Sparkle 1200W PSU MAGNA Model: SPM1200AXJ8 - Broken. Need help identifying components. Any schematics available?
  • Sam Scarbo
    • Oct 2023
    • 38
    My Sparkle (SPI) PC power supply has broken. Originally, there was totally no power output. The 5V-standby was not there. I have replaced a few bulged capacitors but not helping.
    I was trying to do more troubleshooting but burned more components. Some got burned so badly that the markings were gone. And also, the markings of a few transistors were gone because the component surface was worn out somehow.
    If you happened to have disassembled the same PSU model, please help to provide the markings of some of these components.
    See the attached two pictures of the small circuit board (which was soldered to the main board). The components circled in red are the ones that I need help identifying the markings (1 resistor and 9 transistors).
    If you have schematics/service manual for this model or a similar model to provide, that will be useful!
    At this point, I am not sure if I will order the components to attempt fixing it. The chip UCC28512DW is burned. Not sure if it was damaged originally or not, but it got burned more while i played with troubleshooting it, and some more other components, including 1 power transistor.
    Since there are quite a few damaged components, and i don't know which other components need replacement, I am in the process of evaluating whether I should continue to work on it or not. I don't feel confident that I can fix it. It is a waste to throw it away though.
    Thank you!
  • chth96
    Is it possible bridging tiny broken trace
    by chth96
    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
    cutting tiny trace.
    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
    12-03-2022, 11:32 PM
  • ArchangelGabriel
    Aorus 17G YD laptop, broken display, could not switch to external monitor
    by ArchangelGabriel
    Hello guys! I need a little help, I have one laptop for repair, it is an Aorus 17G YD, gaming laptop. Broken display, some cable ripped form daughter board connector, case broken, battery discharged and probably locked, etc. After I did the most tedious job I ever did on soldering back the broken cables (shielded cable) , I measured resistance on CPU and GPU core, 3 and 5 v ps and any coils I find on the board, everything seems to be fine. After I plugged the charger I don't get the power led light on from the charger connection maybe because the battery is locked , but on power button I have
    11-23-2023, 03:55 AM
  • corrize
    Resonator - quartz broken - how to find the same (same frequency) ?
    by corrize
    Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
    I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
    I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
    I'm searching another one for compare…
    Do you have an idea or another way for find the frequency of this resonator please ?
    (I did not found the manufacturer of this component ? And I did not found the...
    03-27-2025, 09:20 PM
  • emeskay
    Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
    by emeskay
    We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
    08-06-2024, 07:13 AM
  • AustinCER
    Need Help Identifying this LCD FPC for Dell G3 15 3590 Gaming Laptop
    by AustinCER
    I am in search for some help in identifying the LCD FPC. It is a connector for a plug-able eDP cable.
    Attached is a photo of the FPC.
    Model: Dell G3 15 3590 Gaming Laptop
    ST: 79QYJT2
    Thank you very much in advanced....
    11-03-2025, 02:55 PM
