Philips 40PFL5605
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Philips 40PFL5605
    Hi, my 40PFL5605H/05 TV does not power on properly.
    The 3.3VDC comes on and stays on.
    The 12VDC then ramps up and stays on for about a second but then goes off again.
    The 12VDC does this three times in sequence. Then stops.
    Finally the red LED on the front flashes twice, stays off for a few seconds and then repeats.
    All the fuses I have been able to find look ok.
    The PSU board is a DPS-206CP.
    The main board is labelled twice as a:
    3104 313 64003
    3104 328 63141
    I haven't been able to find a circuit for the PSU. Any ideas on this?
    I've downloaded some comprehensive manuals but they don't seem to contain a circuit for the PSU board or a description of the fault indicated by the flashing LED.
    Anybody know where I might get a list of faults associated with the flashing LED? Or any other ideas?
    Thanks!
    Hab-cat.
  • habanerocat
    • Nov 2014
    • 96
    • Ireland
    Re: Philips 40PFL5605
    Any pointers on this one lads?
    Could do with some help.
    Thanks!
    • thoma
      • Sep 2012
      • 268
      40PFL5605/67 Philips LCD TV 40PFL5605 102 cm (40") Full HD 1080p with Pixel Plus HD
      2 40PFL5605/93 Philips LCD TV 40PFL5605 102 cm (40") Full HD 1080p with Pixel Plus HD
      3 40PFL5605/98 Philips LED TV 40PFL5605 102 cm (40") Full HD 1080p with Pixel Plus HD
      4 40PFL5605D/77 Philips LCD TV 40PFL5605D 102 cm (40") Full HD 1080p digital TV with Pixel Plus HD
      5 40PFL5605D/78 Philips LCD TV 40PFL5605D 102 cm (40") Full HD 1080p digital TV with Pixel Plus HD
      6 40PFL5605H/05 Philips LED TV 40PFL5605H 102 cm (40") Full HD 1080p digital TV with Pixel Plus HD
      7 40PFL5605H/12B 40PFL5605H/12B
      8 40PFL5605H/12 Philips LED-Fernseher 40PFL5605H 102 cm (40") digitaler Fernseher, Full HD 1080p mit Pixel Plus HD
      9 40PFL5605K/02 Philips LCD-Fernseher 40PFL5605K 102 cm (40"), Full HD 1080p, DVB-T/C/S2 mit Pixel Plus HD
      10 40PFL5605M/08 Philips LCD TV 40PFL5605M 102 cm (40") Full HD 1080p digital TV with Pixel Plus HD
      11 40PFL5605S/98 Philips LCD TV 40PFL5605S 102 cm (40") Full HD 1080p with Pixel Plus HD
      12 40PFL5605Y/93 Philips LCD TV 40PFL5605Y 102 cm (40") Full HD 1080p with Pixel Plus HD
      13 40PFL5605Y/98
      • thoma
        • Sep 2012
        • 268
        Tell me exactly which one of these do you have then i can tell you the chassisnumber of the lcd tv because there are a lot different one
        and then we search the right schematic!
        regards thoma!
          Pictures of the model number sticker with chassis number, and pictures of the whole back side of the TV, the boards (especially the power supply board top and bottom sides) will help.
          Is this your board?
          http://mcsimple.com/index.php/taobao...id/39269016760
          Since it is made by the OEM so I doubt that Philips will publish the schematic for the power supply made by DELTA.
          • habanerocat
            • Nov 2014
            • 96
            • Ireland
            13 40PFL5605Y/98
            This is mine. Thanks.
            • habanerocat
              • Nov 2014
              • 96
              • Ireland
              Is this your board?
              Yes, that looks like my board.
              Here are some pictures.
              • habanerocat
                • Nov 2014
                • 96
                • Ireland
                I'm a bit lost on the chassis number to be honest.
                Other info on the back of the TV is:
                40PFL5605H/05
                SN 1A1017 003313
                Display 932227618682
                Sharp LK400D3GA43U
                B1143
                The manual I downloaded which looks close says the chassis is a:
                Q552.1E
                LA
                But nothing like that on the TV.
                Does the DC voltages pulsing on and off three times as stated above tell us anything?
                Thanks!
                  "Does the DC voltages pulsing on and off three times as stated above tell us anything?" I will have to trace out the circuit on the board to see how 12V is generated.
                  Please give me the list pin names of those two white connectors on the power supply board that go to the main board.
                  • habanerocat
                    • Nov 2014
                    • 96
                    • Ireland
                    1M95 (B03C)
                    1. +3V3-STANDBY
                    2. STANDBY
                    3. GND
                    4. GND
                    5. GND
                    6. +12V
                    7. +12V
                    8. +12V
                    9. +24V-AUDIO-POWER
                    10. GND-AUDIO
                    11. MAINS-OK
                    1M99 (B03C)
                    1. +12VD
                    2. +12VD
                    3. GND
                    4. GND
                    5. LAMP-ON
                    6. BACKLIGHT-PWM_BL-VS
                    7. BACKLIGHT-BOOST
                    8. BACKLIGHT-PWM-ANA-DISP
                    9. POWER-OK
                    Pretty sure that is correct above (it's from the manual)
                    The 24VDC pulses with the 12VDC. The 3.3VDC stays on.
                      OK, the #2 STANDBY (same function as PS-ON), check DCV of the pin when TV is OFF and when power switch is activated, see if it change state when power switch is activated and when the 12V goes back down by itself.
                      Most TV PS-ON signal will be <1V when TV is OFF, and >2.5V when power switch is activated and stays at that level until TV is turned off, that is called ACTIVE HIGH.
                      • habanerocat
                        • Nov 2014
                        • 96
                        • Ireland
                        Hi, thanks for your help.
                        The #2 Standby also pulses at mains-on between 0-3.26V.
                        It gives an initial quick pulse and then pulses the inverse of the 12VDC and the 24VDC. So when the 12V is on the 3.26V is off. Finally it stays on and the LED flashes.
                        • habanerocat
                          • Nov 2014
                          • 96
                          • Ireland
                          Just bumping this back up in the hope of a reply.
                          Gets busy here on the weekends!
                          • habanerocat
                            • Nov 2014
                            • 96
                            • Ireland
                            I managed to find the below from a Philips manual.
                            PNX doesn't boot (HW cause) 2 15 Stby μP P BL PNX8550 SSB
                            This basically says that the main SSB board is faulty with a processor hardware problem, stopping the SSB from booting up.
                            So unless somebody can explain otherwise, it looks like I have a dead processor board.
                            If I buy a new board (where is best?) is it probable that I'll get this TV up and running again? Or could there be other problems?
                            • habanerocat
                              • Nov 2014
                              • 96
                              • Ireland
                              Hi, I managed to replace the main board.
                              TV now powers on fine but the image overlaps as shown in the picture.
                              As you can see this problem is common for onscreen menus and external video.
                              Was my replacement board incorrect or is there something else I need to do to fix this?
                              Thanks.
                                It looks like the main board is not compatible with the panel, did you get the same board version and same P/N?
                                May be TOM66 can chime in on how to get into service made to change the setting.
                                • habanerocat
                                  • Nov 2014
                                  • 96
                                  • Ireland
                                  Thanks for your reply.
                                  I went into the service menu. The only relevant option I saw was TCON alignment, which is set at 0109.
                                  I tried to change it but it made no difference.
                                  Does anybody know what this is, or how to fix my problem.
                                  Thanks.
                                    No great suggestions here I'm afraid. I would guess your ordered board is incompatible.
                                    • kca
                                      • Feb 2016
                                      • 548
                                      Did you ever run across information stating the need to use the Options Code and the Screen Diversity code to configure your SSB? I think that was the necessary step you were searching for.
                                      Wondering if you were able to fix the picture and get this Philips set up and running properly.
                                      • kata40
                                        • Jan 2017
                                        • România
                                        13 40PFL5605Y/98
                                        Hy, i have a problem wit my digital board, at Philips 40PFL5507k/12
                                        the hdmi dont work, maybe are burn.
                                        can you help me to do somethink to work?
                                        • Sharpa
                                          Repair attempt Philips 55OLED804/12
                                          by Sharpa
                                          I bought a SH Philips 55OLED804/12 TV with known defect in an attempt to repair it for personal use.
                                          The symptoms when bought: Philips logo appears then tv turns off
                                          Things tried so far:
                                          1. Powering it on: Philips logo shows on the screen, sometimes with some minor artefacts then shuts down. Red status led flickers rapidly into two batches then repeats
                                          2. Put it in recovery mode by pressing joystick down then plugging it to mains: The tv shows the logo then shows the android animation along with some minor artefacts on the screen...
                                          Today, 08:30 AM
                                        • alro7779
                                          Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                          by alro7779
                                          Hello, guys!
                                          The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                          09-14-2025, 12:25 AM
                                        • G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                          by G33RT
                                          Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                          It does power up when pressing the power button.
                                          I already try the power button while plugin the plug with no result.
                                          Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                          Could this be an PSU or eMMC issue ?
                                          07-19-2025, 03:43 AM
                                        • rumi409
                                          LG OLED C1 Pixel Cleaning Made Picture Worse
                                          by rumi409
                                          ​​​​​​ Hi,
                                          I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                                          11-15-2024, 01:09 AM
                                          HP Z6 G4 3104 Specification for Upgrade or Repair
                                          This specification for the HP Z6 G4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z6 G4 boardview and Z6 G4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP Z6 G4 is accurate, safe, error...
                                          09-12-2024, 02:15 PM
