Sharp Aquos LC-70LE732U Blinking Pattern 2 -5
  • rted
    • Apr 2015
    • 41
    Re: Sharp Aquos LC-70LE732U Blinking Pattern 2 -5
    Hi, took many voltage readings. For results see attachment.
    I hope this helps, TV still flashing 2 long 5 short.
    RT.
      OK, you are confused, it is connector PD pin 16 (PNL ON). what you were measuring are the jumpers, the PD-XX are not for the jumpers, they ran out of room to put the PD-XX right next to the connector.
      The PD connector is a dual row pins, the exposed pins that you see on the top side of the board are the ODD NUMBER pin, pin 1 on the left as printed on the board, next is pin 3, and so on.
      The EVEN numbers pins you have to get to it from the bottom side of the board, left bottom is pin 2, 4, .... and so on.
      • rted
        • Apr 2015
        • 41
        Sorry for the confusion. Took the Power board off and noted Q7120 has heat stress marks. What do you think? see attachment.
        Took reading as you asked and have no voltage at any pin. see attachment.
        Is it possible the transistor Q7120 has overheated and failed?
          We need to verify first that the main board is sending the command PNL ON too the power supply board or not, if it does then we can try to fix the PNL12V section, if the command is not present then you know you have problem in the main board plus the power supply board.
          • rted
            • Apr 2015
            • 41
            I wish I had the schematic of the power board, are there any test points to verify 12VDC?
            Sorry I am not sure how to check for command PNL ON from the Main board. Any suggestion?
            Should I remove the metal cover on the Main unit and test the connector PD? What pin numbers should I check voltage on?
            Thanks,
            RT.
            • newtothis
              • Mar 2013
              • 1556
              • england
              #26
              Do as budm stated in this earlier post
                OK, I look at the service manual page 73, it is pin 10 (PNL_PWR) of the PD connector on the main board.
                • rted
                  • Apr 2015
                  • 41
                  Attached is a close up of PD Connector, I have circled what I believe is row 2 pin - 10 voltage reading is .13 VDC, all other voltage readings on row 2 have 0 volts.
                  I hope this helps, thanks again.
                  RT
                    RT
                    Are you showing the PD connector on the main board or the power supply board? If it is on the main board and only has 0.13VDC, then you have problem with the main board.
                    • rted
                      • Apr 2015
                      • 41
                      I meant to say all other readings on Row 2 have 0 VDC.
                      RT
                        PD on which board?
                          RT
                          Cannot be right.
                          • rted
                            • Apr 2015
                            • 41
                            It's from the power supply board.
                            RT
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              #34
                              Ok can you tell us how you are testing... There should be readings at other pins.
                              • rted
                                • Apr 2015
                                • 41
                                The board is inverted, I grounded the board to the chassis. My negative probe is also grounded. Just took V readings again. Row 2 - pin 10 as circled is .13 VDC and the pin right above in Row 1 is 4.96VDC all other pins have O V.
                                • rted
                                  • Apr 2015
                                  • 41
                                  Here is some additional information. When I plugged the power I took readings of the main board starting with pin 24 and pin 23 and got readings of 7.51 VDC on both pins but the voltage dropped to zero soon after. Now I get the same voltages as the power board (.13 and 4.97)
                                    Thanks,
                                    RT.
                                    OK, you asked me if the PNL_PWR pin can be read on the MAIN board, so I gave you the info as shown above.
                                    But now you are testing on the POWER SUPPLY BOARD PIN 10 which is not PNL_PWR pin, the PNL_PWR pin on the POWER SUPPLY board is PIN 16.
                                    I am about to give up on this thread.
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      #38
                                      We all started somewhere budm, I remember when I used to get really confused LOL!
                                      rted do please try and follow exactly what is being asked of you... We won't ask for you to check pins that are the wrong ones etc... especially if we have schematics in front of us. Remember some of us repair electronics for a living and members like budm, tom66 etc are our elite of what we do regarding this. Trust them and follow exactly what they ask... If you don't understand it then re-read the posts and instructions... If you still don't understand then let us know and we will try to explain anything you need to know
                                        This board is not made for beginner because the EVEN number pins have to access from the bottom side of the board and that can be very dangerous to make the measurement with the board powered up while it is setting upside down.
                                        May be he can use small pin to insert into the connector instead so he can get the reading that way.
                                        Otherwise wait for me so I can trace out the board and see if we can locate the connection to the PBL_PWR from the top side of the board, I really do not want him to have accidentally short the board out while it is upside down.
                                        So do not do anything for and wait for me to give you the test point from the top side of the board.
                                          OK, I trace out the bottom side of the power supply board to see how the PNL-POW and the PNL12V are connected and generated.
                                          As you can see, you can put the meter on JUMPER J7058 to test the PNL-POW signal.
                                          The PNL12V output is from the electronics switch that is turned on by the PNL-POW signal.
                                          POWER SUPPLY BOARD PD connector pinout:
                                          PD-1-2 = PNL12V
                                          PD-3-4-9-10-11-12 = SGND
                                          PD-5-6-7-8 = UR13.2V
                                          PD-13 = AC-DET
                                          PD-14 =PS-ON
                                          PD-15 = BU5V
                                          PD-16 = PNL-POW
                                          PD-17-18-20 = N.C.
                                          PD-19 = DIMMER
                                          PD-21 = OFL
                                          PD-22 = ERROR
                                          PD-23 = NOT USED
                                          PD-24 = STB
                                          • olegeisler
                                            SHARP AQUOS LC-70LE836S only blinking - freebie
                                            by olegeisler
                                            Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                                            Symptoms :
                                            When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                                            A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                                            Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                                            As I see it mainboard has some kind of life, but does not...
                                            07-23-2022, 07:01 AM
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • jonah1024
                                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                                            by jonah1024
                                            Hello!
                                            I'm a few days old into this TV screens repair universe so please bear with me.
                                            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                            - I did a factory reset as well...
                                            07-16-2024, 04:23 AM
                                          • bajdik
                                            Sharp LC-40LE830E white blinking after wallplug is off
                                            by bajdik
                                            Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
                                            07-21-2023, 09:05 AM
