T-Con FS_HBC2LV2.4 vs 400WHC8LV1.3
  • paulstef
    • Dec 2013
    • 724
    Have this 400WHC8LV1.3 T-con board and I'm pretty sure it's bad.
    Have also a working FS_HBC2LV2.4 and was wondering if they are interchangeable. Same connectors, same pitch, same distance between connectors but the board format is completely different.
    Too risky trying?
    They both seem to be from/for Samsung. Even though one came from a 40" Visionquest and the other from a 32" Sony (I think)
    Re: T-Con FS_HBC2LV2.4 vs 400WHC8LV1.3
    "Too risky trying?" Yes. You need to look up the spec sheet of both LCD panels to get the pin out of the boards, the Voltage and current requirement, etc.
    • paulstef
      • Dec 2013
      • 724
      Ok, thank you Budm.
      • paulstef
        • Dec 2013
        • 724
        Well I can confirm, they are NOT compatible. Since the TV isn't worth buying a new T-Con I tried it out anyway. The TV turns on but backlight remains off. Without the T-Con backlight works...
        So much for THIS test. :-D
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • advant
          by advant
          02-03-2020, 12:25 AM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
        • Daren87
          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help NeededπŸ™
          by Daren87
          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
          08-13-2023, 03:25 PM
        • alltvrepairs
          Lg TCon test pins for screen test
          by alltvrepairs
          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
          Appreciate your help....
          06-13-2025, 06:33 AM
