Help please with identification of few components for troubleshooting (Solar Water Fountain circuit)
  • Techie_hobby1
    • Feb 2023
    • 64
    • England
    Need some help please with a few components on this small board so that I can troubleshoot the circuit.
    The PCB is a Single sided board fairly simple circuitry has a +ve and -ve Solar cell power input, a 7.4v 1500mAh (dual 18630 cell) power in which the Solar panel charges the cells, and lastly the Output goes to a DC connector...
    J1 is actually 1P1T Switch (in ON position completes Battery cell circuit
    J2 - to DC Output
    J3 is Battery cell connector
    however I am struggling to identify if:
    Y1 (SOT-23) are NPN Transistors, MOSFET's or 11v Zener's. I am fairly sure they are NPN Transistors though because I get a 0.6v diode reading on Collector and Emitter with +ve on Base.
    Same for Y2 (SOT-23) being PNP with -ve on Base and 0.6v on Collector and Emitter.
    The 8 pin IC is a little odd though but with no markings is making it a lot harder.
    If I am incorrect with any of the above please can you advise further
    Many thanks
  • truclacicr
    • Apr 2019
    • 357
    • australia
    Y1 = SS8050.
    https://www.google.com/search?imgtyp...Cisz%3Am&udm=2
    Y2 = SS8550.
    To identify the IC, you would need to identify its pinout.
    https://ipv4.google.com/search?q=fil...8%20OR%20soic8
      • 31316
      the switch has fractured soldering
      • Techie_hobby1
        • Feb 2023
        • 64
        • England
        truclacicr
        Thanks as always. I think sometimes I over think it in regard to the component searching, and try to use the sites that let you search by the Marking code, instead of trying to do a standard google image search first.
        In regard to the IC 8pin SOIC connections are as follows ( I think it is just 555 timer chip - but just want some clarification please):
        Pins are as follows:
        Pin 1 connected to Cathode of D1 diode and bridged with pin 4
        Pin 4 goes to collector of PNP (Q3) transistor via current limiting resistor
        Pin 2 goes to collector of NPN (Q4)and also to collector of NPN (Q1)
        Pin 8 goes to Anode of the same D1 diode, to DC positive
        • Techie_hobby1
          • Feb 2023
          • 64
          • England
          stj
          Thank you for pointing that out. I actually didn't see that one. I think I managed to locate a few that were broken/cracked.. and still going through them slowly
          • Techie_hobby1
            • Feb 2023
            • 64
            • England
            truclacicr
            whoops I forgot to include pin 7 of the IC, which connects to the base of NPN Q5 transistor
            • Techie_hobby1
              • Feb 2023
              • 64
              • England
              truclacicr
              Now I am really baffled.. I have just realised it does not have any connection to pin 3 (Ouput) so can't be a 555 timer can it
                • 31316
                the chipis probably a 2cell lithium charger or a microcontroller.
                • Techie_hobby1
                  • Feb 2023
                  • 64
                  • England
                  stl truclacicr
                  Very quickly hand drawn a schematic - could have switched a few things around but think you get the jist
                  • Techie_hobby1
                    • Feb 2023
                    • 64
                    • England
                    stjtruclacicr
                    im still having a few difficulties with this circuit.
                    i have tried reaching to other sites but they too are not coming back with anything useful.
                    i swapped out the battery pack for 2 x 3500mAh cells and it seemed to work for about a week, but now it seems like they are not charging.
                    How would be a good way to test that these are actually charging with the sun???
                    Regarding that 8 pin IC..still unsure what it is and how I can identify it???
                    • truclacicr
                      • Apr 2019
                      • 357
                      • australia
                      The circuit diagram is busting my brain. I presume that DC+ and DC- are the terminals of a pump motor, in which case it makes no sense to connect Q5 as in your circuit. Instead, it would make more sense to connect the emitter to ground.
                      Another problem is the absence of a path for the charging current from Solar+ to Bat+ via the IC. How is the battery being charged?
                      I can't understand what D1 is doing.
                        • 31316
                        when the battery switch is on, the solar panel is connected to the battery through a series of resistors.
                        so for it to work you need either NiMH batteries or the lithiums need a protection-board.
                        because it has no charge control - it just pumps power to the cells till the sun goes down!
                        NiMH also will last longer outside - Lithium wont like getting baked in the day and frozen at night.
                        thats why solar lights are NiMH based.
                        • truclacicr
                          • Apr 2019
                          • 357
                          • australia
                          AFAICS, those resistors are too large for any charging current. Instead, they appear to be bias resistors.
                          • Techie_hobby1
                            • Feb 2023
                            • 64
                            • England
                            truclacicr Yes that is correct, the DC + & DC- are what the pump motor connects to.
                            truclacicr stj - so am I right in thinking that these Batteries don't actually charge up at all??
                            Ideally this circuit needs altering so that it can charge the batteries during the sunlight, and then once charged when sunlight switches to sunset have the batteries take over and power the circuit for as long as they can.
                            stj - re NiMh cells, do they require a BMS like Li-Ion cells require.
                            So we are still unsure what the IC is.. I took a look at some of the links that Truclaclcr identified, and there is 1 possible match being the CN3302 but I am struggling to work out if this matches the circuit that I have?
                            • Techie_hobby1
                              • Feb 2023
                              • 64
                              • England
                              truclacicr stj
                              I stand corrected it is definitely not a CN3302 because after looking at the typical applications it mentions MOSFET's in the design which we know these are NPN and PNP transistors and GND is Pin 4 on this IC
                              I have had to put this one aside for a few days as I have been given something else to take a look at..but would really be grateful of any further assistance. I have been searching through those IC's and none of the pin configurations seem to match up
                              I had a light bulb moment where I thought the IC might just have been a Boost Regulator which can be used in Solar Charging (CE6370 series) but again pin config does not completely match up.
                              Ground in definitely PIN 1 as it take its Ground signal through D1 diode which originally takes its GND from Solar Panel -ve
                              Apart from that all the other IC's have GND on PIN 4 that I have come across
                              • truclacicr
                                • Apr 2019
                                • 357
                                • australia
                                The batteries must be charged by the panel ... somehow. However, there is something missing from your circuit.
                                Measure the battery voltage in the dark, then do the same in bright sunlight. Alternatively, disconnect the battery and see whether the IC is getting any supply voltage from the panel.
                                Disconnect the panel and measure the battery voltage at the IC. This will tell you which ICs pins are connected to the panel and to the battery
                                • Techie_hobby1
                                  • Feb 2023
                                  • 64
                                  • England
                                  truclacicr stj Thank you so much, this will give me a better understanding of what is going on with this circuit..
                                  I will also take some time to go back (trace back) all the traces, connections and components to ensure that I have not made a silly error.. this will hopefully rule out any head scratching from both yours STJ's and anyone else who is looking at this.
                                  I think I might have rushed this one a little too quickly in the hope that I could have fixed it quickly for my friend.
                                  She has been without the solar fountain for some time now so I might take some more measurements and photos (many close up) but return it back to her (also give your heads a bit of a break from it) and just have it so it runs without the battery backup for now (then when the weather dips again, disconnect it from her fence and take another look at it)...
                                  Needless to say this is not over and not a finished repair just yet... and TO BE CONTINUED!!!! haha
                                    • Jul 2011
                                    • 6070
                                    There is something not quite right about the circuit and being hooked to lithium ion battery because there should be a sensing wire should be between the two battery cells or this nothing but a voltage monitoring ic chip have you looked up the ic chip that it connects to the battery cells
                                    I agree with STJ in post number 12 about how he thinks this device works
                                      20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
                                      I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
                                      At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
                                      Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
                                      04-09-2023, 08:04 PM
                                    • Astonished
                                      Fixing the Charge Circuit of the Batteries of the DC Motor
                                      by Astonished
                                      Hi friends of electronics
                                      What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                      The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                      Please help me fix this circuit.
                                      (the datasheet of the IC: https://pdf.datasheet.live/28...
                                      01-28-2025, 06:24 AM
                                    • Smilz
                                      M2 Mac mini (820-07529-07) Circuit ID Help
                                      by Smilz
                                      Hey all,
                                      this is my first post on this site.
                                      I just got my hands on a M2 Mac mini (Board Number 820-07529-07) that was described as "no power/logic board defective". As I just got into microsoldering I thought that's a great way to practice my skills under the microscope.
                                      However, this board Clearly has been worked on before and as there are no schematics for the Mac minis (AFAIK) I need some help figuring out what that circuit does.
                                      I already ordered a iCloud locked donor board to swap the parts, but some more information about that part of the board would be...
                                      12-03-2025, 11:01 AM
                                    • Tarot Superstars
                                      Short Circuit tester
                                      by Tarot Superstars
                                      Hello.
                                      I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                      The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                      Link
                                      The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                      https://www.youtube.com/watch?v=0eixDdCpiO4
                                      My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                      09-25-2023, 09:11 AM
                                    • Ugur87
                                      MacBook Air M4 A3240 Brand New Water Damage no Image
                                      by Ugur87
                                      I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                                      08-28-2025, 01:09 PM
