Vizio e470va No Picture
Re: Vizio e470va No Picture
Good, so check and see if you do have 24V feeding the inverter board and 12V feeeding the main board, if not, remove the cables to the inverter board and check again to see if the 12V/24V are present.Never stop learning
23.9v at the connector on the inverter board and 12.10v/23.9v at the connector on the main board.Comment
OK, now we need good clear pictures of the inverter board without the metal shield, you need to check the fuses on the inverter board.Never stop learning
wonder if the mainboard is sending proper signal to tcon?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
could be bad cap on inverter maybe?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Now we do not know if the meter is good or if it is being used correctly.
The 24V should be at the fuse if he does have backlights, this is really frustrating and confusing when we do not get correct readings.Never stop learning
That what I thought in the first in post 1 but some how I thought we lost the 24V and the 12V which nay be why one of the regulator on the main board shows <0.050V).
Apparently my meter skills are lacking severly in this dept. I was checking it with the positive lead on one side and the neg on the other. I'm assuming that was incorrect as I put the negative lead on the ground wire coming in on the inverter board and the positive at the fuse and got 24v on both sides. is that correct?Last edited by at1105; 02-17-2015, 10:57 AM.Comment
Apparently my meter skills are lacking severly in this dept. I was checking it with the positive lead on one side and the neg on the other. I'm assuming that was incorrect as I put the negative lead on the ground wire coming in on the inverter board and the positive at the fuse and got 24v on both sides. is that correct?Comment
by PNI E.hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
by koby058Hi people!!
The owner said it showed bad picture once in a while (attached)
I see that there is back light but no picture.
I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
Also attached schematic and BDV
LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590... -
by nsab6464Hey guys,
I have a Vizio P502ui-B1E with no display activity at all with the power light on. It broke in a very specific way, and now exhibits strange behavior when turned on (slow response to power off command, restarts every 90 sec, more below), so I'm hoping that someone with experience working on this TV can point me in the right direction.
I already tried the 2 most common fixes with no luck:
- Replacing the T-Con board.
- Re-flashing the firmware on the U202 chip (from here: https://www.badcaps.net/forum/showthread.php?p=840012)
Here's exactly... -
by gavricHello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
When tv powers on vizio V logo shows nice on whole screen. picture 1
When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
When i start youtube picture shows on left side fine, right is all scrambled. pic 2
When i click video to start playing picture goes black(like when you change... -
by kcaHello all ~
I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
No picture. No sound.
I tested all the voltages coming out of the power supply... - Loading...
