LG 42LK450 No sound, Horizontal lines
  • Hopsing64
    • Feb 2013
    • 15
    I have a LG 42LK450-UB with stationary horizontal lines across the screen. They are mostly green and purple with a large tan band across part of the screen. photo one. sorry forgot to rotate them. Also getting a whine/buzz on t-con board. I think its coming from the components marked 220 y2 in photo 2. The tv immediately goes to the lines. I get no menu or logo or any sort of source video. The back lights are on and if I remove one of the panel to T-con cables that side turns white. Voltages off the power supply are good, and the A-dim and p-dim are 3.1 with tv on. I'm thinking main board because of the no sound/no picture, but would like to verify that before buying a new one.
    • 12332
    • U.S.
    Re: LG 42LK450 No sound, Horizontal lines
    that tcon sounds pretty iffy, I think I would replace that first, I can't recall hearing any noise from my tcons.
    • selldoor
      Slow Learner
      • 7870
      Checked the voltage at the fuse on the tcon (both sides) also test vgl and vgh.
      I dont know what is "good" but someone will.
      • Hopsing64
        • Feb 2013
        • 15
        Voltage at fuse F1 on the t-con is 12 on both ends.
        VGL 5.2
        vgh 28.1
        VIN 12
        VCC 3.3
        I also dug up a bad t-con and a working but with bad ldvs socket t-con for this tv. Both give me the same display and same buzzing from the two components on it.
        Any other suggestions?
          • 12332
          • U.S.
          VGL 5.2
          vgh 28.1
          VIN 12
          VCC 3.3
          not sure, but makes me think maybe some signal going to the tcon is making it buzz?
            • 12332
            • U.S.
            would be nice if you had a spare mainboard to test with.
              Buzzing sound from the inductors for the switching power supply on the T-CON usually indicates too much current being drawn by the LCD panel.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Wich means that 1 or more backlight tubes are dead? Lcd is drawing to much power Budm?
                • Hopsing64
                  • Feb 2013
                  • 15
                  The back lights work. They come on when the tv is powered on.
                  • arctor
                    samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                    by arctor
                    hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                    04-26-2025, 05:22 AM
                  • howardc64
                    by howardc64
                    07-24-2025, 05:17 PM
                  • kca
                    by kca
                    Hello all ~
                    08-31-2025, 06:38 AM
                  • Ihandyrepair
                    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                    by Ihandyrepair
                    Hi guys
                    I just started fixing 4k TV few months ago. so I am still learning a lot
                    I got this tv from friend complaint is ghosting or horizontal lines on image.
                    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                    then it started to show the ghosting white image.
                    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                    it has 3 thin small boards at the bottom of the...
                    12-05-2022, 04:18 PM
                  • ChaosLegionnaire
                    by ChaosLegionnaire
                    09-13-2022, 09:02 AM
