LG 32LN530B picture upside down
  • bjorkson
    • Apr 2012
    • 127
    Hi I have a LG 32LN530B with a bad main board that keeps resetting. I replaced the main board, everything works. But now the picture is upside down. Have anyone encounter this problem? Or know how to reset or adjust it?
  • nomoresonys
    • 12331
    • U.S.
    Re: LG 32LN530B picture upside down
    could try a firmware update, if ones available.
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Are you sure the replacement mainboard had EXACTLY the same board numbers and revision as the old one - including the number on the bar code label
      • AFajitas
        • Dec 2014
        • 183
        Just buy one of those universal stands and mount it upside down; problem fixed.
        Sounds like something that could be changable in the service menu, maybe your main board has an incorrect panel setting from a different region or something.
        Pulled the following from http://www.askvg.com/secret-service-...ony-and-lg-tv/
        Press and hold <OK> buttons on remote as well as TV panel for a few seconds and the service menu will appear on your TV screen.
        For some TV models, you might need to press "Menu" buttons on remote and TV panel simultaneously for a few seconds to access the service menu. In a few TV models, both methods work and they open different service menus.
        If the service menu asks for a password, enter 0000 (four zero). If 0000 doesn't work for you, try 7777 or 0413 or 8741 or 8743 or 8878.
        Now you can make changes to your desired settings.
        To save the changes press <OK> button on the remote.
        BONUS TIPS:
        1. With the help of this secret service menu in LG TV, you can enable USB drive use by settings USB option to 1. Once you enable this feature, you can insert any USB drive in USB slot present at the backside of your LG TV and your TV will automatically detect it and you'll be able to play audio or video files present in your USB drive on your TV set. You can also view images present in your USB drive on your TV set.
        2. You can also enable Golden Eye feature by settings Eye option to 1 in service menu. This feature automatically adjusts contrast and brightness levels of your TV set according to the lights available in your room.
        3. All LG TV come with a secret feature called "Hotel Mode". You can enable this feature by settings Hotel option to 1 using service menu. Once you enable this feature, the Setup or Channel Search option will get disabled in your TV Settings. Thus no other person will be able to scan channels or fine tune channels. That's why this option is called Hotel Mode.
        • bjorkson
          • Apr 2012
          • 127
          Yes, the board is correct. Let me try a fireware update and see if that fixs the problem. I was looking and there is a post for a LG service bullentin for this exact problem, but I can't find the resolution.
          • AFajitas
            • Dec 2014
            • 183
            I'm 99% sure it's a setting in the service menu, specifically Mirror Mode: 1
            • bjorkson
              • Apr 2012
              • 127
              OK, let me see if I can access my service menu and try that tonight when I get home, will let you know. Thanks!!
              • bjorkson
                • Apr 2012
                • 127
                Last night I try to do a fireware update with no success, also try 3 different method of accessing the service menu and it would not let me open it up. Seen like the main board is locked up, will not let me access anything. Anyone encounter this issue? I can usually access menu from other brand tv fine, seen like this one is very stubborn!
                • iwagner
                  • Jan 2015
                  • 5
                  I have the same TV, different issues but I stumbled across this in another forum, maybe it will help
                  "found a bulletin on the problem, just Press ADJUST key on service remote scroll down to Tool option 5 and select Mirror Mode to 1. After Mirror Mode is changed and saved. Power Down TV turn back on and picture right way round "
                  • AFajitas
                    • Dec 2014
                    • 183
                    Im able to get into the service menu on my LG by holding the "menu" button on the remote and TV at the same time for 3-5 seconds.
                    • bjorkson
                      • Apr 2012
                      • 127
                      IWagner, I don't have the "ADJUST" key on my remote control.
                      • bjorkson
                        • Apr 2012
                        • 127
                        I also read somewhere that it will not let you access the service menu depending on the TV software version if it's higher or lower.
                        • nuala
                          • Aug 2013
                          • 37
                          ON THE SM REMOTE, HIT THE "IN START", THEN ENTER CODE 0000, THEN YOU CAN NAVIGATE THE SERVICE MODE LOOKING FOR WORDS LIKE VERT FLIP OR THE LIKE....DON'T THINK 0000 WORKS ANYMORE. THE NEW CODE IS 0413.
                          this is a factory remote. You could try the remote that came with the set.
                          • bjorkson
                            • Apr 2012
                            • 127
                            My TV is not a Smart TV, just a regular 32in LED TV, will try again tonight when I get home with all your suggestion and see what I can come up with. Will report back. Thx
                            • nomoresonys
                              • 12331
                              • U.S.
                              you could be right, might be a problem with the main board, since you can't access the menus.
                              • truep
                                • Aug 2010
                                • 373
                                Do you have a service remote? On most LC tv's you have to use a service menu to access/use the service menu. You can get one on Ebay.
                                • selldoor
                                  Slow Learner
                                  • Dec 2010
                                  • 7870
                                  Perhaps tackle from another angle:
                                  https://www.badcaps.net/forum/showth...7&highlight=LG from post8
                                  may be of interest
                                  • bjorkson
                                    • Apr 2012
                                    • 127
                                    OK, I figure out the mystery. LG came out with two different panel in the same year that uses the same main board, but programmed them differently. Panel S/N is LC320DXE and HC320DXN. My TV panel is the LC320DXE, the main board I received was for the HC320DXN model. I have since returned it and got the main board programmed for my panel and everything is working like a charmed. Thanks for everyone's input.
                                    • selldoor
                                      Slow Learner
                                      • Dec 2010
                                      • 7870
                                      Pleased to hear you got it fixed just so that others do not make the same mistake were the boards numbered the same?
                                      [QUOTE=selldoor;519243]Are you sure the replacement mainboard had EXACTLY the same board numbers and revision as the old one - including the number on the bar code label[/QUOTE
                                      • bjorkson
                                        • Apr 2012
                                        • 127
                                        Yes, the main board number is the same, but the revision is different, if you go to ShopJimmy and put the model tv number on there, they have a couple of main board with the same S/N, noted with the panel S/N info for that particular board.
                                        • garrymc123
                                          Luxor TV board input board change but picture upside down
                                          by garrymc123
                                          Looking for some advice changed over the video input board due to bad hdmi ports but now the picture is upside down tried the service menu but can't find anything to do with flip the picture..
                                          Is there anything I can do to flip the picture or do I need to change the board again..
                                          Garry...
                                          08-29-2022, 04:53 AM
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • kleito
                                          LC-52D85UN Software / Picture upside down
                                          by kleito
                                          Howdie
                                          I just replaced a TCon board on this TV, and now my Picture is upsidedown.
                                          I do not have a remote.Is there maybe another way to change this, like a software update?( which i can never find, probably due to the age of the unit)
                                          I cannot find a "flip"setting in the regular set up of the TV either
                                          Any help is appreciated.
                                          TIA
                                          12-01-2022, 04:39 PM
