Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
  • Ama Chur
    • Feb 2025
    After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon cables removed. Is it possible to do the scotch tape fix on the ribbon cable?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4405
    • Italy - Milan
    Bad start: No tv model, no pictures of boards.. i think screen is by LG so you can't exclude half ribbon connection, it can be bad tcon..
    • Ama Chur
      • Feb 2025
      The TV model is TCL47e5. It didnt have any stickers on the back so the panel is what I had to go off of at the time. Had to dig deep for the model really. Im aware it CAN be a bad T-con, is the only way to check that to find a T-con from 2012 and see if it works? Are T-con boards proprietary to the model of TV?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4405
        • Italy - Milan
        Maybe TX-L47E5, it needs its own tcon model, every one are different..
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • cagri
          BOE HV650QUB-F70 TCON issue - VGH AVDD HAVDD no voltage - caps seem ok
          by cagri
          I have an Arcelik TV with BOE HV650QUB-F70 TCON board, but I think there's an issue with/around PMIC.
          PMIC: iML8940
          There is backlight and sound, but no picture. I watched a YouTube video and turned it off, half an hour later it was dead.
          Input 12v, fuse ok
          DVDD1V2 = 1.2v
          DVDD1V8 = 1.8v
          DVDD3V3 = 3.3v
          VGL = -7v
          **VGH = -0.3v
          **VCOM0, AVDD, HAVDD = 0v
          SWBK1 = 3.3v
          SW1 = 12v
          VGH to GND resistance is 500kohm as expected
          Readings are same after I disconnected the two cables from TCON to panel...
          07-27-2023, 09:48 PM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • JSBJSB
          Panasonic OLED TX-65GZ950E no image
          by JSBJSB
          so I have this problem with this OLED that had a LED blinking issue at first.
          It was blinking twice so it means according to similar service manuals (I cannot find the proper one) EVDD 24V SOS, Panel or TCON Fault.
          Also, the connector from PSU to TCON which supplies 24V was burned (changed it) and saw threads about this topic but didn't relate completely to mine.
          First thing was to tape the signal ERRORDETECTION so it would try to initialize. And it didn't so I unplugged the panel from TCON.
          Then it started up and went to green light...
          05-14-2025, 02:39 PM
        • Ancient1
          I'm stuck . Panasonic TH-L32U20M panel's boards issue
          by Ancient1
          Hi
          The TV seem to start ( blinking green) but goes into blinking red. No display and or backlight. Full view photo.
          Actions :
          1. Disconnected Panel's Right, 2nd, board : TV comes ON (steady green , no blinking red )
          1a. You can see in two photos the B/W screen , fading blue "HDMI12" , and the wierd sides of the image, like an old CRT.
          Obviously the fault is from or on the Right, secondary board
          2. I taped the Flex tracks, ~2 tracks at a time- see Photo. The issue seems to be on the V lines (Assuming Data...
          09-03-2023, 03:51 AM
