Samsung UN32EH5000FXZA, No Backlight
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Samsung UN32EH5000FXZA, No Backlight
    200v
      Could just be the over voltage threshold is set there... doesn't mean the LEDs will operate like that continuously.
      • johnboy1313
        • Nov 2012
        • 1959
        It does seem to fluctuate from 175V to around 185V and back to 175V without settling down.
        • johnboy1313
          • Nov 2012
          • 1959
          I have a couple more concerns about the LED strips. There is a connector on both ends of each strip. In my past experience with LED TVs, whenever there was a connector on both ends of the string, there was a jumper to another string. This is not the case here. The connectors at the other end are just open. Any thoughts?
          Also, can I buy standard ultra bright white LEDs and solder the leads to the pads for test purposes?
            I was going to ask you about that since I only see the cable so on one side only.
            Are the + and - markings on both end of the strips?
            The way the 4-pin connector on the power supply board are setup, the LED strips look to be connected in parallel so it needs only 2 pair of wires.
            No one worked on this TV before, right?
            • johnboy1313
              • Nov 2012
              • 1959
              Yes, there are markings on both ends. I'm away from the strips right now, but I believe they are flipped from one end to the other.
              I wondered the same thing myself. I don't see any evidence that would suggest it.
                I never seen 32" LED backlights with just two strips with LED driver out put that puts out more than 150V, usually <100V, 42" larger is >100V.
                Something does lot look right, unless there are limiting resistor on the strip that we are not seeing.
                Can you also please verify that the two strips are connected in parallel?
                • johnboy1313
                  • Nov 2012
                  • 1959
                  The two positive pins on that connector are connected as are the two negative pins.
                    So the two strips are connected in parallel, and each strip has 12 LEDs.
                    I see on the right side of your picture has two tapes attached to the chassis, what were they taping down? since there are no wires shown in the picture.
                    I can see that the tapes on the left side is for taping down the wires.
                    https://www.badcaps.net/forum/attach...5&d=1423004264
                    This is UN32EH405, as you can see, it uses 4 strips of LEDs.
                    http://s807.photobucket.com/user/bud...?sort=3&page=1
                    I thinks some one has been inside this panel before you, no way two strips can light up the panel evenly.
                    BTW, the label on my board and on your board indicate VLED of 147V, 260mA.
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      The tape was holding down the ends of the LED strips. Unlike any other panel I've ever torn into, these strips aren't stuck to the panel with double sided tape, they are attached with plastic clips stuck through holes in the panel. There are only as many clips as there are holes. The strips in my picture have been detached from the panel. I don't believe there is room for two more strips when it is assembled correctly. The white reflective sheet only has 24 holes in it for the LEDs as well. The white sheet would cover any additional strips.
                        Hmm, interesting.
                        • johnboy1313
                          • Nov 2012
                          • 1959
                          Interesting indeed.
                            It could be that each LED is a two chip module with two LEDs in series, perhaps?
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              Would I be able to tell when the LED barely glowed? I wondered that too, but I could clearly see two or three LEDs inside each module in the pictures I've seen. I've misplaced my 40X loop though, so I can't say for certain.
                              • johnboy1313
                                • Nov 2012
                                • 1959
                                Any other ideas? I suppose I could attempt to get one good string from the two and see if I can buy the other. Though the PSU output worries me.
                                • johnboy1313
                                  • Nov 2012
                                  • 1959
                                  I found the fast track guide. Thanks again for the service manuals Tom. Page three has a mistake though. The picture shows CNL802 pins 1 through 5 labeled D1+, D1+, N.C., D1-, and D1-. The legend under the picture is reversed. Pins 1 and 2 are labeled D1- and pins 4 and 5 are labeled D1+. With that said, on page 4, it looks like D1+ should measure a constant 110V. I measured again and I'm seeing a steady fluctuation from roughly 172V to roughly 185V. It also says D1- should measure 1.3V-32.8V depending on what Backlight Dim is set to. The higher Backlight Dim measures, the lower D1- should measure. Backlight Dim on my board measure about 2V, right in the middle of the range. D1- both fluctuate from a few millivolts to roughly 3V.
                                  I suspect this power board is faulty and that is what blew the LEDs.
                                  At connector CNL802, there are four wires. Pins 1 and 2 (D1+) are grey and black respectively. They run to one LED strip. Pins 4 and 5 (D1-) are also grey and black and run to the other LED strip. How can this be? Even if the PSU was working correctly, one LED strip would read 110V with respect to ground at both pins on that connector. The other would read 1.3V-32.8V with respect to ground at both pins on that connector. My gut is telling me that there is supposed to be a second harness jumping the two LED strips together.
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    Are you guys as stumped as I am?
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Looks like I'm on my own with this one. I'll report back once I get it working.
                                      • johnboy1313
                                        • Nov 2012
                                        • 1959
                                        Power supply and LED strips. I bought a set with a broken screen off ebay for 15 bucks.
                                        • CapLeaker
                                          Leaking Member
                                          • 8327
                                          so did you try the old power supply? Just for shits and giggles...
                                          • grimreaper420
                                            Samsung Odyssey G9 (c49g95tssr) no picture or backlight. Power LED shows
                                            by grimreaper420
                                            hey guys,
                                            i bought 2 samsung odyssey g9's for a decent price. they both have the exact same fault. when plugged into a power source, the blue led powerlight shows, but when turned on there is no picture, no backlight, no menu, nothing. when plugged into a laptop the laptop recognises the monitor, but keeps disconnecting and reconnecting.
                                            dont have any schematics or diagrams unfortunately. any ideas?
                                            thanks
                                            09-03-2024, 03:47 AM
                                            09-07-2024, 05:50 AM
                                          • C152Heavy
                                            by C152Heavy
                                            Summary for TL-DR readers:
                                            • VCC pin (18) of PFC...
                                            01-11-2023, 02:53 PM
                                          • sansanpartida
                                            Samsung QE82Q70RAT no backlight
                                            by sansanpartida
                                            Hi everyone!
                                            Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                            My issue: No backlight.
                                            Model: QE82Q70RAT
                                            Type No: QE82Q70RAT
                                            The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                            So hopefully, I can fix this cheaper.
                                            05-22-2024, 06:56 AM
                                          • howardc64
                                            Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                            by howardc64
                                            TV was fixed just after removing Samsung's rear snap cover.
                                            This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                            Maybe PSU->backlight connector didn't have a good contact?...
                                            07-23-2025, 12:34 AM
