Polaroid p49fn0038k backlights flashing split second
  • Chrissygizmo
    • Mar 2021
    • 129
    Hi all, I have a polaroid p49fn0038k, I originally thought the problem was just a straight forward backlight replacement, however this isn't the case..
    When I power it up, the backlights flash on for a split second, I've tested the backlight strips and all are fine, I can see the polaroid symbol on the screen using a torch light....
    Any help would be greatly appreciated
    Thanks in advance
  • STKR123
    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
    by STKR123
    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
    I wonder if re-flashing the BIOS might be of any use here.
    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
    11-03-2024, 06:58 AM
  • rddube
    LG 50lb6100 flashing backlights unsusual fix!
    by rddube
    Thought I'd share this find for the repair of an LG tv which had started to turn on but would only get flashing backlights. Backlights would flash at a few second intervals, and when I opened it, noticed that only the 3 bottom rows were flashing, the 2 top rows were completely dead. Replaced a few burnt leds (tested with my led tester), put everything back together, tested all led strips and they were all good, but again the 3 bottom rows would go into this flashing cycle.
    Read all the discussions on the web and on Badcaps (wonderful forum!!) and...
    03-16-2022, 05:46 AM
  • KevM
    Philips Pus 436401/12 flashing backlights question
    by KevM
    hi had loads of help from this forum getting TVs back up and running but seem to be hitting a brick wall with this one.
    Backlights failed before Xmas so ordered a new set and after replacing them and putting the set back together was delighted to see it work for 15 seconds only for the picture to flash on and off and a quick look round the back confirmed the backlights were flashing on and off
    I have a steady 44v at +vled and a fluctuating 0v to 10v at -vled when the light start flashing, a steady Bl-on voltage and steady dim voltage.
    If i disconnect 2 strings of leds...
    02-04-2022, 09:40 AM
  • Bloopeta
    Panasonic TX-55CX400B backlights flashing on and off
    by Bloopeta
    Hi peeps, have a Panasonic TX-55CX400B here, guy I got it from said he tried to turn it on other day, and no backlights.
    When I received it last night, I plugged it in, and it came straight on and appeared to be working fine, so knowing this would only be temporary, I left it running for a good few hours, and they eventually went off. I tried turning it off and back on again, and this time the backlights started flashing at a steady continuous pace. So I turned it off and left it overnight as it was getting late.
    This morning when I turned it on, same problem, backlights...
    12-04-2019, 01:45 AM
  • JunkmanJimbo
    JVC lt-42em73 Flashing Backlights
    by JunkmanJimbo
    First I replaced the backlights. Then I found three bulging capacitors, one leaking, on the power supply board. Now, when I turn on the tv, the picture flashes with an image and then the picture goes away. I can unplug the tv and plug it back in, turn it on and the same thing happens. Please help. Thanks!
    09-01-2022, 06:56 AM
