TH-P50G15A - 6 Blinks- Bad TNPA4782
  • Glitcher
    • Mar 2013
    • 673
    • USa
    #61
    Re: TH-P50G15A - 6 Blinks- Bad TNPA4782
    Any chance we can start referring to D806 as d608, i keep looking for a diode that does not exist
    Ahh sorry bout that, Don't know why I keep getting them confused. Must be from a past board I worked on.
    • tw2005
      • Oct 2011
      • 6458
      well game over for my board. just destroyed the Pfet. casing cracked and leg fell out.
      bugger
      Not sure you're on the right track though as i get the same results with the FET out. I don't think you can get more open cct than what i got with no FET at all now!
      • Glitcher
        • Mar 2013
        • 673
        • USa
        #63
        Dang that sucks wait are you getting the same readings on the pads with the fet removed? As in post 53?
        • tw2005
          • Oct 2011
          • 6458
          FQD4P25 may be ok not that helps me find one any easier
          • tw2005
            • Oct 2011
            • 6458
            yep little or no difference. you never know but maybe my fet was open ? I actually wanted to test the FET out but that chance is gone
            • tw2005
              • Oct 2011
              • 6458
              Actually, i was being sarcastic and now i'm not joking but I think this FET is shot. the whole casing is cracked that's why that leg crumbled out. But this board was working like this except that anomally I discussed with Tom. Which brings me back to these boards working with this part of the cct omitted.
              So maybe get a FET, I am LOL.
              • Glitcher
                • Mar 2013
                • 673
                • USa
                #67
                Even with the FET removed I'm still not getting the same readings as you. I'm thinking theres a problem somewhere in the area where D608 is. My D608 reads .707 and OL
                • tw2005
                  • Oct 2011
                  • 6458
                  Try opto PC601, they're pretty common on sc,ss boards if you have scraps
                  • Glitcher
                    • Mar 2013
                    • 673
                    • USa
                    #69
                    Just tested PC601 out and changed it, doesn't seem to change my readings for D608 though. I was trying to replaced some extra parts IC464, IC465 near the M81707 FET drivers to be safe but ended up peeling these traces off... Barely even touched it with my iron and it came right off for both of them too! it doesn't seem like the trace goes anywhere, are they just place holders?
                    • tw2005
                      • Oct 2011
                      • 6458
                      Pin 1 is NC. Well that's pretty rough. Do you have flux pen and a very fine conical tip?
                      We seem to be heading off in tangents now. I'm still curious about the OL across the diode
                      • Glitcher
                        • Mar 2013
                        • 673
                        • USa
                        #71
                        What exactly is NC?
                        • tw2005
                          • Oct 2011
                          • 6458
                          I took my opto out still same unless this is just how your meter rolls? What do you have?
                          • tw2005
                            • Oct 2011
                            • 6458
                            What exactly is NC?
                            No Connection
                            • Glitcher
                              • Mar 2013
                              • 673
                              • USa
                              #74
                              So I guess I'm fine without those traces? Explains why it would peel off so easily I guess.
                              I just have a regular meter I bought from some electronics store.
                              Maybe it was the diode you used?
                              • tw2005
                                • Oct 2011
                                • 6458
                                I had the same reading both direction until I replaced it, remember. W'e already compared that's what lead me to replacing my diode
                                • Glitcher
                                  • Mar 2013
                                  • 673
                                  • USa
                                  #76
                                  Originally posted by tw2005
                                  answered in post #40 but now with this huge 1watt zener 0.663 & 1.7.
                                  Its that 1.7 that's different from mine. I'm getting 0.704 & OL.
                                  • Glitcher
                                    • Mar 2013
                                    • 673
                                    • USa
                                    #77
                                    blk lead on D, I get is 9.36k G-S, ol on any other
                                    red lead on D, 2.26Meg D-G, 2.31Meg D-S
                                    blk lead on D I have 9.75k G-S, ol on any other
                                    red lead on D 7.35Meg D-g, 7.34Meg D-S
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      yep, I realise but we may be chasing a non issue if your meter reacts different.
                                      I get about 9.5k in either direction and there's a 10k rsistor across where we are testing> I don't think we can get clear picture of what's going on and I can't see where to go next or if i's worth the time
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        Is d619 ok?
                                        • Glitcher
                                          • Mar 2013
                                          • 673
                                          • USa
                                          #80
                                          Well going through all the IGBTs again I just found Q660 is short... I didn't replace this one yet since it wasn't shorted the first few times I went over it.
                                          • cloo
                                            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
                                            by cloo
                                            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
                                            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
                                            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
                                            After doing a factory reset this problem was gone and the picture was back to...
                                            01-06-2025, 06:02 AM
                                          • EazyBone
                                            Un50cu7000 2 blink oddity *partially solved
                                            by EazyBone
                                            I write this to maybe help another with this TV.
                                            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
                                            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
                                            03-18-2024, 10:24 PM
                                          • Vebririon
                                            panasonic TX-P50V10E 6 blink led problem
                                            by Vebririon
                                            I'm new here and trying to repair my Panasonic TX-P50V10E plasma TV, which is currently showing the 6 red blink error code.
                                            Just for context: I'm used to building PCs and installing modchips in old consoles, but this is my first time trying to fix a TV. I'm French, and while my English is okay, I'm using ChatGPT to help translate and clarify my messages as much as possible — so please forgive any odd phrasing.
                                            I'm also not very experienced with using a multimeter, but I'm very motivated and ready to follow instructions carefully and report...
                                            05-17-2025, 10:16 AM
                                          • Biruslapio
                                            Panasonic P58V11B 8 and 12 blinks error "fix"
                                            by Biruslapio
                                            Bought this TV used not working, panel flashed briefly on power up and it was blinking 8 times, a quick look on SS board revealed a common fault on the 3uF 250V capacitors, C201 to C205 (C1620X in the service manual), the solder joints were all cracked, C201 and C205 pins were darkened and some sparking had occurred on them, C201 was split open and clearly overheated in its last hours, replaced that one and resoldered the others, 8 blinks fixed.
                                            Also the previous owner broke the antenna connector by taking the TV out of the wall mount forgetting to unplug it, I desoldered the tuner...
                                            04-13-2021, 07:13 AM
                                          • Userrrname
                                            Tx-pr42gt30 6 blink
                                            by Userrrname
                                            👋đŸģI recently got a tx-pr42gt30, I bought it in non-working condition. When I opened it, I saw that all the transistors and diodes had been removed from the tnpa5330, and several microcircuits were in poor condition, so I decided not to try to repair it. Instead, I bought another tnpa 5330 (also AB), which was already repaired (according to the seller, the board was repaired and worked before the screen was damaged), transistors were also changed on it, but Chinese copies were installed (there is no round hole in the middle, the inscription is easily erased) and a pair of transistors that...
                                            07-19-2025, 07:53 AM
