I have a 42LG50-UA tv. When I turn the TV on, the image is good for about 30 seconds. The image then becomes increasingly saturated with red and slightly dim. Images look coarse and the problem is especially apparent in skin tones. I have a multi-meter but my experience with electronics is limited.
42LG50 Red Tint and Dim Screen
Tags: None
Re: 42LG50 Red Tint and Dim Screen
And a picture of the T-con board will help (top of TV usually, connected to the main A/V board, which is in your 1st picture)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
I tried to capture the fault in the image with these pictures from the TV. The ones labeled correct were taken from my phone and the ones labeled fault were taken from the TV set. I also took a couple pictures of screen test images on my TV. The screen test pictures I found online and projected to my TV; they are not from the TV menu as I could not find any there. To my untrained eye, the test screen pictures looked good.Comment
That looks like Gamma Voltages problem on the T-CON board, U7 is AS15??Never stop learning
Thank you for the help budm. Is "U7 is AS15" a reference to a bad processor chip? Do you have a link to show the replacement of a T-CON board with similar connectors?Comment
AS15 is the GAMMA Voltage reference IC.
Your T-CON board P/N is 35-D023305 as printed on the bar code sticker.
http://www.shopjimmy.com/cmo-35-d023305-t-con-board.htm
Please verify the numbers since your pictures are not in focused.
You can also check the DCV of the Gamma Voltage test point #1~17 with reference to chassis GND.
http://assets.shopjimmy.com/media/ca...3305-top_1.jpgLast edited by budm; 04-09-2015, 03:31 PM.Never stop learning
1-13.02V
2-11.68V
3-10.96V
4-9.96V
5-9.78V
6-9.50V
7-8.96V
8-7.55V
9-6.99V
10-6.40V
11-6.02V
12-5.04V
13-4.76V
14-5.23V Not a typo
15-3.96V
16-2.63V
17-1.70VComment
Thanks to everyone who helped. @newtothis I ordered a new board. My hand isn't steady enough for soldering.@tom66 I read another thread you started on a different forum about the AS15 and AS19 ICs going bad. I have the AS19-H1G IC. I don't know if these events are related but my house was hit by a power surge which destroyed a couple battery chargers I had plugged in. That was about the same time the problem in my TV started. The TV is 6 years old. @newtothis are there any tips for replacing the T-CON board? Again, this is the first TV I have ever attempted to repair. I did read the manuals posted by budm.Comment
I think the failures just "happen", and there's little you can do to prevent it.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM -
by smic717394Hi,
I have a iphone XS that came in for a screen replacement, the screen was badly cracked, and inside missing scues, on the back of the screen still the blue protector, the screen was a LCD. So we replaced the screen and all good, installed the screen and we noticed that pressing the screen with a bit of force but not excessive, the phone dies. After plugging the charger it turns back on, but again if you press it it dies. I open the phone again, and I can't see anything major, with the phone open, if I press on the logic board, battery, charging board, or even putting pressure on... -
by ChrissygizmoHello everyone, I’ve just been given a Samsung UE55JU6800K smart tv as it had white spots on the screen due to the led lenses falling off. After refitting them & putting the tv back together I thought it was a nice easy fix for a free bedroom tv , then I tried it before screwing the back into place. I realised that the right side of the screen was darker than the other side, I removed the screen again as I thought the backlights had failed but they are fine.
I put the screen back in place & turned it back on . The screen seemed to be ok again but different screens on the same... -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo - Loading...
