is this a defective lcd screen?
  • mattstolte
    • Dec 2013
    • 612
    • usa
    lg 32lk330 modelClick image for larger version
  • newtothis
    • Mar 2013
    • 1556
    • england
    Re: is this a defective lcd screen?
    Looks like it to me
      +1
        Hard to tell, looks different to other failures I've seen before so would consider main board as a possible cause. Or t-con if it has a motion FRC on board.
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          its dead Jim!
          Follow the white rabbit.
            I wouldn't think with big dead band like that will cause by T-CON or Main board, it is so hard to be 100% sure.
            I wonder what the on screen user menu looks like.
            • newtothis
              • Mar 2013
              • 1556
              • england
              Yeah I thought the same budm, It was that huge band that made me think panel... If it was just the other lines in pattern I would of thought differently
                The only thing that is throwing me off is that the band is one colour and horizontal. That means the source drivers of the panel are working, and it rules out the gate drivers as they can't discriminate single colours. But, it's possible that some signal between the T-con and the drivers is causing a malformed image, this could be a panel fault if the fault was a short on one of the drivers or something like that.
                • mattstolte
                  • Dec 2013
                  • 612
                  • usa
                  Tom can u send me a picture of a motion frc
                    http://www.bestbuy.com/site/lg-32-cl...&skuId=2137061
                    It is only 60Hz TV so it does not have FRC.
                    • mattstolte
                      • Dec 2013
                      • 612
                      • usa
                      the screen doesn't even change when I press menu, so I take it its defective panel]
                        This is not a guarantee - a defective main, or in rare cases the T-con could also cause the picture (or what is left of it) to freeze up.
                        I'm not saying the panel isn't bad -- it's a crapshoot either way.
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          There is also a slight "shearing" of the picture on the top section, going towards the bottom left, starting at the top right. Or is this just an artifact of the screen refresh timing and camera timing?
                          Muh-soggy-knee
                          • mattstolte
                            • Dec 2013
                            • 612
                            • usa
                            theres nothing hooked up to it ben just power so theres no picture
                            • ben7
                              Capaholic
                              • Jan 2011
                              • 4059
                              I'm talking about the screen, whatever that failure is causing it to display. There is a shear in the picture.
                              Muh-soggy-knee
                              • Ryan.man
                                by Ryan.man
                                02-04-2025, 12:23 PM
                              • Mad_Science
                                Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                                by Mad_Science
                                I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                                03-01-2024, 05:05 PM
                              • smic717394
                                by smic717394
                                07-25-2024, 10:16 AM
                              • vpower
                                Acer Nitro 5 model N20C2 board LA-K862P black screen
                                by vpower
                                I have this laptop: charging light is on when connected to the charger, when I push the power button you can hear the fans spinning for a three seconds, the keyboard backlight it turning on, the caps lock key is unresponsive, no image on screen. Only a couple of times it booted with image for a few seconds and then reboots to black screen. When it is frozen with black screen and lit keyboard, I can keep pressed the power button to shut it completely.
                                I downloaded schematics in this forum ( https://www.badcaps.net/forum/troubl...y/troubleshoot...
                                11-23-2024, 02:58 PM
                                HP ProBook 640 G1 Base Model Notebook 600 Specification for Upgrade or Repair
                                This specification for the HP ProBook 640 G1 Base Model Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 640 G1 Base Model boardview and 640 G1 Base Model schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 05:27 AM
