Interesting home-built TAB bonding machine
  • lookimback
    • Aug 2013
    • 1489
    Re: Interesting home-built TAB bonding machine
    This tells you several ways of doing it.
    ------------signature starts here------------
      Boy, it is not as simple as shown in video from Romania.
      • lookimback
        • Aug 2013
        • 1489
        Definitely not. But it is absolutely doable.
        • Shinju
          • Mar 2014
          • 1239
          It's a sweet project and cool machine, but let's be realistic for a second. Is it really worth the time to fix these tabs on screen like Sony and Samsung? These panels in a reseller market sell for pennies on the dollar anyway.
          I am all for fixing but time is money and this looks like it would cost a customer quite a bit in labor alone.
          Don't get me wrong it's bad ass and cool and support it 100% but sometimes you just gotta toss in the towel on these LCD/LED tab bond issues. And who knows how long the repAir will last let alone the other tabs that might fail next.
          • lookimback
            • Aug 2013
            • 1489
            I think it's worth it if you are buying the TVs to fix and resell as I do. I've gotten over 2 dozen TVs above 40" in the past year with TAB failure. At even just $150 each, that would have been $3600.
            • Shinju
              • Mar 2014
              • 1239
              I fix and resell as well, but I look at it like time vs return i also work full time and kids ect.
              I think it's great and cool, but again for me it's all about time and risk of what happens if another tab fails then I have to spend more time on the same panel.
              To each is their own!
              • lookimback
                • Aug 2013
                • 1489
                Yeah, I see your point. If you're just doing this on the side then maybe not. This is all I do now though. Sometimes I barely get by, but it pays the bills. Something like this would help me a lot. Especially considering that a lot of newer TVs don't even have enough parts value to make them worth taking a risk on. And it looks like fun too.
                • AFajitas
                  • Dec 2014
                  • 183
                  This is the response I got:
                  Hi
                  I use welder and weld head made in usa,if you need help you must be pay and I help you with any detail and procedure you need.cost 500$
                  Floristeanu Daniel
                  • zomi
                    • Nov 2011
                    • 510
                    #29
                    Same here
                    And to add
                    4000-6000$ welder+weld head SH-New
                    • zomi
                      • Nov 2011
                      • 510
                      #30
                      I think
                      If a machine can be soruced 2nd user at a reaosnable rate
                      then the rest is really trial and error
                      From the specs as initial values and then experimentation with the machine.
                      Similar to the bga rework machines...
                      its worth it if you have a good source of higher end panels..
                      that have failed.
                      Then its is serious money and a viable business ...
                      Or repairs for the end user..
                      But finding a machine at the sweet spot is the key
                      I don't think this person in the video is going to tell us anything that can't be figured from some experimentation..
                      I thought before feedback the person had developed a cheap method of making a diy machine..
                      • SteveNielsen
                        Retired Tech
                        • Jun 2012
                        • 2327
                        Originally posted by zomi
                        i thought before feedback the person had developed a cheap method of making a diy machine..
                        Same here.
                        • lookimback
                          • Aug 2013
                          • 1489
                          We honestly don't even know it was the same panel. I didn't see anything in that video which would make me want to give him $500 for information. In all honesty, I think I could make a machine which could do this for under $1500, if I had access to a machine shop. That would include making my own custom heating elements for the head. You also need a cooling method, because you can't remove the pressure until it's cooled beyond a certain threshold. It's really not that difficult though. You need an alignment method, a USB microscope to inspect alignment, and a press mechanism with an attached head which can be heated and cooled to precise temperatures. That's not really that complicated.
                          • lookimback
                            • Aug 2013
                            • 1489
                            I was incorrect about the shelf life of the tape. It's 24 months if stored at 70°F and 50% humidity. Also, bonding temps are specific to the particular tape used, so that info is available in data sheets for the tape.
                            • lookimback
                              • Aug 2013
                              • 1489
                              I wonder if it would be possible to make something to do this in a handheld version? Maybe something that would clamp onto the panel for stabilization. And a thumb control to move the TAB into position, small LCD screen and USB microscope to assist in alignment, and a trigger to actuate it.
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                #35
                                ^^ That's actually what i'm thinking as well.
                                A working TV? How boring!
                                • AFajitas
                                  • Dec 2014
                                  • 183
                                  Even if it is less reliable than a tab bonding machine, it could still be viable. A lot of these panels are trash anyway without the proper fix.
                                  • lookimback
                                    • Aug 2013
                                    • 1489
                                    Exactly. It's like, there's really nothing to lose but a little time.
                                    • AFajitas
                                      • Dec 2014
                                      • 183
                                      I wonder if you could heat up a piece of copper or aluminum and stamp it with that. Both metals cool down pretty quickly. I noticed he had some sort of cloth between the heating element and the panel in the video. Was I seeing that right?
                                      • AFajitas
                                        • Dec 2014
                                        • 183
                                        Check this out. Where a guy tried to fix a tab bond and failed. http://forum.bongofish.co.uk/index.php?topic=2257.0
                                        • lookimback
                                          • Aug 2013
                                          • 1489
                                          What's important is to have even heat distribution and pressure. In a handheld device, I think an ordinary hakko soldering iron element could work. But only if you don't use more copper than you need. The entire head shouldn't be copper, because it will take too much to heat it. I'd use a ¼ square piece of copper, attached to some other material which doesn't conduct heat well. And there are ways of rapid cooling. A burst of co² or air maybe.
                                            I just bought a SkyRc MC3000 battery testing machine very interesting device temp
                                            I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
                                            The charger has four individual temperature sensors for each battery cell
                                            The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
                                            Or test...
                                            09-14-2022, 07:12 PM
                                            ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                                            This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-12-2024, 03:28 PM
                                          • CG2
                                            Janome DC3050 Sewing Machine Pedal Resistance
                                            by CG2
                                            OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                                            Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                                            04-14-2023, 07:53 AM
                                          • Soulzink
                                            Samsug washing machine. Power supply DC41-00189a board issue
                                            by Soulzink
                                            I am trying to fix a samsung washinmachine power supply main board.
                                            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                                            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                                            The power supply board reference is the following: DC41-00189a
                                            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                                            04-19-2025, 06:26 AM
                                          • unimatrix93
                                            How to stabilize AC voltage to CNC machine
                                            by unimatrix93
                                            Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                                            I have a CNC machine wired to 3-phase 230V AC.
                                            It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                                            The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                                            I contacted the electricity company but they refuse to help me solve this problem.
                                            So I started to look around for some DIY...
                                            03-17-2025, 05:52 AM
