LG RZ-27LZ55 momentary backlight
  • zx81
    • Mar 2014
    • 118
    Hi Guys please could you help me out with this LG RZ-27LZ55
    When I power the set up I get the backlight to come on it will stay on for 5-6 seconds sometime it only comes on for a second or so then shut down the set again.
    I have tested the voltages I am getting 24v showing around 18v then the voltage drops down to zero while I'm reading. Same with the 33v. Standby and 12v are present.
    Sound is also present
    Pics attached
    zx81
  • zx81
    • Mar 2014
    • 118
    Re: LG RZ-27LZ55 momentary backlight
    Any pointers as to where to start would be very much appreciated guy.
    • zx81
      • Mar 2014
      • 118
      Can anyone suggest where to start with this could it be an inverter issue that's pulling the voltage down and shutting down the power supply or should I investigate the power suppy ?
      Any pointers would be very much appreciated.
      Cheers
      zx81
      • CapLeaker
        Leaking Member
        • 7985
        Disconnect the main board from the PSU, then force the PSU on with the back lights connected. Use a 1k ohm resistor from STBY voltage to PSON, and another 1k resistor from 5v to BLon. See what you get.
        • zx81
          • Mar 2014
          • 118
          Thanks for the reply CapLeaker will try that out and post my results.
          • zx81
            • Mar 2014
            • 118
            CapLeaker can I forgo the resistors and just short out the connections suggested?
            Sorry for the newb question. Pretty much starting out and have loads to learn.
            Does the power supply need to see a load and that's why we need to use the resistors?
            Will the resistors be a dummy load?
            zx81
              The forced on resistor is for current limiting incase there is shorted circuit, the current be limited to 5V/1000 Ohms = 5mA not enough to damage anything. If you slip on that 5V wire and accidentally connect to the wrong pin, or shorted pin, or chassis, you can damage the power supply.
              It is not dummy load resistor.
              And when you do the force on, you MUST disconnect those cables (the PS-ON, BL-ON) going back to the main board FIRST.
              • zx81
                • Mar 2014
                • 118
                Thanks for the explanation budm.
                • zx81
                  • Mar 2014
                  • 118
                  Hi Guys,
                  I've just uploaded some close up pictures of the connectors on the power supply and a connector going to the main board. The connectors have different labelling compared to Capseek's instructions. No STBY or PSON labels. Would someone be kind enough to point out which points I should connect the 1k resistors in my particular case? I will be removing the main board connector and use that side of the connecters to push the resistors into. Is it ok to do so?
                  Does the wattage of the resistors matter ? I don't have any !k resistors and will have to pick some up locally.
                  Why does the power supply have 33v ? is it really 33v or is it 3.3v.
                    PWR-CTL (Power Control) = PS-ON (Power supply ON)
                    INV-CTL (Inverter Control) = BL-ON (Backlights ON)
                    INV-BRI (Backlights Brightness) = Backlights Dimming Controll, Note: there is no indication to tell us if it is PWM-Dimmimg (Pulse Width Modulation) or A-Dimming (Analog)
                    • zx81
                      • Mar 2014
                      • 118
                      Thanks Bud.
                      Any idea what the 33v is used for or am I reading it incorrectly is it 3.3v?
                      I am picking up some 1k resistors tomorrow is wattage anything I should look out for will 0.5-0.6watt be okay?
                        The 33V may be for the electronic tuner, if it is 3.3V it would have been labeled with 3V3 not 3.3 since sometime the DOT can be hard to see.
                        1/4W is more than big enough, just be sure to remove the wire/s going back to the main board before forcing on since we do not want to back feed the force on signal back to the main board.
                        • zx81
                          • Mar 2014
                          • 118
                          Got it.
                          Will pick up some resistors tomorrow and report back with my findings.
                          Cheers.
                          • zx81
                            • Mar 2014
                            • 118
                            I have got a couple of resistors ready to go now. But I am confused where my standby is.
                            The connector does not show Stby? Or 5v stby.
                            There is another connector on the main board that shows ST 5V if I follow that connector back to the power supply it goes to an area near the primary side of the power supply where there is an IR jack and rs232 port. There is a printed white divider line that may be indicating that it is on the cold side of the power supply.
                            I'm a little confused and thought it best to seek advice before I blow anything up.
                            • zx81
                              • Mar 2014
                              • 118
                              Hi guys can anyone offer any advice on the correct connection points to put the resistors?
                                OK, before doing the force on, we need the pictures of the whole back side of the TV.
                                I see that it has read connector and white connector with 24V and inv control lines, also other two connectors with PWR-CTL and PWR2, so I need to see which connector goes to the main board and which connector is not used.
                                  https://www.badcaps.net/forum/attach...5&d=1426004736
                                  Is this the connector on the power supply board or on the main board?
                                  If is on the main board then what DCV do get on all those pin when TV is OFF and when power switch is activated?
                                  • zx81
                                    • Mar 2014
                                    • 118
                                    I will upload better pics tomorrow.
                                    I'll do some photoshop work to make a very high quality flat/evenly lit pic to upload that will show everything clearly. Until then I'll hold off trying the force on.
                                    • zx81
                                      • Mar 2014
                                      • 118
                                      Hi Bud I'm away from the set right now. I'll update this thread tomorrow with the info you've requested and a real high resolution pic of the whole main board and power supply. I may put some overlays in photoshop to help show things more clearly.
                                        OK, just make sure to give me the Voltage readings on those pins, thanks.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • cheebster
                                          iPad Pro 12.9 5th Gen Backlight Issue
                                          by cheebster
                                          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
                                          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
                                          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
                                          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
                                          Anyone...
                                          05-20-2025, 09:17 AM
                                        • canadaboy25
                                          LG Flatron 24EN33TA No Backlight When Cold
                                          by canadaboy25
                                          I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
                                          I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
                                          03-07-2023, 12:23 AM
