RCA 47LA55RS Red Light OK, Not power ON
    Re: RCA 47LA55RS Red Light OK, Not power ON
    OK, so if all the cables are connected, you do not get backlights to flash on at all, but if you disconnect the small cable from inverter to the T-CON, the backlights then flash on for seconds?
    • alfredomfr1
      • Oct 2014
      • 318
      • usa
      Capacitors replaced on Master and Slave inverter boards, now if I leave only the slave disconnected (4 pins T-Con cable connected) can see image on the screen for 1 sec.
      With the slave connected the relay just remain clicking and nothing on the screen.
      Slave inverter board defective?
        Yes, it does sound like you have slave inverrter board probem.
        How are the MOSFETs and the fuse on the slave inverter board? Did you check them?
        • CapLeaker
          Leaking Member
          • 8325
          Sounds like a short on the slave inverter board, or the fuse is open.
          • alfredomfr1
            • Oct 2014
            • 318
            • usa
            Fuse ok, MOSFETs not in short.
            • alfredomfr1
              • Oct 2014
              • 318
              • usa
              #26
              I replaced the slave inverter board but still same problem
              • CapLeaker
                Leaking Member
                • 8325
                what happens if you unplug both inverter boards and turn on the TV? You get sound and a pic, if you shine a flashlight at the screen?
                • alfredomfr1
                  • Oct 2014
                  • 318
                  • usa
                  #28
                  When both inverter board are unplugged the tv don't turn on, just stby red light, but if I make a bridge between the stby (5v) and power-on signal, the tv turn on and I can see image with a flashlight
                    • 12274
                    • U.S.
                    #29
                    maybe recheck your solder joints on your new inverter caps, had similar problem after replace inverter caps, touched m up and it worked, but my soldering is pretty bad.
                    • alfredomfr1
                      • Oct 2014
                      • 318
                      • usa
                      #30
                      The solder joints are ok, maybe the new inverter board are defective too, how can I test this inverter board?
                      • CapLeaker
                        Leaking Member
                        • 8325
                        There are some things you can test on the inverter boards, other things sometimes read good, but they are actually not (like the transformers for instance). To properly check the transformers, you need a ring tester. Other than that, if a CCFL is bad, it would do the same thing flicking on for a second, then off...
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • ipatch
                          troubleshooting microsoft surface pro 4 no power no led charge light
                          by ipatch
                          hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                          10-05-2023, 11:59 AM
                        • russpall
                          LG 39ln540v - red light flashes twice, no power to LED driver?
                          by russpall
                          Hi there,
                          I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                          The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                          08-27-2024, 01:07 PM
                          by sam_sam_sam
                          03-31-2024, 02:12 PM
