Polaroid P28LED13
  • hardyz2
    • Apr 2015
    • 6
    • United Kingdom
    Polaroid P28LED13
    I stumbled across this forum while trying to work out if it is worth trying to get my daughters TV repaired or just buy a new one and thought I would ask your expert opinions?
    The set is a Polaroid P28LED13, the problem is that when you try to turn the set on the red light on the front just keeps on flashing, previously the after a minute or so the screen would flash and the red light would go solid but now all it does is flash.
    I have changed one capacitor that I thought may be the problem as it looked like it had a slight bulge on the top but this did not work (small blue one on the pic).
    Any advice would be greatly appreciated as my daughter is doing my head in complaining that she is missing all sorts of weird programs?
    Just realised I have put this in the wrong forum, any chance one of the mods can move it to the Troubleshooting TVs and Video Sources forum please?
    • 31159
    Re: Polaroid P28LED13
    if you have a meter, check the big diodes on that board.
    • hardyz2
      • Apr 2015
      • 6
      • United Kingdom
      Sorry, don't have a meter. I was thinking of taking the board into a store and asking them to check it for me.��
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Flashing standby led on these sets normally means that the firmware on the main board is corrupt and will need reflashing.
        • hardyz2
          • Apr 2015
          • 6
          • United Kingdom
          Sounds like a plan Reecey; I assume I need to download the latest firmware, pop it on a usb and put it into the usb on the set. No doubt there will be some pesky menu that I will have to access to start the process off?
          Any advice will be very much appreciated.
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            It is a pain to preform and find the corect software version, you have to get the exact model of main board correct (the numbers on the bar code) I dare say Tom66 will be on here in a min, he is probably the best on the forum.
              I would at least get the meter to check power supply Voltages first, incorrect or missing Voltages will not do any good.
              • paulstef
                • Dec 2013
                • 724
                "previously the after a minute or so the screen would flash and the red light would go solid but now all it does is flash. "
                So it got progressively worse. This doesn't sound like a firmware problem then to me...
                The crappiest meter on ebay costs around $5.
                This TV looks like a cheap model, surely not worth it to have someone repair it for you.
                Buy your daughter a new TV or tell her to do something else, watching TV isn't good anyway. :-D
                • Debs
                  • Aug 2015
                  • United Kingsdom
                  [QUOTE=hardyz2;553360]Hi all,
                  Just realised I have put this in the wrong forum, any chance one of the mods can move it to the Troubleshooting TVs and Video Sources forum please?[Could you advise what you established on this problem my son also has this TV 16 months old and has the same problem. Asda are not interested as out of warranty. Thanks]
                  • Debs
                    • Aug 2015
                    • United Kingsdom
                    Sorry never used this forum before so I think I posted incorrectly. hardyz2. Did you ever manage to sort your TV my son has the same model and it has the same fault. Asda are not interested as out of the 12month warranty, annoyingly it is 16 months old.
                      Does your set have the flashing red light problem?
                      • crazycavan
                        polaroid TQLHD24PR004 no power
                        by crazycavan
                        hi, my tv no longer starts like dead, no standby led
                        motherboard : MS36639-ZC01-01
                        panel : V236BJ1-P01
                        flash spi: GD25Q64
                        need usb firmware or to reprogram​
                        05-05-2024, 08:40 AM
                      • snimmits
                        Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
                        by snimmits
                        Good afternoon,
                        I have a Polaroid P43D300.
                        It shipped with WiFi and Bluetooth.
                        Two weeks ago, I ran through the first time installation.
                        This did a full reset and went through the first time setup.
                        Once complete, I went to settings > sound.
                        selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
                        search completes and doesn't find any devices.
                        I have tried everything I can think of.
                        Can someone provide...
                        03-01-2024, 09:26 AM
                      • Chrissygizmo
                        Polaroid p49fn0038k backlights flashing split second
                        by Chrissygizmo
                        Hi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
                        When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
                        Any help would be greatly appreciated
                        Thanks in advance
                        11-10-2022, 10:30 AM
                      • maamar-tdj
                        Polaroid TV TQL48R4PR003 switch off after logo display
                        by maamar-tdj
                        I am looking for the Dump Firmware of this model.
                        Mark: Polaroid
                        Model: TQL48R4PR003
                        Main board chassis: CV9203H-A42
                        LCD Screen / Panel: 15y_s48ff11mb7s4lv0.1
                        More information: W25Q32
                        thank you for your reply
                        05-26-2022, 08:53 AM
                      • coax81
                        Polaroid tql39r4pr002 TV switch off after logo display
                        by coax81
                        i have an issue with my polaroid TV Model : tql39r4pr002
                        the standby led is red , and when i turn on the TV it shows the polaroid logo and turns off, also the standby led switches to blue the back to red .
                        capacitors are apparently ok, i have 320V in the smoothing primary capacitor, and 13V in the diodes in the secondary.
                        i don't understand why the mainboard switches to this mode and don't turn on.
                        don't find any service manual for this model ,or the main board schematic. cv9203h-a42
                        thank you for your help....
                        08-12-2020, 08:43 PM
