Toshiba 47tl5154 no image just backlight
  • ricosavy
    • Jul 2012
    • 457
    • united states
    I have a toshiba led tv that will turn on and have a backlight but no image. How can i test it to see if my tcon board is bad or if i have a bad main board.any input is appreciated thanks.
  • ricosavy
    • Jul 2012
    • 457
    • united states
    Re: Toshiba 47tl5154 no image just backlight
    Here pic board
    • ricosavy
      • Jul 2012
      • 457
      • united states
      Here pic power supply
      • ricosavy
        • Jul 2012
        • 457
        • united states
        Tcon board
        • CapLeaker
          Leaking Member
          • 8180
          Pretty easy to check with an oscilloscope the LVDS, while turning on and off the menu on the TV all the time.
            At least check and see if the main board is supplying the Voltage to run the T-CON.
            • ricosavy
              • Jul 2012
              • 457
              • united states
              I seen 12volts on the tcon fuse(budm)
              I dont have a oscilloscope that is can go to 100mhz just one that can do 20mhz not high enough.In future i will purchase one for now i can only check voltages(capleaker)
              • ricosavy
                • Jul 2012
                • 457
                • united states
                i replaced the tcon board still just getting backlight but no image on tv any ideas what to check
                • Peter Chiu
                  Banned
                  • Dec 2012
                  • 145
                  If you didn't see any LVDS signal on scope,open the LED screen penal....... U will find water stain (on one or two green boards with tab connect to LCD screen) clean with tooth brush and acetone .One of my friend DID change resistor and fuse and fix the TV.
                  Most-likely you have is Toshiba 47TL515U LED TV and you definitely need is the Main Board 75023298. ......
                  Pls give us a feedback, if you fix the TV......Good luck......
                    The OP does not have the scope.
                    "I seen 12volts on the tcon fuse(budm)
                    I dont have a oscilloscope that is can go to 100mhz just one that can do 20mhz not high enough.In future i will purchase one for now i can only check voltages(capleaker)"
                    • Peter Chiu
                      Banned
                      • Dec 2012
                      • 145
                      My Mexican friend (Jose Perez) teach me, put LVDS cable on the tongue and you can feel the signal....... But don't try at home ........
                      Next project 1: I will make LVDS tester in the future.
                      Next project 2: LVDS to VGA converter ,LVDS signal on your computer monitor.
                      • CapLeaker
                        Leaking Member
                        • 8180
                        [QUOTE=Peter Chiu;547915]My Mexican friend (Jose Perez) teach me, put LVDS cable on the tongue and you can feel the signal....... But don't try at home ........
                        QUOTE]
                        I am guessing that's how your friend checks the main filter cap on the power supply to see if the PFC is working or not...
                          He must have very sensitive tongue to detect 350mV! or just B.S.
                          From SONY T-CON info:
                          The LVDS transmitter contains a circuit to serialize the parallel data. The parallel video information along with
                          sync and clocking data are transmitted via twisted line pairs. Depending on the logic level, current is sent along
                          one or the other of the twisted pair of wires. The receiving end of the wires is loaded with a resistor (usually
                          around 100 to 120 ohms). The receiver detects the polarity of the voltage drop across the resistor to determine
                          the logic level. The current level swings in the wire are about 3ma with a voltage differential of around 350mv.
                          This allows for transmission of the video signal with minimal EMI.
                          "Next project 2: LVDS to VGA converter ,LVDS signal on your computer monitor."
                          http://www.ebay.com/itm/like/2213100...lpid=82&chn=ps
                          • Peter Chiu
                            Banned
                            • Dec 2012
                            • 145
                            I also heard people says {My father used have a TV repair shop , he fix TV with screw driver.}........more than one people said that ...........(CRT TV has 30 kV )....This is a murder.....
                            I could never understand........
                            • ricosavy
                              • Jul 2012
                              • 457
                              • united states
                              I have replaced the main board ,and tcon board still same problem no image just backlight.any ideas
                              • CapLeaker
                                Leaking Member
                                • 8180
                                bad panel?
                                • Hamie
                                  • Apr 2014
                                  • 1383
                                  If you remove one ribbon from the tcon do you get anything?
                                  Then reverse the process.
                                  • ricosavy
                                    • Jul 2012
                                    • 457
                                    • united states
                                    I will try it
                                    • ricosavy
                                      • Jul 2012
                                      • 457
                                      • united states
                                      Ok discounted the right side the left was dark no backlight the right had back light then disconnected the left side had back light all the tv and could see some line on right side
                                      • CapLeaker
                                        Leaking Member
                                        • 8180
                                        Is that model number correct? 47tl5154
                                        I can't find a thing about it. So recheck. I see that there is another ribbon cable between the inverter and the t-con.
                                        • Salem Aboshala
                                          820-00138-A got image but no backlight
                                          by Salem Aboshala
                                          Dears, this is my first post here and first try to fix my own laptop Apple MacBook Pro Retina 15-inch Mid 2015.
                                          I have some general electronics troubleshooting experience and still as my hoppy but this is my first laptop trying to fix.
                                          History: my laptop backlight stopped working without any reason.
                                          Symptoms:
                                          I have image on screen using my flashlight.
                                          I have fully working laptop with the help of my external SAMSUNG LED tv via HDMI cable.
                                          Keyboard backlight still working and can be adjusted normally.
                                          Since two days I tried to follow all similar...
                                          06-11-2024, 03:02 PM
                                        • zaurus81
                                          Yashi All in one model AY62409 (Quantum S 24'') no image (backlight works)
                                          by zaurus81
                                          This chinese all in one computer gives an image when connected to an external vga monitor but only the backlight with integrated monitor (no image). Initially I thought it was an edid problem on the eeprom of the screen but then I saw that the monitor works correctly with another identical motherboard (model th410-d4, read by bios). Unfortunately the motherboard is chinese and has no brand or codes on the pcb. The format seems ITX. Nothing can be found online. The official yashi site provides drivers but not the bios. The electrical diagram is obviously unobtainable
                                          The board is equipped...
                                          01-16-2025, 03:54 AM
                                        • Constantinos
                                          Macbook Pro A2442 820-02098 No image but has backlight
                                          by Constantinos
                                          Hi all
                                          I have a Macbook Pro A2442 with the 820-02098 from a friend which has no picture on the display, however, the backlight works.
                                          He was streaming a football match on a questionable site, then the site crashed, and the problem emerged.
                                          Initially, he sent it to apple, who quoted him £1323.95 to replace the display, lid angle sensor and top case.
                                          Obviously, he decided against this and gave it to me so that I could have a crack at it.
                                          From initial diagnostics, I connected to an external monitor, I first tried with a HP 22W monitor, and I booted into the boot menu...
                                          08-24-2024, 09:48 AM
                                        • ajgae
                                          HP Pavillon x360 14-ba174nz no image no backlight, LCD_VCC low (2.25V)
                                          by ajgae
                                          Hi everyone!
                                          First post on here so do tell me if i'm doing anything wrong. I have a laptop that came in with a broken hinge, but a healthy LCD. We replaced the LCD rear cover and now we do not get an image on the LCD anymore, though we get one via HDMI. There is sadly no schematic or boardview available for this motherboard (Bucks U42 DIS 17817-1) as far as i can tell, but I was able to identify which of the important pins on the LCD eDP connector (30 pin 2 lane) correspond to which pins on the motherboard display connector (which is 40pin, 30 for LCD and 10 for camera/face rec etc)...
                                          03-06-2025, 09:53 AM
                                        • learnmore
                                          Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
                                          by learnmore
                                          Hello Community!
                                          CASE DETAILS
                                          Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
                                          13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
                                          Tried inserting firmware on USB and left it in for a few hours, but no change
                                          03-03-2024, 09:49 AM
