LG 32LN530B picture upside down
  • nomoresonys
    • 12331
    • U.S.
    Re: LG 32LN530B picture upside down
    on the jvc, strip it down to the frame, not sure if its the best way, but I laid it face down on a quilt, unscrewed all the screws from the back, make sure theyr all out, then had a helper and me hold the tv at all four corners because now back is loose, flip it over on its back with screen facing up, take off the metal fame held by screws, then you have access to tab bonds, figure out which one/s it is, slight pressure to make them tighter, I used a half piece of I believe it was 1/4 inch clear plastic flexible tubing, anything that wont lose dry up will prob. do, you put it between your loose bond and the frame, took me several tries to get it just right, its been a while, but if you have any problems, post it here, with maybe a pic. or two, let us know how it goes.
    • nomoresonys
      • 12331
      • U.S.
      Budm has some good posts on tab bond fixing, check m out.
      • paulstef
        • Dec 2013
        • 724
        I had a similar problem with a wrong firmware (or parameters). In my case (https://www.badcaps.net/forum/showpo...10&postcount=5) I swapped a memory chip between old and new board and it worked.
        On the board from the OP here I see 3x SOIC or SOP-8 packages, could be memory too.
        • garrymc123
          Luxor TV board input board change but picture upside down
          by garrymc123
          Looking for some advice changed over the video input board due to bad hdmi ports but now the picture is upside down tried the service menu but can't find anything to do with flip the picture..
          Is there anything I can do to flip the picture or do I need to change the board again..
          Garry...
          08-29-2022, 04:53 AM
        • Tr0ll
          by Tr0ll
          Original T-con:
          First replacement T-con:
          10-07-2023, 07:48 PM
        • JJAAMM
          by JJAAMM
          Problem
          07-06-2023, 06:01 AM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • kleito
          LC-52D85UN Software / Picture upside down
          by kleito
          Howdie
          I just replaced a TCon board on this TV, and now my Picture is upsidedown.
          I do not have a remote.Is there maybe another way to change this, like a software update?( which i can never find, probably due to the age of the unit)
          I cannot find a "flip"setting in the regular set up of the TV either
          Any help is appreciated.
          TIA
          12-01-2022, 04:39 PM
