I'm looking at a Vizio E41I-A2 where the V logo is stuck on the screen. Any ideas? Thanks for any help with this.
Vizio - E41I-A2 Vizio Logo Stuck on Screen
Re: Vizio - E41I-A2 Vizio Logo Stuck on Screen
Can we see the whole back side of the TV so we can see all the boards? There are more than 2 boards in that TV.Never stop learning
I would start by testing the power supply voltages at the plugs/cables going out to the other boards, do you have a digital multimeter? be careful when working with power supply, HIGH VOLTAGE, on primary side, can be deadly.Last edited by nomoresonys; 01-16-2015, 09:32 AM.Comment
From my expereance with these newer vizio/JVC LED panels is mainboard failure. Doesn't look like this model has an EEPROM that can be swapped out.
I had a 2012 Vizio Made JVC that I got that did the same thing yours is doing the JVC logo would pop up and then the panel would shut down completely.
After a few hours of troubleshooting and the TV coming on perfectly fine with the back off, I found that one of the speaker wires had been smashed in-between the back shell and the wall mount braces, this came like this from the factory (great QA eh!) so I cut the damaged part of the wires soldered the 2 wires back together did a little shrink tubing and turned the panel on and is still working perfectly.
I would check all your connections and possible look for any kinked or smashed wiring inside the panel.Comment
https://www.badcaps.net/forum/attach...3&d=1421367394
Try disconnecting the left connector to see if the power light stays on white.
if not, then try disconnecting the LVDS cable (flat white cable) between the main board and the LCD panel and see what happen.
https://www.badcaps.net/forum/attach...4&d=1421363838
Flashing power indicator sounds like main board problem.Never stop learning
see the connector on the left side of power supply?, turn the tv on and check them in dc voltage, see the writing next to it, legend, labeled 1 thru 14, you should get those voltages or very close to it, with everything hooked up, again be careful what you touch on power supply, if you have any voltages that dont match the legend, report it, number and voltage.Comment
by StuntHi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
screen that's it and stuck there. I left it until the following day and i still...09-02-2025, 01:51 PM -
by spice_discI'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...1 Photo -
by paulxxxxThe TV stuck at logo and cannot be turned off unless the cord is unplugged.
I was given two main boards and exactly the the same thing happens to both of them.
I have checked all voltages on the connector on the power board that goes into the main board and they all look OK.
There are no signs of damage on any of the 3 boards.
Would someone help me with a pointer to the manual? It's supposedly to be the same as E601i-A3.
Thanks! -
by abajorHaving this very weird issue.
The owner of this laptop complained about screen being intermittent when opening and closing, and has been using the laptop on a thunderbolt video connection since the screen failed.
I swapped with a working screen from an A2141 waiting for parts.
The Os exhibits this weird behavior where it boots to to 1/3 the status bar, then it makes the boop sound. It's at the log in but for whatever reason the desktop isn't loaded.
The laptop boots fine into recovery mode. I updated from Monterey to Sonoma and the laptop still has... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM - Loading...
