TH-P50G15A - 6 Blinks- Bad TNPA4782
Re: TH-P50G15A - 6 Blinks- Bad TNPA4782
Ok, the jury has come back with not guilty. Just fixed my second 4782 first go.
Here's my list, some of which again maybe overkill but I'm sticking to this until i know more.
Q601, RJK6026 shorted_ used STP10NK60ZFP 600V 10A N FET
Q661, RJP6065, shorted_ used RJP63F3A
Q441, 45G127 _ shorted_used 45G128
Q451, 45G127 _ shorted_used 45G128
Q701, MMBTA92
Q702, 2PD601
Q818, 2SK3018 _ used 2N7002
Q551 CPH5524_ shorted
D608, MA8120M, MAZ81200ML 12V 150mW zener(DIODE ZENER 12V 150MW SMINI2) _ open cct_ I had to improvise here and used 1N4742 12V 1W axial lead
D618 RF101L4S 400V 1A shorted
R613 47K was open cct, can not tell in cct if good
IC771,724,725 78L05 _ seemed ok
IC773(bad),564, 464,465 _ TC7SH14F
IC521 M81707FP _ used M81737FP
R521,522 100ohm 5% metal _ burnt out open cct
NOTE: These are AA_CSL, AA_CML & they originate from IC562. If those resistors are blown then that high voltage has been feed back to the octal buffer ICs at SC20.
Both mine IC561,562 were shot showing a P5V in resistance of about 500ohms
Once removed that cleared. IC563 is also on the same Vcc but seems to have survived.Comment
There is one glitch I've found and not sure what to think or whether it's a characteristic or not.
When in serv tool, if you hold return it will shutdown and reboot the TV. With the original board i fixed with no vset cct it does this.
with this board which has vset, it 7 blinks. turn it off/on and back to normal. Can be repeated so unsure if there's some tiny part I've missed or what.Comment
Maybe worth trying on some test patterns - could be some patterns such as full white or all black will trigger a shutdown.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Ran full white for half an hour, certainly heats that SC up. No, I was thinking there's some residual voltage as when you force it to recycle it tries to fire the panel up pretty quick.
with the remote you can't forec it to recycle immediately, there's a period where the main board will not recognise the on command, like a lock out until it's ready or a set period.
Not overly concerned but i hate the unexplained. never seen a 7 blink using return to cycle on any Panasonic before so would not surprise me something minor is wrong with the detect cct.Comment
Try setting it to dynamic pic mode and try turning it to all black then after 5mins press MENU or something to light up the screen does that trigger an error?
A lot of these older Pannys will essentially turn the panel off on all black, the panel still is primed but the priming is reduced to the minimum level and sustaining is eliminated for all but the first subfield. Lets them claim 5,000,000:1 dynamic contrast. As soon as an image needs to be displayed, priming glow will return almost immediately.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Out of time I'm afraid. Heading home TV remains. Not bad though, fixed 50u20(card swap A board), 50St30A 7 transistors, P50G15 including two 4782 SC rebuilds.Try setting it to dynamic pic mode and try turning it to all black then after 5mins press MENU or something to light up the screen does that trigger an error?
A lot of these older Pannys will essentially turn the panel off on all black, the panel still is primed but the priming is reduced to the minimum level and sustaining is eliminated for all but the first subfield. Lets them claim 5,000,000:1 dynamic contrast. As soon as an image needs to be displayed, priming glow will return almost immediately.Comment
Well I've seen something similar on the one and only 5081 board which also had burnt out 100 ohm resistors on those lines to IC521.
It stands to reason that those resistors can't burn out fromthe buffer IC only from high voltage from the FET driver. They're on the input side so internally that chip would have to short internally for this to happen.
Just ohm out pins 10-20 on those or 7-14 on that inverter IC. that's on the P5v or 5V that enters from the A board at SC20Comment
blk lead on D, I get is 9.36k G-S, ol on any other
red lead on D, 2.26Meg D-G, 2.31Meg D-SComment
Looks like I found the problem, I desoldered it and I'm not getting any readings at all from it seems like it blew. It seems to be a P-Channel 250V 3A Mosfet vg = 30v. Now If I could find a suitable replacement from some of my salvaged Panasonic boards.
I isolated both R613 and R869 and they measured good.Last edited by Glitcher; 04-11-2015, 06:39 AM.Comment
so what are you saying , you can't replicate in cct my readings in diode mode?Looks like I found the problem, I desoldered it and I'm not getting any readings at all from it seems like it blew. It seems to be a P-Channel 250V 3A Mosfet vg = 30v. Now If I could find a suitable replacement from some of my salvaged Panasonic boards.
I isolated both R613 and R869 and they measured good.Comment
have you looked at the pictures I posted of that part of the cct being deleted? I have two AF boards , one with, one without that Vset cct, so clearly it's possible for it to be removed and the Tv to work.
I suppose I could remove mine and check that P fet. i always thought they'd blow short and FETs need to be switched on to check. I think very early on I did not know this and had a FEt show open but I was testing wrong. Don't kow much about P fets but that one is unique, I tried looking for a sub a while back for a post and never had any luck. Also unique I think for these models.Comment
Did you remove both of those ICs to get the tv to work?
My D806 was completely blown in half so I had some suspicion the damage could go to that FET. I could be wrong though. I have seen and had some FETs that have completely blown which went open cct but the damage is usually obvious.Comment
No, that's how that board is from manufacture which is my point. panasonic decided to delete it somewhere along the line. None of the photos at SJ show it deleted but i have one and if you go through Hombre's post he has a 46" board also with no vset cct.Did you remove both of those ICs to get the tv to work?
I have 2 rev AF but hey are not the same. I don't have the other board in front of me just the one with the same setup as yours.
I'll remove my FEt and see what it does out
Any chance we can start referring to D806 as d608, i keep looking for a diode that does not existComment
by clooI recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
After doing a factory reset this problem was gone and the picture was back to...01-06-2025, 06:02 AM -
by EazyBoneI write this to maybe help another with this TV.
So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
...03-18-2024, 10:24 PM -
by NairolfHello,
I have a Samsung DM32D display.
When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
Here’s what I have tried so far:- Disconnected the cable between the mainboard and the power supply → the backlight turns on.
- Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
- Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
From these tests, I suspect the problem might be on the mainboard. Could anyone...3 Photos08-24-2025, 03:47 AM -
by VebririonHi everyone,
I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report... -
by Userrrname👋🏻I recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...07-19-2025, 07:53 AM
- Loading...
