Toshiba 55g300u issue after issue
  • x9x9x9x9x9
    • Apr 2015
    • 20
    What the tv does currently: no noise or picture just a black screen with a green power led. Sometimes when power is turned on you can hear a very faint electrical arc/buzz for a half second or so. It is hard to get it to repeat the noise on each power up.
    I have a toshiba 55g300u. I replaced the power board and the jumpers on the backlight boards. When I got the TV it was broken. I opened it up and the jumpers from the master backlight board to the slave boards were burnt up on both sides. As in there are 2 sets of board. I replaced the power board and jumpers and when I did that the tv powered on but the jumpers I had put on I had just quickly soldered for the test. While running the test the TV powered on but I had a friend helping me (who isnt the most intelligent) and he kept trying to move the back light boards while the tv was on. He was trying to put them on the little knobs that hold them in place. During this some of the jumpers popped up and touched/shorted. Now I can't get it to work again. What could it be on the power board that blew? All the caps look good but I haven't tested them.
    I haven't looked much at the logic board for issues.
    Some where I have photos of the burned out jumpers I can upload. I will just need to find the photos.
    The story/background of this TV: I received it for free from a friend not working. Opened it up and saw the burnt up jumpers and then got tired of it laying around and gave it to my boss. Now that he has it he is making me do all the labor while he buys the parts. To put it softly I am a little pissed off about this. At this point I just want the thing to work or be completely dead so I can get it out of my life :-)
    Thanks,
    Chris.
  • x9x9x9x9x9
    • Apr 2015
    • 20
    Re: Toshiba 55g300u issue after issue
    still havent found the problem
      Any good clear pictures of the all the boards, the jumper that shorted to the chassis, the whole back side of the TV?
      • CapLeaker
        Leaking Member
        • 8222
        Thanks,
        Chris.
        Buy him a new one?, or put it in the trash can.
        • x9x9x9x9x9
          • Apr 2015
          • 20
          Here are 2 pictures 1 of each bacl light boards jumpers. I will take more photos in just a few minutes. I have reploaced the jumpers multiple times now but I soldered each one since I didn't have the proper molex connectors.
            I hope they will be better pictures cause I am trying to see if the wire that touches the chassis is the B+ power wire or the transformer driver wire, right now I cannot tell form the pictures.
            Did you check all the fuses on the inverter boards?
            • CapLeaker
              Leaking Member
              • 8222
              uff... its like I am wearing my grandmothers glasses. Check your pics... those are majorly out of focus.
              • x9x9x9x9x9
                • Apr 2015
                • 20
                Sorry, I quickly took those when I first opened it up to show my buddy the burnt up jumpers. I think the problem is the transformer I removed (I have a replacement board) Oh and this is not my solder job I was teaching a coworker.
                  Can we see the whole back side of the TV to see how all the boards are connected together?
                  There are more than one version of your TV:
                  http://www.shopjimmy.com/catalogsear...oshiba+55g300u
                  • x9x9x9x9x9
                    • Apr 2015
                    • 20
                    Here are the others
                    • x9x9x9x9x9
                      • Apr 2015
                      • 20
                      Oh sorry I just saw the reply wanting to see the back. Here you go. Thanks everyone. The transformer has had the kapton tape removed.
                        So the fuses on the inverter boards are OK?
                        • x9x9x9x9x9
                          • Apr 2015
                          • 20
                          I believe so. What is the best way to test them? I just used a continuity test.
                            If the fuses are good, showing <1 Ohms, then check and see if you do have 24VDC feeding the fuses.
                            • x9x9x9x9x9
                              • Apr 2015
                              • 20
                              Okay. Tomorrow I will bring the second board up here and check that. I was measuring one of the 12v lines to the back light (i think) and it was come up to 8 volts or so then quickly drop out when the power button was pressed like the board said abort to the power operation. The electrical arc sound was coming from the transformer on the power board. I really hope thats not a normal thing because getting that off took a lot of work.
                                BTW, so right now the TV is totally dead, no green power LED?
                                  12V is not used by the inverter board: look at P803, 804
                                  http://assets.shopjimmy.com/media/ca...8932-top_1.jpg
                                  You can disconnect the P803, 804 and see if the TV will power up.
                                  • CapLeaker
                                    Leaking Member
                                    • 8222
                                    Yeah, I am wondering about that too. We need to know if there is standby voltage, maybe the TV powers up and there is no back light, or the whole thing is dead. So a detailed description on the power status would be good.
                                    • x9x9x9x9x9
                                      • Apr 2015
                                      • 20
                                      I am getting the green power led. When I hit the power button it goes out. Then I can hit it again a few seconds later and it will come back. Its like the back light circuit is dead but there is no sound either.
                                        OK, the inverter circuit in this TV does not generate any error signal back to the main board what is going on with the inverter board, so the TV should work without having the inverter boards connected.
                                        So lets find out the PFC Voltage booster circuit is working or not first, you will have to measure the DCV between the two legs of the main filter 450VDC caps (at any one of the two caps will be find).
                                        The DCV on the cap should jump from 160VDC to >360VDC when power switch is activated and should stay at that level until the TV is turned off.
                                        You will be working in the Deadly primary side of the circuit, so do not touch anything and do not let the probes slipped on you.
                                        • Soulzink
                                          Samsug washing machine. Power supply DC41-00189a board issue
                                          by Soulzink
                                          I am trying to fix a samsung washinmachine power supply main board.
                                          I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                          Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                          The power supply board reference is the following: DC41-00189a
                                          I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                          04-19-2025, 06:26 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • notallbad
                                          TCL 55RP620K power board issue
                                          by notallbad
                                          Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
                                          0% p_dim at 1.65v and a_dim at 1v
                                          50% p_dim at 3.3v and a_dim at 1.65v
                                          100% p_dim at 3.3v and a_dim at 2.88v
                                          Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
                                          Leds are 2 rows of 15 6v leds.
                                          On inspection of the power board found diode MBR3200 shorted so replaced with...
                                          07-12-2025, 05:45 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
