Sharp Aquos LC-70LE732U Blinking Pattern 2 -5
  • rted
    • Apr 2015
    • 41
    Re: Sharp Aquos LC-70LE732U Blinking Pattern 2 -5
    Hi Budm, sorry if I don't follow your instructions. I also appreciate your patience and understanding.
    I noted the 12V is coming from Q7120, Attached is a picture of the Q7120 from my previous post that looks like it has heat stress marks on the board. What do you think?
    I also took readings of the Q7120 from the top side see attachment. I took reading from jumper J7058 and it was .13V.
    Voltage reading at the PD pin 16 is .13V. Pin 15 is 4.95V all other pins are 0V. see pic PD connector voltage readings.
    I hope this helps and again I'm doing my best and sorry if I mess things up.
    RT
      OK, so the main board is not sending the signal to turn on the electronics switch Q7120.
      So troubleshooting the main board will be next.
      You can do the following, you can force on the Q7120, or jump the input-output pin of Q7120 just to verify that the T-CON is OK, The key is that they must be done AFTER the TV is turned on.
      • rted
        • Apr 2015
        • 41
        OK, I jumped the Q7120 input output pins as you suggested after the TV was turned on and the panel power came on saw the screen turn on for about 3 seconds then went black.
        I hope this was what you were asking for.
        RT
          Yes, so the error went away?
          I wonder if the it goes back to standby due to no video signal detect or it has more problems.
          Try to see if you can get on screen setup menu to come up.
          • rted
            • Apr 2015
            • 41
            The setup menu comes on panel picture looks fine. Do you want me to do a factory reset?
            • rted
              • Apr 2015
              • 41
              The error went away and the TV picture is fine. It's been on for almost an hour. I think you go it narrowed down now, great job!!!!!!
              FYI Voltage reading on pin 16 is 10.8 Vdc. On the main board D3303 red diode blinking on /off. Turned TV off then on a couple times and the TV is working fine!!
              • rted
                • Apr 2015
                • 41
                Originally posted by rted
                The error went away and the TV picture is fine. It's been on for almost an hour. I think you go it narrowed down now, thank you!!!!!!
                • rted
                  • Apr 2015
                  • 41
                  This morning I turned the TV on by jumping Q7120 input/output pins and the TV picture was fine once again. Looking forward to finding the root cause of the main board panel switch not working.
                  Thanks again Budm for helping me get to this point.
                    Need to look at the diagram of the main board to see how that PNL-PWR is generated, there should be a switched transistor that is commanded on and off by the processor.
                    • rted
                      • Apr 2015
                      • 41
                      Looking forward to the solution. Thanks for everything to date.
                      RT.
                        Please check the resistance of the PNL-PWR pin (the control pin) against chassis GND for me, no power to the TV of course.
                        I just want to make sure it is not being grounded out.
                        • rted
                          • Apr 2015
                          • 41
                          Hi Budm, checked the resistance from panel power pin 16 to chassis ground. meter reads 1, open circuit.
                          Thanks,
                          RT.
                            OK, that is fine.
                            I look at the service manual which does not have any diagrams, just the block diagrams, the PNL-PWR seems to be generated directly by the processor without any buffer circuit.
                            So at this point you just have to use it the way it is, the only bad thing is that when TV goes into standby (not powered off by the power switch) when it does not detect video signal, the T-CON will still get 12VDC which is no big deal since the TV signal will always be present any way, otherwise the 12V will be shutoff when TV is turned off.
                            • rted
                              • Apr 2015
                              • 41
                              What do you think if I connect a push button switch to the input and output pins of Q7120, wire it so I can access the switch on the outside of the TV.
                              • newtothis
                                • Mar 2013
                                • 1556
                                • england
                                #55
                                That would work
                                  You can disconnect the PNL-PWR wire going back to the main board and then use 1K resistor with one end connected to STBY power supply, another end goes to the switch Common contact, The N.O. contact of the switch goes to the PNL-PWR pin of the connector PD of the power supply board.
                                  This way you do not have 12V running to the out side of the TV, using low level signal is a lot safer.
                                  Since one end of the resistor is directly connected to the STBY power supply, the other end goes to out side, so if that wire shorted to the chassis, the maximum current will be only 5V/1000 Ohms = 5mA.
                                  • rted
                                    • Apr 2015
                                    • 41
                                    Thank you Dudm, Newtothis, Johnboy1313, and R_J. I truly appreciate your patience, understanding and taking time to help me solve the problem.
                                    As a doityourselfer sites like this are priceless, I'm going to make a donation and hope all other Newbies do the same.
                                    Cheers to all!!!!
                                    • bryan4203
                                      • Aug 2015
                                      • usa
                                      #58
                                      Im a total noob, and I know this thread is old, but how do i do this? Ive found q7120 and it has 4 legs. My question is where is the input-output pin? Thanks for reading
                                      • rted
                                        • Apr 2015
                                        • 41
                                        Did you ever get a reply or help with regards to my post " Sharp Aquos LC-70LE732U Blinking Pattern 2 -5"?
                                        • rted
                                          • Apr 2015
                                          • 41
                                          OK, I trace out the bottom side of the power supply board to see how the PNL-POW and the PNL12V are connected and generated.
                                          As you can see, you can put the meter on JUMPER J7058 to test the PNL-POW signal.
                                          The PNL12V output is from the electronics switch that is turned on by the PNL-POW signal.
                                          POWER SUPPLY BOARD PD connector pinout:
                                          PD-1-2 = PNL12V
                                          PD-3-4-9-10-11-12 = SGND
                                          PD-5-6-7-8 = UR13.2V
                                          PD-13 = AC-DET
                                          PD-14 =PS-ON
                                          PD-15 = BU5V
                                          PD-16 = PNL-POW
                                          PD-17-18-20 = N.C.
                                          PD-19 = DIMMER
                                          PD-21 = OFL
                                          PD-22 = ERROR
                                          PD-23 = NOT USED
                                          PD-24 = STB
                                          Hi BUD M,
                                          You helped me solve a problem with the subject title over a year ago. The TV has now gone to the blinking pattern 2 - 5 once again. I would like to replace the Q7120.
                                          Would you be so kind to send me the part number of Q7120 or tell me where I can find the schematic so I can replace it on the board.
                                          Your kind reply is greatly appreciated.
                                          RT
                                          • olegeisler
                                            SHARP AQUOS LC-70LE836S only blinking - freebie
                                            by olegeisler
                                            Got this SHARP AQUOS LC-70LE836S for free - did some basic troubleshooting, and found manual - without detail schematics though. Comes from a meeting room with extremely few working hours.
                                            Symptoms :
                                            When connected to mains, the logo blinks continously, approx 6 times per 10 seconds.
                                            A press on MENU as per the manual changes this to one short blink, one long and then repeats.
                                            Only 5V ( Standby ) on PSU module present, no AC_DETECT, no 12V, no 13V, no PS_ON from mainboard.
                                            As I see it mainboard has some kind of life, but does not...
                                            07-23-2022, 07:01 AM
                                          • scubacamper
                                            Sharp Aquos LC-70C6400U Half Screen Dark
                                            by scubacamper
                                            I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                            Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                            when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                            05-03-2025, 12:19 PM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • jonah1024
                                            Sharp Aquos LC-40UG7252E LCD TV burn in?
                                            by jonah1024
                                            Hello!
                                            I'm a few days old into this TV screens repair universe so please bear with me.
                                            Recently, and all of a sudden my 40” 4K Sharp Aquos LCD TV turned on with colors all smudged in some places on the screen that remain like that even without any kind of video source. I do have image but the colors are smudged/tinted/ washed out in patches as per defects. This to me looks similar to burn in but I’m shore this is not an OLED.
                                            - I did the classic unplug and hold power button to discharge the caps but it didn't help.
                                            - I did a factory reset as well...
                                            07-16-2024, 04:23 AM
                                          • bajdik
                                            Sharp LC-40LE830E white blinking after wallplug is off
                                            by bajdik
                                            Hello, on Sharp LC-40LE830E is everything OK. Working great. If I put the 230 V off and on again, it just blinking white standby LED. I can power on only via VOL- and CH+ and POWER button on TV. After that, I can power off and power on again without problem (by buttons or remote control) until the 230 V is connected. If i put the plug off and on again, just white standby LED blinking. TV needs three button starting again.. On the first look, the backlight looks great, no darker or lighter spots. Any idea what is wrong?
                                            07-21-2023, 09:05 AM
