Just picked this one up, preliminary problems is dead on arrival, nothing when I try to power up. Anyone have experience with these that can provide some tips? Thanks
Panasonic Viera TC-L42D2 help
Re: Panasonic Viera TC-L42D2 help
Fuses?
Pictures of boards?
Please update your profile with country and mains voltage.Please upload pictures using attachment function when ask for help on the repair
by mostachioHi Badcaps,
I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
TV Details:
Model # - TH-65DX700Z
Symptoms:
The television turns on and displays a picture then makes a clicking sound and turns off.
I haven't opened it up yet but... -
by Ama ChurAfter watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
by BigPeteI picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
Unfortunately the whole machine has to come apart to fix it.
I have... -
by badcappoHello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
Diode type G972s6 - D101 with a short
Mosfet 06N90E - Q301 shorted
Fuse T5AH 250V - F103 blown
Diode D301 shorted
Relay DG1U-17VDC II - RL001 blown
I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀... -
by J8rda7Hi,
the TV has a black screen. Sound OK, backlight OK.
When I measure T-CON voltages, there is VGL+VGH=0V. After unplug the right side of the screen from the T-con, voltages are OK and half screen works normally.
I tried to search for any kind of short on the right side, but I had no luck. I have a beginner experience in measuring and repairs of the LCD panels..
Thanks to anyone who can guide me in solving the problem.. and be patient with my english 🙂😁 - Loading...
