Philips 47pfl5704d/f7 Added Pictures
  • kmab
    • Mar 2015
    • 16
    • usa
    Philips 47pfl5704d/f7 no picture, no sound, stnby light (1) long and (4) short blinks... Visual of power supply looked OK.. Any ideas ??... Also need service manual... thanks
    Re: Philips 47pfl5704d/f7 Added Pictures
    http://elektrotanya.com/?q=showresul...at2=schematics
    • CapLeaker
      Leaking Member
      • 8326
      another picture of the power supply where the CN4 and CN5 connectors are. So we can read the pin outs.
      • kmab
        • Mar 2015
        • 16
        • usa
        cn4 cn5
        -v audio analog/pwm dim
        gnd snd boost
        + v audio dim
        12.3 bl on/off
        12.3 gnd
        12.3 gnd
        gnd 12.3
        gnd 12.3
        gnd
        stby
        3v3 stby
        • CapLeaker
          Leaking Member
          • 8326
          First off what voltages are you getting on these pins.Use the pin out description with the voltage you measured beside it. We got to find out if the issue is on the main board itself or on the power supply. See what you get TV on vs TV off.
          • kmab
            • Mar 2015
            • 16
            • usa
            soon as tv is plugged in stby light starts flashing (1) long (4) short, No on/off..
            cn4
            -v audio, 0vdc
            gnd
            + v audio, 0vdc
            12.3, 0vdc
            12.3, 0vdc
            12.3, 0vdc
            gnd
            gnd
            gnd
            stby, 3.3vdc
            3v3 stby, 3.3vdc
            cn5
            analog/pwm dim, 0vdc
            boost, 0vdc
            dim, 0vdc
            bl on/off, 0vdc
            gnd
            gnd
            12.3, 0vdc
            12.3, 0vdc
            • CapLeaker
              Leaking Member
              • 8326
              With the ribbon cables disconnected on CN4 and 5, measure stby and 3.3V stby pins on CN4.
              After that you could "force" the PSU on using a two 1k ohm resistors. One from the standby voltage to PSon and the other from standby voltage to BLon. This should bring up all voltage rails and the backlight.
              I tried to DL that schematic, but everything is slower than molasses here today.
              • kmab
                • Mar 2015
                • 16
                • usa
                cn4 and cn5 cables disconnected, 3v3 stby=3.3.vdc and stby=2.6vdc
                Need clarification on 1k from stby to PSon... stby or 3v3 stby and which pin is PSon.. is this done with cables connected..
                • CapLeaker
                  Leaking Member
                  • 8326
                  3.3V Stndby = Standby power from PSU to main board.
                  Standby = PSon is from main board back to the PSU to tell the PSU to turn on. Same as the BLon. That comes from the main board and tells the PSU to turn the back light on.
                  • kmab
                    • Mar 2015
                    • 16
                    • usa
                    is this correct
                    1k from standby to 3.3v standby
                    1k from standby blon
                    cables disconnected
                    • kmab
                      • Mar 2015
                      • 16
                      • usa
                      CapLeaker - did you stop posting ???
                        "1k from standby (PS-ON) to 3.3v standby = OK
                        1k from standby blon = wrong, it is 1K between BL-ON and 3.3VSTBY.
                        • CapLeaker
                          Leaking Member
                          • 8326
                          Sorry... no... I guess the thread moved fast down and I am kind of busy with little crap that needs to be dealt with. Some days I have more time than others. Not easy having 4 kids home
                          I thought it was clear to use the 3.3V standby voltage, as I explained what the standby (PSon) does.
                          • kmab
                            • Mar 2015
                            • 16
                            • usa
                            thank you for your replies.. did not mean to have two threads on the same tv just my inexperience on this forum.. i apologize...
                            cn4 & cn5 disconnected at main board
                            1k from stby to 3.3v stby
                            1k from 3.3v stby to bl-on
                            back lights did not power on...
                            no 12.3vdc
                            stby= 3.3vdc
                            3.3v stby= 3.3vdc
                            • CapLeaker
                              Leaking Member
                              • 8326
                              O.k. I guess we have trouble with the PSU not firing up. I DLed the service manual on here, but for some reason I can't read it. Schematic is too blurry. I guess we got to find another one.
                              • CapLeaker
                                Leaking Member
                                • 8326
                                I found another service manual, but it didn't include the schematic for the PSU
                                Shopjimmy has had a repair kit for that board and they replaced following:
                                Transistors 5 Q101, 501, 601, 602, 603
                                Integrated Circuits 4 U101, 401, 501, 601
                                Diodes 3 D301, 601, 602
                                Capacitors 1 C102
                                Fuses 2 F101(37'), F101(47")
                                Gives you something to do.
                                • kmab
                                  • Mar 2015
                                  • 16
                                  • usa
                                  since we thought the ps may be bad did a little more experimenting.
                                  stby to gnd
                                  3.3 stby to bl-on
                                  Back lights ON
                                  12.5vdc where specified
                                  power supply good
                                  question - this would indicate main board bad...
                                  checked on shop jimmy and they state a new board needs configuring..
                                  what does configuring mean ???
                                  thanks
                                    So it is active LO for the PS-ON.
                                    Best is to ask SJ exactly what is involved to do the configuration.
                                    • CapLeaker
                                      Leaking Member
                                      • 8326
                                      Since the PSon is backwards in the power supply and it does fire up, I guess the problem is on the main board that controls the PSon. Maybe that transistor is bad that pulls the STBY or PSon to GND.
                                      What you could do is maybe to put the TV back together, take the PSon wire off the PSU (in order that it doesn't backfeed to the main board) and short the PSon pin from the PSU to GND. The TV should come alive.
                                      • kmab
                                        • Mar 2015
                                        • 16
                                        • usa
                                        Tried last suggestion: cn4 & cn5 reconnected, PSon (stby) to ground..
                                        led on front panel blinks four times and repeats tv does not power up..
                                        Guess we will look for a new main board, Shop Jimmy is out...
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • double_DD
                                          Philips curling iron - is this a common AC cable?
                                          by double_DD
                                          Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                          As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                          Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                          08-18-2025, 10:04 AM
                                        • janos6662000
                                          Philips 47PFS7509/12 LCD TV problem
                                          by janos6662000
                                          Hi
                                          I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                                          When i applied cable signal to check image, i had normal picture, but TV was restarting.
                                          I downloaded original firmware and applied the update, but the problem remained.
                                          From a colleague i received a "factory package software" which is a lot bigger.
                                          I made another firmware update, but still did not solve the problem.
                                          Somewhere on the way the error got worse, because at the moment the...
                                          08-12-2025, 12:54 PM
                                        • aidanmo
                                          Philips 43PUS7506/12 - Loud blown out sound
                                          by aidanmo
                                          I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                                          I thought maybe the speakers got damaged, so I replaced them - no dice.
                                          • Using the internal speakers, it always happens.
                                          • Using the headphone jack, it never happens.
                                          • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                                          02-28-2025, 03:13 PM
