Interesting home-built TAB bonding machine
  • johnboy1313
    • Nov 2012
    • 1959
    Re: Interesting home-built TAB bonding machine
    http://youtu.be/OCiTKtRBtlk
    Here's an American version very similar process.
    • diif
      • Feb 2014
      • 6978
      • England
      #42
      A bit more info here on the different types of tape and the temperatures required.
      http://www.a-i-t.com/hot-bar-solderi...t/3m-acf-guide
      • lookimback
        • Aug 2013
        • 1489
        So you actually need a different type of tape for the flex to glass and the flex to board connections.
        ------------signature starts here------------
        • diif
          • Feb 2014
          • 6978
          • England
          #44
          It does look that way. There is this video of someone using 9703 to repair an ipod touch, but there is no afterwards video so there is no way of knowing if it worked.
          https://www.youtube.com/watch?v=abidHYSlQqs
          • lookimback
            • Aug 2013
            • 1489
            It probably works, but may not last as long as using the correct type.
            • tibimakai
              • Jan 2012
              • 3680
              Here is a company in Fremont CA:
              http://www.bigbytecorp.com/lcd--plasma-repair.html
              Here are others:
              http://www.lcdrepairalliance.com/
              • lookimback
                • Aug 2013
                • 1489
                They're a lot cheaper than I thought.
                • zomi
                  • Nov 2011
                  • 510
                  #48
                  Ipod touch repair does work
                  But bear in mind it is slightly different in that there is no heat involved.
                  it doesn't get hot
                  where as in the panels quite abit of heat is generated so its a different scenario ?
                    I just bought a SkyRc MC3000 battery testing machine very interesting device temp
                    I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
                    The charger has four individual temperature sensors for each battery cell
                    The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
                    Or test...
                    09-14-2022, 07:12 PM
                    ALIENWARE Steam Machine R2 i7-6700T Specification for Upgrade or Repair
                    This specification for the ALIENWARE Steam Machine R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Steam Machine R2 boardview and Steam Machine R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-12-2024, 03:28 PM
                  • CG2
                    Janome DC3050 Sewing Machine Pedal Resistance
                    by CG2
                    OK, this is a long shot. I got this sewing machine cheap because it's end of line, ex-display, and had no pedal. The genuine pedal costs £60, while Ebay knock-offs go for around £15. So I went for the knock-off, it doesn't work, and I'm not sure whether it's the pedal or the sewing machine that has the problem.
                    Now this is an electronic machine, unlike the old fashioned sort where the pedal was a big resistor in series with the power to the motor. Here, the pedal is just (I think) a variable resistor fed with a 5 volt supply, and limited to a current of 5 milliamps. Assuming that...
                    04-14-2023, 07:53 AM
                  • Soulzink
                    Samsug washing machine. Power supply DC41-00189a board issue
                    by Soulzink
                    I am trying to fix a samsung washinmachine power supply main board.
                    I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                    Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                    The power supply board reference is the following: DC41-00189a
                    I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                    04-19-2025, 06:26 AM
                  • unimatrix93
                    How to stabilize AC voltage to CNC machine
                    by unimatrix93
                    Hello there everybody, I'm not sure if it's the right topic to ask this but I hope so.
                    I have a CNC machine wired to 3-phase 230V AC.
                    It's a smaller CNC machine with a 3500W motor, do it does not uses much power.
                    The problem is, when the residents come home and put load on the network, the voltage can drop to around 207V which is fine for most household items but by CNC machine stops working from this.
                    I contacted the electricity company but they refuse to help me solve this problem.
                    So I started to look around for some DIY...
                    03-17-2025, 05:52 AM
