samsung ue40d503problem reboot logo only when i have input signal from hdmi and tuner
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    hi to all
    i have the above model ue40d5003
    the damage was definitely caused in my case by a generator that I installed burned the protection at power supply of tv and created the following problem
    when I have not connected the antenna, any input source lights up normally i can insert on the menu and the tv doesnt reboot
    when I connect,the antenna or hdmi signal however, when it goes to show an image, the image appears momentarily and then restarts appears the logo and the same again.the lights of standby blinking continously
    Can you tell me from your experience what could be wrong or where should I look?
  • Xristakis795
    • Mar 2021
    • 162
    • Greece
    Re: samsung ue40d503problem reboot logo only when i have input signal from hdmi and t
    maby if i do a firmware update solve my problem in your opinion ?
      09-07-2024, 05:50 AM
    • Ellos
      Samsung s21 sim recognized but no signal
      by Ellos
      I'm just starting out with smartphone repairs and picked up a Samsung S21 to work on. Everything functions perfectly except there's absolutely no cellular signal. The SIM card is recognized, WiFi works fine, but zero network signal.
      I've tested my SIM in another phone and it works perfectly with good signal, so it's definitely the phone.
      From what I've read online, this issue is usually caused by the network chip needing to be desoldered and reballed since one of the solder balls might be cracked.
      I think I've located the SOC that...
      06-27-2025, 01:31 AM
      09-06-2024, 11:40 PM
      09-06-2024, 08:40 PM
