Viewsonic N3252W Power Issues
  • thrallking
    • Apr 2013
    My N3252W has decided it finally wanted to start giving me problems. A few days ago it blew a few capacitors (six to be exact) in the power supply and stopped turning on. I went ahead and replaced the caps and it started working again. Well, it worked for two days at least.
    Not long ago the screen flickered and then went black, but unlike last time there are no popped caps. Whenever I hit the power button the light turns green, then off, then back to red ready to do the cycle over again. I should also note that the red standby LED flickers a little (it doesn't turn off, just dims occasionally).
    So, does anybody have an ideas as to what this latest issue is?
  • mmartell
    • Oct 2013
    • 3189
    Re: Viewsonic N3252W Power Issues
    Replace ALL caps in the secondary - those that haven't failed are probably in the process of doing so. Then it might not hurt to replace the smaller ones in the primary while your at.
    • nomoresonys
      • 12331
      • U.S.
      yep, they don't have to bulge to be bad.
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        You should be using good quality caps from a known good seller - radioshack ones are generally not up to it.
        Usually recommend panasonic FR FM & FC in that order (not all sizes are available in all series.
        • thrallking
          • Apr 2013
          So just to clarify, you think my problem may still be capacitor related? Assuming the problem continues after replacing all of the caps on the power supply, are there any other components on that board that could be the culprit with these symptoms?
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • PantherDave
            by PantherDave
            Hi all!
            05-29-2024, 02:01 PM
          • GLISIT
            by GLISIT
            01-16-2025, 02:29 PM
          • zlr8r
            Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
            by zlr8r
            hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
            Ill try and give as much info as I can.
            Dell Inspiron 17 (7786) Laptop
            Service Tag: 5J0NHT2
            Bios: 1.9.0
            When I received this , it would only flicker on the KB backlight for a second, then off and on.
            Then it started getting weirder!
            Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
            12-12-2023, 09:31 PM
          • sli4
            Original NES power issues
            by sli4
            I recently turned on my old NES to find the red light won't go on at all. When powered on it shows black bars on the tv and a loud buzz through the tv speakers. Powering it off, the buzz goes away and tv goes back to normal (white snow).
            I tested the power supply itself and it is outputting 9V as it should - first two solder joints on the board at the power port show the same.
            Here's where it starts getting funky - When powered on, one side of the 7805 voltage regulator is showing 18V and the other is about 8.7V (center 0).
            On the big blue connector I get...
            11-28-2024, 12:52 PM
