TH-P50G15A - 6 Blinks- Bad TNPA4782
Re: TH-P50G15A - 6 Blinks- Bad TNPA4782
Ok I feel like im going crazy here... I remeasured Q660 and its not shorted now... I could of sworn I went over it twice and my meter beeped on continuity... I need a break =/
Also I haven't replace IC 691 yetComment
So this is 6 blinking but nothing is blowing?Comment
I'm getting something like 169K on both those ICs pins 10-20. The thing is I plugged on the SC board with Sc50 shorted. It'll sound like the SC turns on for a second (starts buzzing) and then goes off and then it'll start blinking 6 times.Last edited by Glitcher; 04-11-2015, 03:36 PM.Comment
You checked the MID voltage?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
D652 is that ok. Maybe throw a new IC691
My resistance is nothing like yours across 10-20 for those buffer ICs,ic561,562.
mine starts in the meg ohms decreasing slowly as it charges.
So I tried diode red on 10(gnd) = 0.484, Blk on 10(gnd) 0.968Comment
Yep I'm stumped... The only thing I noticed is the MID voltage is too low, peaking at around 45V. So I guess there has to be a problem with the FET and drivers? (IC521 I guess) Replaced some extra parts, and even some from your image but still no process... ugh I hate these boards -.-Comment
If its only going to 45V then the ckt is only being charged by the resistors to Vsus, I would check if the gate drivers are working (check their 5 & 16V supply)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
here's some diode readings
q451
g(red)
- E(blk)0.608,
- c(blk)1.041
g(blk)
- E(red)0.998,
- c(red) OL
E(red)
-C(blk) 0.47
E(blk)
- C(red) OL
Q441
g(red)
- E(blk)0.604,
- c(blk)charges and goes OL
g(blk)
- E(red)0.992,
- c(red) OL
E(red)
-C(blk) 1.94
E(blk)
- C(red) OLComment
Heres what I got on mine, seems pretty much the same.
q451
g(red)
- E(blk)0.654,
- c(blk)1.086
g(blk)
- E(red)1.065,
- c(red) OL
E(red)
-C(blk) 0.480
E(blk)
- C(red) OL
Q441
g(red)
- E(blk)0.661,
- c(blk) OL
g(blk)
- E(red)1.002,
- c(red) OL
E(red)
-C(blk) OL
E(blk)
- C(red) OLComment
q451
g(red)
- E(blk)0.654,
- c(blk)1.086
g(blk)
- E(red)1.065,
- c(red) OL
E(red)
-C(blk) 0.480
E(blk)
- C(red) OL
Q441
g(red)
- E(blk)0.661,
- c(blk) OL
g(blk)
- E(red)1.002,
- c(red) OL
E(red)
-C(blk) OL
E(blk)
- C(red) OL
Can you zoom in on D618 and illuminate?
R451,441, do they measure 5.6 ohmsComment
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by EazyBoneI write this to maybe help another with this TV.
So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
...03-18-2024, 10:24 PM -
by VebririonHi everyone,
I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible â so please forgive any odd phrasing.
I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report... -
by BiruslapioBought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner... -
by UserrrnameđđģI recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...07-19-2025, 07:53 AM
- Loading...
