Samsung UN32EH4003 Power Cycling
  • jstiene
    • Feb 2013
    • 148
    Hello.
    I just received a Samsung UN32EH4003 TV. When I turn it on, it power cycles on and off. Screen comes on and then off, powers off, resets and starts again. This is the first time I have come across this. Has anyone else encountered this problem in a newer model TV? Trying to determine where to start troubleshooting this type of problem.
    Thanks!
    Joe
  • sordids999
    • May 2013
    • 2158
    • uk
    Re: Samsung UN32EH4003 Power Cycling
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • karem.elkayar
      • Jul 2016
      Originally posted by jstiene
      Hello.
      Thanks!
      Joe
      Dear Jstiene,
      I have the same problem with my samsung TV. how did you fix yours?
      best regards,
      Karem Elkayar
        Originally posted by karem.elkayar
        Dear Jstiene,
        best regards,
        Karem Elkayar
        Same make and model of the TV?
        If it is then you should upload good clear pictures showing all the boards and how they are connected together and go from there.
        • sintv
          • Feb 2015
          • 37
          • scotland
          Disconnect set from the network. A couple of times thr Samsung hub has went down and caused this same problem
          • mu2
            • Oct 2009
            • 217
            I think this is the same problem I had. Take a look at this post.
            https://www.badcaps.net/forum/showthread.php?t=40665
            If the cap is not bulged, remove and check the capacitance. I bet it will be very low.
            Mike
