T-Con FS_HBC2LV2.4 vs 400WHC8LV1.3
  • paulstef
    • Dec 2013
    • 724
    Have this 400WHC8LV1.3 T-con board and I'm pretty sure it's bad.
    Have also a working FS_HBC2LV2.4 and was wondering if they are interchangeable. Same connectors, same pitch, same distance between connectors but the board format is completely different.
    Too risky trying?
    They both seem to be from/for Samsung. Even though one came from a 40" Visionquest and the other from a 32" Sony (I think)
    Re: T-Con FS_HBC2LV2.4 vs 400WHC8LV1.3
    "Too risky trying?" Yes. You need to look up the spec sheet of both LCD panels to get the pin out of the boards, the Voltage and current requirement, etc.
    • paulstef
      • Dec 2013
      • 724
      Ok, thank you Budm.
      • paulstef
        • Dec 2013
        • 724
        Well I can confirm, they are NOT compatible. Since the TV isn't worth buying a new T-Con I tried it out anyway. The TV turns on but backlight remains off. Without the T-Con backlight works...
        So much for THIS test. :-D
        • kca
          by kca
          Hello all ~
          08-31-2025, 06:38 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • netgearnetgear
          TCL 43S423 TCON OR PANEL FAULTY???
          by netgearnetgear
          Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
          08-20-2025, 06:04 PM
