Funai lc320em1f
  • newtothis2
    • Jul 2014
    • 36
    • usa
    Funai lc320em1f
    Hello I have a Funai lc320em1f power comes on then right to stand by.
    I be leave these boards are used by a few deferent sets.
  • KevinCro
    • May 2014
    • 104
    Re: Funai lc320em1f
    You will need to post more information. Have you looked at the boards for any bad caps or fuses? It sounds like the power supply is sensing a fault and shutting the system down. Can you take a picture of the back of the tv without the cover so that we can see the board layout?
    • Ltank
      • Jun 2013
      • 776
      Re: Funai lc320em1f
      Check power Mosfet for short.
        Re: Funai lc320em1f
        See if this service manual is close to what you have:
        http://elektrotanya.com/?q=showresul...oria=&kat2=all
        It is one of those bad designed two-transistor switcher power supply.
        Boards are pretty cheap:
        http://www.shopjimmy.com/catalogsear...t/?q=lc320em1f
        • newtothis2
          • Jul 2014
          • 36
          • usa
          Re: Funai lc320em1f
          I checked for bad caps didn't see any.
          The power board is
          Ba94f0f0102 6_a
          I don't know what a mosfit is.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Re: Funai lc320em1f
            Sounds like the mainboard can't detect a signal, to me. I dunno.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • newtothis2
              • Jul 2014
              • 36
              • usa
              Re: Funai lc320em1f
              If I can just replace one of the boards for cheap.
              Just send me a link, please. Witch board is the problem?.
              • MagicSmoke
                • Feb 2011
                • 275
                Re: Funai lc320em1f
                It looks to me like PSU and input board is combined and the digital main is a separate board as is the inverter board. So at least 3 different boards that could be bad.
                Without pics and some basic info about what voltages you have on the PSU, It will be difficult to narrow down which one is faulty.
                There are some video's on utube to help understand basic tests on PSU and the inverter board.
                Warning!!!! There can be over 200v on the PSU and 400v or more on inverter when operating. I would advise to be very careful if/when testing.
                Edit..budm has a few links in his signature that give good instructions on what to test.
                  Re: Funai lc320em1f
                  Please look at your boards to see which one that matches the one on shopjimmy link I post in post #4 so I can see which exact boards you have in your TV.
                  • newtothis2
                    • Jul 2014
                    • 36
                    • usa
                    Re: Funai lc320em1f
                    I didn't see my board.
                    A01ftmpw a
                    On the sticker.
                      • 12184
                      • U.S.
                      Re: Funai lc320em1f
                      ok, one second please, let me get out my crystal ball.
                        Re: Funai lc320em1f
                        How about pictures of YOUR boards including the sticker pictures?
                        • newtothis2
                          • Jul 2014
                          • 36
                          • usa
                          Re: Funai lc320em1f
                          I've been trying to. Not going well.
                          Iphone5s
                          Will get er done.
                          • newtothis2
                            • Jul 2014
                            • 36
                            • usa
                            Re: Funai lc320em1f
                            This is the closest I've found.
                            http://www.shopjimmy.com/emerson-syl...1-main-cba.htm
                            But it day's this.
                            LC320EM1 SN beginning with DS1 or DS5 LC320EM1F SN beginning with DS1 or DS2 or LC320SL1 SN beginning with DS2. Sticker number may vary.
                            And mine starts with. Rs1
                            • newtothis2
                              • Jul 2014
                              • 36
                              • usa
                              Re: Funai lc320em1f
                              Will the above board work?.
                              • kevinjo
                                • Aug 2014
                                • 49
                                Re: Funai lc320em1f
                                Funai boards are...FUN? Sorry, bad joke. I have found that most of them as was posted before are mosfets ( black things with 3 legs ). Put your mutimeter on diode and check all the way around for short or open. Also Funais have solder issues. Resolder all the big diodes. Those are the 2 biggest issues and once in a while you will find a bad zener but hope that doesn't happen as they are harder to find. I also had a few mains go on them but not as much as the other things mentioned. Good luck.
                                • newtothis2
                                  • Jul 2014
                                  • 36
                                  • usa
                                  Re: Funai lc320em1f
                                  I can't get pictures uploaded.
                                  Here are the specs.
                                  Funia lc320em1f
                                  Sn-rs1a1028100261
                                  Power board-a01ftmpw a
                                  Other board-a01ftmiv
                                  I just need a link to the power board
                                  I can't seem to find it thanks.
                                  • MagicSmoke
                                    • Feb 2011
                                    • 275
                                    Re: Funai lc320em1f
                                    Your PSU and mainboard should have a P/N like this..BA94F0F0102 6_A
                                    or something like it. That is the # to search for.
                                    I found at least 2 on ebay. Here is one... http://www.ebay.com/itm/Emerson-LC32...-/261440550311
                                    These are a pain to fix. I have one here that I have replaced zeners, resistors, diodes and mosfet and it still doesn't output any stable voltages.
                                    When uploading pics you have to wait for it to complete, it is not instant. It takes at least 30-50 seconds for each of my pics to upload.
                                    • Shane711
                                      • 493
                                      Re: Funai lc320em1f
                                      I have another TV where someone else worked on it and left me a mess. So the Emerson LC320EM1f had missing parts. I can't find what diode goes in location D609. Looking at the schematic it seems it has no value anyway I can't find a value for it. Board number BA94F0F0102 6_A. I even have another board and I removed the diode from it but there is nothing printed on it. I need help please?
                                        Re: Funai lc320em1f
                                        Where is the schematic?
                                        • DXseekerMO
                                          Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                          by DXseekerMO
                                          Hello everyone!
                                          Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                          Symptoms:
                                          1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                          2) TV does not appear to turn on
                                          3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                          4) "Power on" terminal on Power Supply has 3.26v
                                          5) "A13V" terminals have 12.9v
                                          6) Stand-by test jumper on Power Supply has 12.9V
                                          7) Optical audio jack on Main Board illuminates
                                          8) With stand-by...
                                          06-09-2021, 12:19 AM
                                        • FriedFred
                                          Schenker VIA 15 PRO, PF 4NU1F V1.0, P/N: MBPPF4NU18-F310 - 36mA in stand-by
                                          by FriedFred
                                          Hello, everyone!
                                          I have here a Schenker VIA 15 PRO, with this numbers on the board: PF 4NU1F V1.0 and P/N: MBPPF4NU18-F310 .
                                          I took out the memory and the battery and the SSD.
                                          So, in stand-by, only the board, takes 36mA. No power-button pressed at all, I can measure 1.8V, 3.3V, 5V. All coils present voltages except the two power rails for the CPU. The CPU is a AMD Ryzen 5 4600H.
                                          After pressing the power-button, the current raises to 500mA and the two power rails for the CPU show up with 0.8V.
                                          After several seconds, the fans switch-off and the board keeps powered...
                                          03-08-2025, 04:45 AM
                                        • Titus6
                                          LG OLE65C1 Stand-By issue
                                          by Titus6
                                          I bought an OLED65C1 refurbished TV back in 2022 from a shop. The TV is awesome, this is my first OLED and I really love it.
                                          However I have an issue with the TV since the end of last year. I noticed when my TV is in Stand-By, sometimes the LED goes off then comes back on. When do so it seem periodical. It only goes away for 1-2 seconds, than comes back on. The TV NEVER turnes off, while it's on, so it's not overheating issue or electrical power issue.
                                          I bought a service remote (MKJ39170828) and checked the menu 3. Power On/Off Status. I took...
                                          01-31-2025, 04:01 PM
                                        • DXseekerMO
                                          Vizio E400i-B2 missing stand-by voltage
                                          by DXseekerMO
                                          I picked up this Vizio E400i-B2 with no stand-by light and diagnosed it with missing stand-by voltage. I found a Power Supply at ShopJimmy, installed it but it didn't work properly. SJ refunded the transaction and did not ask me to send the board back.
                                          So I took some voltage readings upon the original board. Here's what I found:
                                          Main caps have 169.9v
                                          AC detect voltage is 1.3v
                                          None of the MOSFETS appear to be short.
                                          The opto (IC106) that appears to have something to do with stand-by voltage has 3.0 volts on terminal 1...
                                          10-30-2021, 10:19 PM
                                        • howardc64
                                          by howardc64
                                          Problem
                                          08-04-2024, 10:36 PM
