board that is being provided power to? Is it the audio circuit?
                                Thank you in advance.
                                  That 18V connector is for supplying the Voltage to run TI chip UA3 Class D amplifier.
                                  • nightstah
                                    • Jul 2011
                                    #57
                                    Originally posted by budm
                                    '8(remote on/off): 0v' The main board is not sending the ON (PS-ON same as remote on/off) command to turn on the rest of the power supply.
                                    Firstly, apologies for reviving an old thread. That said? I wanted to specifically thank you. I had the same issue with the same set that recently came into my possession. Standby voltage only, all others 0V.
                                    I'm personally grateful you outlined the order of operation. It allowed me to avoid erroneously ordering a power board and instead a main board. $22 fix, the previously dead TV sprung to life.
                                    • karthur
                                      • Nov 2015
                                      • 150
                                      I was given a set because it "wouldn't come on". The model no is E550i-A0e.
                                      When I checked the power board, I had 0vdc on pin 8 (remote on/off). I replaced the main board (3655-0642-0150). Got it for less than $20 of ebay.
                                      Not bad for a $20 TV.
                                        by sam_sam_sam
                                        03-31-2024, 02:12 PM
                                        by sam_sam_sam
                                        07-01-2024, 06:34 AM
                                      • CMCM
                                        Russound CA4 Power Supply Repair
                                        by CMCM
                                        Hello Everybody,
                                        Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                        Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                        The outputs marked 12v and 20v are all measuring only 1v.
                                        The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                        The capacitors physically look clean (no bludgesor leaks) and...
                                        Yesterday, 01:12 PM
                                      • JimBanville
                                        Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                        by JimBanville
                                        The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                        Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                        I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                        I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                        09-13-2023, 07:21 AM
