Panasonic Viera TX-L50E6E - no image
  • J8rda7
    • May 2024
    • 7
    • Czech Republic
    the TV has a black screen. Sound OK, backlight OK.
    When I measure T-CON voltages, there is VGL+VGH=0V. After unplug the right side of the screen from the T-con, voltages are OK and half screen works normally.
    I tried to search for any kind of short on the right side, but I had no luck. I have a beginner experience in measuring and repairs of the LCD panels..
    Thanks to anyone who can guide me in solving the problem.. and be patient with my english 🙂😁
  • J8rda7
    • May 2024
    • 7
    • Czech Republic
    Nobody give me a hint? 🙁
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4543
      • Italy - Milan
      check other threads, forum is full of similar situations, the problems are almost 4 possible.. not much to read.. bye
      • J8rda7
        • May 2024
        • 7
        • Czech Republic
        Hi, I made some progress..
        After making some experiments, with blocking some pins between the left side, betweenT-CON and panel using "tape method", I finally got an image. And now it is still working even the tape is removed and no pin is blocked.. BUT... the right side of the screen is slow, dark etc. as you can see in the photos. And it is "working" only for a short period of time after the tv is turned on, then it becomes distorted, choppy... As it is on the photos..
        I think, that the problem is a short somewhere in the panel. But I didnt find anything. I have only basic knowledge about repairing the panels.
        Any ideas what to do next? Thanks guys​
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • Chrissygizmo
          Panasonic TX-48CX350B backlights but white screen , blank screen
          by Chrissygizmo
          Hi all, I’ve got a problem I hope someone can help me fixi.
          I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
          01-11-2025, 03:18 PM
