Polaroid fxx-321c - No Signal
  • caphair
    • Nov 2011
    • 1249
    Trash picked 32" lcd Polaroid. Turns on fine, menu pops up etc as it should.
    Problem is it doesn't detect any input whatsoever. I'm guessing mainboard issue but what specific component would cause this?
  • MagicSmoke
    • Feb 2011
    • 275
    Re: Polaroid fxx-321c - No Signal
    Post some pics of the setup. The TLX-03201b I found in the trash has a separate input connection strip that plugs into the mainboard. If yours is like that try reseating it first.
    More than likely the tuner circuit has failed, I had a vizio lose DTV channels, had to replace the tuner board. It was a separate board on mine, not part of mainboard.
    • CapLeaker
      Leaking Member
      • 8226
      Check for power to the tuner.
      • caphair
        • Nov 2011
        • 1249
        Here are some pics, I don't really know what I'm looking for here or where to trace power to the tuner?
        Let me know if you need any specific angle or anything that might help
        • caphair
          • Nov 2011
          • 1249
          I noticed three bulged caps on the power supply and one of the big filter caps on mains side. Was only able to replace the three caps on secondary and still no signal.
          Possible mains filter cap could be causing this issue or still a mainboard/tuner problem?
            So you can see user setup menu on the screen but it does not show any Video from DVD, cable box, or PC?
            • caphair
              • Nov 2011
              • 1249
              Correct just keeps saying no signal. Cable box coaxial input shows static. Only the one hdmi input seems to work
                You do have main board problem, I wonder if this TV was hit by surge or lighting.
                • caphair
                  • Nov 2011
                  • 1249
                  There's a connector at the top left of mainboard labeled 12v 12v and on both I measure 18v. Should I try replacing that bulged mains filter cap? There's two, I imagine it's a pfc set up
                    Are the main caps rated at 450VDC?
                    The pictures are too dark for me to see the details on the power supply board, if it has PFC, then the DC Voltage should be >360VDC.
                    But since you indicated that it works fine on one of the HDMI, then I doubt that it will be the power supply board.
                    • caphair
                      • Nov 2011
                      • 1249
                      Yes both rated 100uf at 450v
                      If it's not the power supply, any way to figure out where the issue lies? I can post better pics of something if needed to help in diagnosing.
                      Why would there be 18v at the two 12v lines I mentioned?
                        12V output is not tightly regulated power supply because it is for running the Audio amplifier that does not need tightly regulated power to run.
                        I am not sure how much we can do on the main board without the diagram, you may want to do real details visual inspection of the main board both sides to see if it has any sign of damages. My be check the Voltage regulator ICs, ect.
                        • CapLeaker
                          Leaking Member
                          • 8226
                          you should be able to open the metal can of the tuner. Have a look inside. Maybe you see something. Check that the tuner is actually getting proper power. No power, or not correct power, no tuning. my post #3. Looks like there is a regulator U23 (what is it?) in front of the tuner. May be also that the pins don't make good connection in the RF terminal.
                          • AstutePauciloquent
                            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
                            by AstutePauciloquent
                            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
                            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
                            11-23-2023, 11:02 PM
                          • howardc64
                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                            by howardc64
                            Failure Symptom
                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                            Where is the short?
                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                            05-27-2025, 02:56 PM
                          • JayPoorJay
                            Converting +/- 5v to a Usable Hz Signal
                            by JayPoorJay
                            Good morning.
                            I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
                            This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
                            The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
                            08-07-2022, 08:35 AM
                          • Xristakis795
                            samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
                            by Xristakis795
                            hi to all
                            i have the above model ue40d5003
                            the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
                            when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
                            when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
                            Can you tell me from your experience...
                            02-09-2023, 03:17 PM
                          • Mirenia
                            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
                            by Mirenia
                            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
                            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
                            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
                            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
                            03-30-2025, 06:47 AM
