Dynex DX-L40-10A Won't turn on.
  • Funda
    • Feb 2015
    • 68
    Hello all. I am in need of your help. I picked up a free tv from work because it was being replaced, it won't turn on, and I can't find the cause of the problem.
    I hear a click when I plug it in but the red stand by light comes on and neither the remote or the touch pad will turn the set on or change the light to blue. I don't hear any other sounds from the circuitry when trying to power it up but in the dozen or so times I've plugged/unplugged it it's made sounds from the speakers a couple of times.
    I took a few voltage readings and there does seem to be something wrong to me. On the PS board the connector going to the main board is supposed to have 12v on at least 2 of those pins. I'm reading 9.8 on both pins labeled 12v.
    I don't really see any obvious damage but on the underside of the PS board there's some oily residue in one small area, like the part on the other side got too hot and cooked that spot, but nothing looks fried per say. That spot is in the first pic under the yellow banded piece in the upper left corner.
    I'm not sure what to check next and could use some guidance.
  • CapLeaker
    Leaking Member
    • 8134
    Re: Dynex DX-L40-10A Won't turn on.
    Need better pics with pinout from the PS connector going to the main board. Basically you can unplug this connector and force the power supply on with a 1k Ohm resistor between PSon and STBY voltage (5v), BLon (back light) and 5V. That should turn on the power supply rails and the backlight should be on. Then measure voltages again.
    I think your case is a main board problem.
    • Funda
      • Feb 2015
      • 68
      I'll get better pics when I get home from work.
      • splitcrete
        • Dec 2012
        • 387
        • usa
        I had the same problem same set. Try to heat up the lower left of the main board.
          Pictures of the whole backside of the TV?
          • Funda
            • Feb 2015
            • 68
            Do you mean 2 resistors?
              Yes, two resistors.
              • Funda
                • Feb 2015
                • 68
                Does it matter which 5v I use?
                • Funda
                  • Feb 2015
                  • 68
                  Nvm it's clear to me now after reading it enough times! Lol
                  • Funda
                    • Feb 2015
                    • 68
                    Just tried doing the resistor trick and I do hear the click noise as if the boards were hooked together but there's no backlight and it doesn't come on still.
                    One thing to ask tho did I need to leave the cable plugged or unplugged. I tried it unplugged.
                    I was also using 1/2W resistors
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Unplugged from main.
                      You are tricking the PSU into thinking the mainboard is causing load on the connections thus initiating them.
                      Did you test voltages again? If so readings?
                      Also picture of the connector from PSU to main so we can see the voltage legends
                      • Funda
                        • Feb 2015
                        • 68
                        Trying to upload pics from my phone and there's bad lighting.
                        I'm not having any luck with trying to upload from the phone so I'll have to do it at work tomorrow.
                        With the resistors in I am getting 5.3v at pin STB and still pulling 9.8v at both 5V S pins. All the rest read 0. That's on the PS board.
                        • Funda
                          • Feb 2015
                          • 68
                          PS board pinout
                          GND
                          GND
                          STB
                          5V S
                          5V S
                          12V
                          12V
                          GND
                          BR1? BRL?
                          SW
                          GND
                          GND
                          5V M
                          5V M
                          Main board pinout
                          +5V
                          +5V
                          GND
                          GND
                          BL ON/OFF
                          DIMM
                          GND
                          +12V
                          +12V
                          +5VSB
                          +5VSB
                          ON/OFF
                          GND
                          GND
                          • CapLeaker
                            Leaking Member
                            • 8134
                            So you are saying that you unplugged the main board from the power supply and forced the power supply on and you are still getting 9.8v where you should get 12v?
                            • newtothis
                              • Mar 2013
                              • 1556
                              • england
                              Yes was going to ask the same, Did you mean the 12v pins rather than the 5V S?
                              • Funda
                                • Feb 2015
                                • 68
                                Yes still getting 9.8 on the pins 3,4&5 down from the top. That would be the 5v pins on the PS board. If u want readings from the main board I'll have to do that tomorrow. Already closed it up for tonight.
                                Just so I'm on the same page the PS board is the tan one that the power wire connects to correct?
                                • Funda
                                  • Feb 2015
                                  • 68
                                  Well I'm not getting 9.8 in pin 3. That's 5.3
                                  • Funda
                                    • Feb 2015
                                    • 68
                                    Sorry for all the edits and extra posts. It's been a long day and I've had a few doses of "medicine" and a couple shots so I'm remembering things late and staggered. Lol
                                    • newtothis
                                      • Mar 2013
                                      • 1556
                                      • england
                                      Pics would really help with labels of what voltage you get at each one as you previously stated :
                                      • CapLeaker
                                        Leaking Member
                                        • 8134
                                        Now I am confused. First the 9.8v are on the 12v rail, now they are on the 5v rail? Make some new pictures. Also use your PS pinout list in post 13 and fill in all the voltages.
                                        • howardc64
                                          by howardc64
                                          Yesterday, 05:17 PM
                                        • brzostos
                                          HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
                                          by brzostos
                                          Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
                                          After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
                                          Original HP 150W power supply, the diode in the power socket lights...
                                          10-01-2024, 01:34 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
