Samsung UN32EH5000FXZA, No Backlight
  • johnboy1313
    • Nov 2012
    • 1959
    I picked this one up today. It powers on but has no backlight. A flashlight shows that there is a picture. I believe that I have one or more open LEDs. In standby, the main cap shows 169V across it but when powered up, it only shows 166V. I find this to be confusing. I expected to see ~390V at power up. In standby, CNL802 shows ~95V at pins 1 and 2. When powered on, I see ~180V at those pins and all marked voltages are present at CNM803 as well. With CNL802 unplugged and the meter in diode mode, I get O/L in every possible configuration on the plug. I suspect that this points to at least one open LED for what I suspect to be two LED strings.
    Looks like I need to open the panel.
    Re: Samsung UN32EH5000FXZA, No Backlight
    This TV has no PFC booster, so the cap voltage will always be ~160V. You can tell this because there is no PFC inductor, diode, MOSFET, etc.
    They can get away without PFC because LED TV uses very little power.
    • CapLeaker
      Leaking Member
      • 8193
      plus you can't test the LED string like that with a multimeter anyway. Only thing you can do with a multimeter there is to check if one of the wires is shorting out to the metal frame and each individual LED.
        The LEDS stings looks to be connected in parallel, see bottom side connection.
        Your meter is not going to put out Voltage to forward bias the LEDS to test the whole string.
        What DC Voltage do you get at the LED connector?
        You can put DCA meter in series with the wire to see if it shows any current draw.
        https://www.badcaps.net/forum/showpo...4&postcount=95
        https://www.badcaps.net/forum/showpo...&postcount=107
        • johnboy1313
          • Nov 2012
          • 1959
          That makes sense. I got into the panel fairly easily. There is evidence of multiple LEDs being blown. It looks like there is soot at each end of both LED strips but the LEDs themselves don't look burnt like I've become accustomed to seeing. How do I test each LED? Do I need to pry the cover off each one and glue it back on when I've tested it?
            I believe those LENS are snap-on.
            • CapLeaker
              Leaking Member
              • 8193
              yes, they are
              • johnboy1313
                • Nov 2012
                • 1959
                It looks like these are glued on somehow. I broke the first one off and will have to super glue it back on. At any rate, the first LED shows .741V in diode mode and O/L the other way. I guess this means it is good???
                If there are 12 LEDs on a strip and each strip is being fed ~180V, that means each LED needs 15V to light. Does that seem right?
                  .741V is very low for an LED. When tested on a meter a good LED should glow slightly, if a reading is available.
                  How do multiple LEDs fail simultaneously? Design flaw?
                    White LED should have forward Voltage around 3~4V range (typical is around 3.3V).
                    0.741V looks real low to me.
                    12 LED x 3.3 = 39.6V+ V drops for current limiter.
                    http://www.maximintegrated.com/en/ap...ex.mvp/id/3070
                    • johnboy1313
                      • Nov 2012
                      • 1959
                      It looks like I should be able to slip a sewing needle under each side of the lens to get to the LED mounting pads. This should give me something to probe without breaking each lens off. I have some known good LED strips from a different set here to see if they light when tested. They are 3.3V LEDs for certain though. Six LEDs on a strip, 20V from my bench top power supply will light the strip.
                      Back to my question above, does 15V each LED seem right?
                      • johnboy1313
                        • Nov 2012
                        • 1959
                        The PSU is putting out roughly 180V to each strip when powered on. 95V in standby.
                          "Back to my question above, does 15V each LED seem right?" I do not understand what you mean by 15V each LED.
                          Just use 3V coin cell battery with 100 Ohms in series for testing these white LEDs.
                          • johnboy1313
                            • Nov 2012
                            • 1959
                            180V from the PSU at connector CNL802 / 12 LEDs on a string = 15V each, or am I missing something?
                            • johnboy1313
                              • Nov 2012
                              • 1959
                              3V doesn't light any LEDs. 4V only makes a handful of them barely glow. It's hard to tell they're even glowing.
                                The strings are connected in series.
                                  That does not make any sense, are you limiting the power supply current o about 10mA, that should be more than enough the light up white LED quite bright.
                                  Do you have any other white LED to try?
                                  • johnboy1313
                                    • Nov 2012
                                    • 1959
                                    There's 24 LEDs total. 180V/24 LEDs is still 7.5V each. Maybe thats why the LEDs are blown.
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      I tested a good, known working LED on a different strip. I can light the strip of six LEDs with 20V at the connector. It shows .741 on my meter as well and does not light up when being tested with the meter.
                                        What is the DC rating of the LED DRIVE boosted Voltage filter cap C9110?
                                        • grimreaper420
                                          Samsung Odyssey G9 (c49g95tssr) no picture or backlight. Power LED shows
                                          by grimreaper420
                                          hey guys,
                                          i bought 2 samsung odyssey g9's for a decent price. they both have the exact same fault. when plugged into a power source, the blue led powerlight shows, but when turned on there is no picture, no backlight, no menu, nothing. when plugged into a laptop the laptop recognises the monitor, but keeps disconnecting and reconnecting.
                                          dont have any schematics or diagrams unfortunately. any ideas?
                                          thanks
                                          09-03-2024, 03:47 AM
                                          09-07-2024, 05:50 AM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                        • sansanpartida
                                          Samsung QE82Q70RAT no backlight
                                          by sansanpartida
                                          Hi everyone!
                                          Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
                                          My issue: No backlight.
                                          Model: QE82Q70RAT
                                          Type No: QE82Q70RAT
                                          The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
                                          So hopefully, I can fix this cheaper.
                                          05-22-2024, 06:56 AM
                                        • howardc64
                                          Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                          by howardc64
                                          TV was fixed just after removing Samsung's rear snap cover.
                                          This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                          Maybe PSU->backlight connector didn't have a good contact?...
                                          07-23-2025, 12:34 AM
