Samsung LE37R87BD - Sound but no picture.
  • donst
    • Nov 2013
    • 56
    Re: Samsung LE37R87BD - Sound but no picture.
    Originally posted by budm
    May be the flux is covering up the pins, try applying the solder to the legs and check again, but it sounds like you have found the problem.
    You can remove that suspect transformer and test it again.
    Soldered the legs again but still it gives me nothing. Unfortunately removing the transformer did not solve the problem either.
    What should i look to do now? Replace inverter board/transformer? Is it possible to purchase just the transformer from somewhere? I've already bought a main board when i jumped the gun a bit so i'm hesitant on spending too much more.
    All help appreciated, thank you.
    • vinceroger69
      • Mar 2012
      • 6714
      I think budm meant when you removed the faulty tranformer to check the readings on it whilst removed from the board (this is what i always do too)
        You need to retest the transformer off the board, if it still shows open connection then you will need to replace it. The inverter board will not function if not all good transformers are installed, the protection circuit will kick in, same if it has one bad lamp or open lamp connection, it will shutdown.
        • selldoor
          Slow Learner
          • 7870
          I already gave you links of possible places to buy a board or a single transformer
          just check as your transformers appear to have different numbers 6025B or 6026B If you intend to keep the set for a while a whole board may be the better option then you have spares. If one transformer has given up others may follow.
            • 12087
            • U.S.
            for sure, you've come this far, are you gonna let 25 or 30 bucks keep you from possible success?
            • donst
              • Nov 2013
              • 56
              #26
              So after discovering the transformer was indeed faulty after re-measuring after detachment from the board i purchased a new inverter board but the problem persists.
              • donst
                • Nov 2013
                • 56
                #27
                Thanks for the links mate, opted for the whole board for the reason you suggested above. Although, unfortunately it didn't solve the problem.
                Anymore suggestions guys?
                • donst
                  • Nov 2013
                  • 56
                  #28
                  Anyone?
                    • 12087
                    • U.S.
                    #29
                    well maybe try a tcon, hopefully you didnt buy a faulty inverter.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      #30
                      Have you tested the transformers windings like you did on the old board? Is the new board a exact match (numbers on stickers etc).
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • jchang
                        Samsung UN70NU6900F no picture and no sound
                        by jchang
                        Hi all
                        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                        Symptom:
                        No picture no sound.
                        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                        No sound at all.
                        What I tried:
                        1. I tried unplugging the left or right ribbon...
                        01-09-2023, 06:28 PM
                      • Dodgethis
                        Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                        by Dodgethis
                        Hello all,
                        This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                        09-11-2024, 07:39 AM
