Samsung TV keeps restarting by itself
  • centos
    • Jan 2015
    • 9
    • US
    I have a Samsung UN40D5005BF LED TV. When a power cable is connected, the TV blinks red light and starting sound comes out ( I did not push power button ). Then it repeats this by itself. The red light goes out and comes back with blinking and the starting sounds come out again.
    I have checked the capacitors and they look all very clean and flat. I checked the rectifier and it converts AC to DC well. I'm not sure whether this is a main board issue or power supply issue. Is there a place that I need to check more ?
    Re: Samsung TV keeps restarting by itself
    Please upload the pictures of the whole back side of the TV so we can see how all the boards are connected together.
    • centos
      • Jan 2015
      • 9
      • US
      I'm uploading more pictures. Thanks for looking at this problem.
      • MagicSmoke
        • Feb 2011
        • 275
        Unplug the connector to the button board and see if it stops the cycle. The buttons can fail or get sticky.
        Edit .. the red led wont light though because it's on that board.
        • saddle_au
          Waste Warrior
          • 121
          Cheap part: http://www.findmytvpart.com/product/...g-ln32d403e4d/
          • tw2005
            • Oct 2011
            • 6458
            Is the panel fully lit or does it look like a 1/4 of the screen unlit? If it has a 4 channel backlight anything like the 55D6000 then if a LED burns out, that channel goes open and the TV just endless reboots, briefly lighting the screen with the SMART logo .
            not saying 100% that is the issue but worth lookig at also.
            • centos
              • Jan 2015
              • 9
              • US
              Disconnected power switch but it still tries to start. There is no red light but I could hear starting sound. I don't know what makes this start. If I'm sure that this is a main board issue, I will buy the cheap part. That's pretty good price.
              The panel is completely dark. No light at all.
              Thanks for all suggestions !
              • centos
                • Jan 2015
                • 9
                • US
                I guess I have the same issue that this guy has. It was a main board issue.
                https://www.youtube.com/watch?v=hG2FHHXKsSU
                Probably I should buy the one that saddle_au recommended. I will try it out. Thanks !
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Main board issue = usually the main BGA processor needs reflow or reballing. But a proper reballing would cost upwards of $60 so in this case replacing the mainboard is the cheaper option.
                  A working TV? How boring!
                    • 12097
                    • U.S.
                    maybe check the fuse on the tcon board, labeled F1, I believe it was. http://www.shopjimmy.com/samsung-bn9...-con-board.htm
                    • centos
                      • Jan 2015
                      • 9
                      • US
                      I disconnected the tcon board and TV still automatically keeps starting over and over again. I can tell because a starting sound comes out but there is off sound so I assume that it crashes and restarts. Hope this is a main board issue. I already ordered the part so we will see in a week.
                      • centos
                        • Jan 2015
                        • 9
                        • US
                        omg, can I cook the main board in oven ? If my new main board comes, I will try this out with old one.
                        http://zedic.com/lg-42dl550-fix-repair/
                        • centos
                          • Jan 2015
                          • 9
                          • US
                          I replaced the main board but no luck. Probably the power board has an issue...
                          • mmartell
                            • Oct 2013
                            • 3189
                            This test can't be definitive without knowing the nature of this power supply but it looks similar to other basic Samsungs in which this test would apply. Disconnect the cable between the main board and the power supply and then plug it in. Does the backlight come on ?
                            • Nick's Tvs
                              • Jan 2014
                              • 621
                              Super late but I just got this exact same model and can confirm the backlight will turn on no problem if you have a bad main. That's what happened on mine. Unfortunately it seems like I also have either a bad panel or t-con in addition to the bad main because I just replaced my main and now I get the tv to turn on stay on with backlight but no picture.
                              I do get voltages going from the t-con to the panel and the panel boards has certain ceramic caps showing 3.27v and 15v and other such voltages but all the ic's on the tabs stay cold. Normally they heat up a good amount so I just don't know what is going on.
                              • royanon
                                • Aug 2016
                                • Hong Kong
                                Hello, I have the same problem. I've change the PSU, Mainboard, no help. And I unplug everything, and plug them back again, it work for a hour or something, I can watch TV without any problem. But soon, it turns off and can never boot up again. It just show the logo screen and then a click sound again and again.
                                Is that the panel problem?
                                  09-07-2024, 05:50 AM
                                  09-06-2024, 11:40 PM
                                  09-06-2024, 08:40 PM
                                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                  09-06-2024, 06:20 PM
