Troubleshooting on TV components
  • engelwood39
    • Mar 2015
    • 93
    First off I want to say I am so happy I found this site and this is a wonderful utensil to assist and inform people like myself. I am new to this world and am very excited to learn more about component diagnostics.
    I am wanting to know what is a good multimeter for doing component level testing that has an affordable price point? Also I am fine buying used off EBAY and Amazon, thanks you in advance!
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Re: Troubleshooting on TV components
    I can't recommend any particular make or model, but certainly get one that has a good array of probes and crocodile clips. Components are getting so small these days.
    • Ijaz Ahmed
      • Dec 2013
      • 35
      • Pakistan
      I will recommend a used Fluke 79 or 77. I have been using these for years. They are excellent.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        Fluke 77 and 79 are both great choices.
        • retiredcaps
          • Apr 2010
          • 9271
          Define affordable? $10? $25? $50? $100?
          --- begin sig file ---
          --- end sig file ---
          • retiredcaps
            • Apr 2010
            • 9271
            The Fluke 77 and 79 are workhorses. Here are the positives and negatives.
            Positive
            - 2,000 hour battery life using 9V alkaline battery
            - simple, easy to use
            - likely within calibration after 20 or 25 years
            - reliable
            Negative
            - slow continuity speed
            - range switch could be a bit mushy depending on condition of meter
            - lacks features compared to its latest versions (like capacitance, min/max/average, etc)
            The 77 and 79 are good meters, but be careful not to overpay. $30 USD would be the max I would pay.
            • retiredcaps
              • Apr 2010
              • 9271
              Related post ...
              https://www.badcaps.net/forum/showpo...7&postcount=17
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8222
                Fluke is my first choice, Agilent my second.
                • engelwood39
                  • Mar 2015
                  • 93
                  Positive
                  - reliable
                  Negative
                  Affordable is very relative to the person, sorry for leaving out my price range. Also economically priced would have been a better way for me to state that. as far as the $30 range... I would consider that to be very good price wise. Thanks for all the input! this online community is awesome!
                  • Techie_hobby1
                    Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
                    by Techie_hobby1
                    Need some help please with a few components on this small board so that I can troubleshoot the circuit.
                    The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
                    J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
                    J2 - to DC Output
                    J3 is Battery cell connector
                    however I am struggling to identify if:
                    Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's....
                    07-24-2025, 12:43 PM
                  • User2025
                    Please help to identify the components on Surface Laptop GO3, model 2013, i5-1230U
                    by User2025
                    I am working on a Surface Laptop GO 3, which is the new release 2024 with a i5-1230U processor. Originally, it had a 256GB SSD, then the owner attempted to upgrade it to 1TB SSD by himself. "Surprisingly", it did not boot afterwards, then changed back to the original SSD, did not boot either.
                    It turned out to be that just a couple of components had been knocked off when the owner was trying to get off the SSD cover with his beloved screw driver.
                    I do not have another board of same model. Although I have a Laptop Go 2, the layout of that bit...
                    04-29-2025, 04:13 PM
                  • Endlessmist
                    Surface Pro 4 - need help with some messed up components
                    by Endlessmist
                    Hi everyone
                    Here is the case that i'm trying to solve.
                    (short intro to explain what happened)
                    I bought second hand Surface Pro 4 and when I tried to reinstall the Windows it appeared there was the password on UEFI. Seller don't reply anymore. I decided to reflash the UEFI chip to remove the password. So I need to remove the chip from the motherboard first.
                    I have basic experience of repair tablets and phones, like battery or display change. So i opened the Surface Pro 4 and removed the motherboard successfully.
                    (the...
                    04-22-2023, 07:30 AM
                  • Sam Scarbo
                    Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
                    by Sam Scarbo
                    My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
                    I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
                    If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
                    See the attached two pictures of the small...
                    09-18-2024, 08:29 AM
                  • summerwhite
                    DJI Mini Pro 3 missing components near camera connector
                    by summerwhite
                    I have a DJI drone that is not displaying a video feed anymore after a repair.
                    When tearing down the DJI drone to fix the armature there was some hot glue next to the camera connector that i had to remove.
                    Now there are missing components either because they got pulled off or because they where never placed.
                    I have two reference images from XXZ and a photo of mine.
                    I'm truely hoping someone has another DJI Mini Pro 3 that they can help me identify what these components are and if they are necessary.
                    On the board view from XXZ they...
                    04-06-2025, 11:15 PM
