RCA 47LA55RS Red Light OK, Not power ON
    5v and 12v ok, no power on, when plug the power cable the relay sound one time first and one-two, one-two after that a weir sound but nothing happen.
    Power Board Model: HLP-45D01
    Re: RCA 47LA55RS Red Light OK, Not power ON
    There are nothing related to troubleshot this tv power board on the web, any help?
      I made a bridge between power-On and stby(5v) and the TV turn on when power button is pressed, the red light led become blue but still no backlight on screen.
      Voltage Read:
      24v: 25v
      12v: 11.69v
      14v: 16.79v
      5v: 5.26v
      Any suggestion?
        Did you have a look at the inverter board?
          This TV has 2 inverter boards, how can I test these 2 boards?
            Aaah! It has a Master and a Slave backlight setup. Does the backlight come on for 2 secs and off or no backlight coming on at all? You can check if the main board is actually giving the turn on signal to the backlight. I can't see the pinouts on the power supply. Basically there are some wires going from the power supply to the inverter board. Turn the TV on, and check the BLON pin on the power supply. You also should check fuses on the inverter board. Maybe some pics of the inverter boards would be nice.
              In the backlight connector (Pic 3) which is the BLON pin?
                I would try and replace those 2 caps also
                I fixed a samsung lcd with no backlight with replacing those caps!
                  Master
                  24V: 25v
                  BRI1: 1.66v
                  SW1: 4.97v
                  BRI2: 0v
                  SW2: 0v
                    I have not 680uf 35v capacitors, I need to order.
                      Do you have other capacitors?
                      For example 4x 330uf?
                        560uf 25v, nothing close to 35v
                          And the measurements on the Slave? Looks like the Master is getting juice from the power supply. Does the backlight attempt to turn on for a second or nothing at all?
                            Slave
                            24v: 25v
                            BRI1: 4.97
                            SW1: 1.66
                            backlight did not attempt to turn on.
                              https://www.badcaps.net/forum/attach...1&d=1422285528
                              What DCV do you have on CN1? Especially the pin 12_ON/OFF.
                              Please post all the readings of the CN1 connector.
                                CN1
                                24V: 25.05v
                                VBR-A: 1.66v
                                on/off: 4.97v
                                VBR-B: 0v
                                Status: 0v
                                  OK, the control signals and the 24VDC are OK.
                                  I see that there is small white ribbon cable with 4 pins, does it go to the T-CON board? If it does go to the T-CON board, remove it and see what happen.
                                    ribbon cable removed, backlight come on for a second and turn off
                                      How can I test the inverter board in order to determine the defective one?
                                        Any help?
