Samsung UN46EH6000 LED ERROR Codes
+ More Options
Latest Activity
    replied
    Re: Samsung UN46EH6000 LED ERROR Codes
    One shorted mlcc cap can make the ones next to it read short too, maybe take the first one in the row that reads short out and check it out of circuit, recheck the others see if they still read short, lots of times it's only one bad cap, video example there, I've seen others too, this is the one I found in English: https://www.youtube.com/watch?v=jLd6QO7Z7m4
  • 111joser111
    replied
    I know this is old post, but still, if any one finds it like i did, i found the issue (not the solution yet).
    I have a UE48H6200 with the same issue, sound no image no backlight, Cause? Short in the rigth panel board (i dont know the name, the one between the tcon and the panel).
    If i connect one flat cable from the tcon to the panel at a time i get backilight but no image, when i connect both, no backlight at all.
    Measuring the componentes i found on the right board some ceramic capacitors shorted, gnd to 2 lines in each buffer line.
    Dont know if its one buffer shorted or a cap going short.
    Probably will try to inject 1V to both sides of one of the caps and see if anything heats up, but im inclined to be a buffer line gone bad...
    So sad, great tv, what a waste. Ill post if i find out any solution other then new panel.
    Cheers.
  • Agent24
    replied
    Originally posted by budm
    it is also good for light table.
    That's a clever idea...
    replied
    I used 46" SAMSUNG LED backlights with broken screen as the light source in my garage, it is also good for light table.
  • Michale32086
    replied
    Yea, lesson learned.. I thought I was careful with them, but I had a houseful of grandkids... So it's likely I wasn't concentrating enough..
    Ah well, like I said. Lesson learned..
    Hopefully, it's like leaving the boat plug out of your boat when you put it in the water..
    It's a mistake that only happens once...
    replied
    Oh dear, that sucks. LCD panels are very delicate, so you must be careful to avoid damaging the tab bonds.
  • Michale32086
    replied
    Well, unfortunately a sad ending.I got in the new LED strip.. I tore down the TV again and installed the strip.. When I went to put on the actual picture glass, I had torn one of the cellophane connectors completely off the glass..
    I didn't handle that very well and ended up sweeping a million glass shards off the floor..
    So, this one was a bust.. But, at least I have a working set of LEDs... At least I think they are working.. The TV might have been slammed down on the counter a few times.. things are a bit fuzzy...
    Anyways, thanx for the assists.. At least I learned alot..
  • Michale32086
    replied
    Originally posted by johnboy1313
    The reason the left strings don't work when tested is because the connector on the end that accepts the right string of LEDs acts as an open circuit. You need to short the pins in that connector or test both strings together with 42V.
    Thanx, JB. That's good to know...
    That simply re-enforces my hope that, once the replacement comes in, I should be able to get this puppy up and running..
    Thanx again..
  • johnboy1313
    replied
    Originally posted by Michale32086
    OK, found a wall wart that did not blow anything up... It's rated at 12v, but the meter says it was putting out 16v..
    Referring to the attached pic..
    I touched the 16v to the points indicated by the boxes...
    On the Green points, all the LEDs to the RIGHT of the box lit up fine.. The LEDs to the LEFT of the box did not light up...
    Except for the one red box on the right. No LEDs lit up at all...
    Touching the 16v on all the boxes on the left.. No LEDs lit up...
    Apparently, the one strip on the right side is bad.. Just to confirm, I pulled that entire strip off and tested them individually. Still no joy..
    But I find it hard to believe that all the strips on the left are bad..
    replied
    It's worth noting there is no difference between "LED" TVs and LCD TVs, they both have LCD panels, but one has LED backlights and other has CCFL backlights.
    Picture wise, virtually no difference (maybe slightly brighter), energy saving is better.
  • Michale32086
    replied
    I seem to remember from the LCD laptop display that there were like a half dozen different mylar sheets. That's what frustrated me so much about that...
    In this latest project, there was the glass display, a single mylar sheet and a think white plastic diffuser and that was it..
    Well, I'll tackle an LCD next and see
    Thanx again...
    replied
    It's roughly the same.
    The only real difference is there are fluro bulbs in the panel instead - these are quite thin and can potentially be damaged if you are careless.
  • Michale32086
    replied
    One thing that this project (and the Westinghouse project before) taught me was that breaking a TV down to it's bare components wasn't nearly the horror I thought it was going to be..
    But then it hit me today..
    These were LED TVs. My only experience before was with LCD laptop displays and those were a nightmare..
    How does breakdown of an LCD compare to the breakdown of an LED??
    Anyone have any firsthand experience??
  • Shinju
    replied
    Originally posted by tom66
    CCFL and EEFL bulbs contain a SMALL amount of mercury. About 0.02g per TV. Eating three tuna sandwiches releases more mercury into the environment than a 32" TV contained.
    Actually LED TVs are better environmentally because they require less coal power to operate... more than any mercury saved from the bulbs!
    I am convinced far more damage is done to the environment by dumping ~15kg of electronics, metal and plastic, than a few milligrams of mercury ever would, or even considering the extra power used by the display.
    True, but here in the states things we do never really make sense, rest of the world thinks we are crazy!
    You are right about the power consumption LED/CCFL.
    Give me a plasma any day of the week! If I am going to drive a car its going to be a flashy gas guzzling machine of beauty
    replied
  • CapLeaker
    replied
    sweet! Good going!
  • Shinju
    replied
    ^ one would think, I believe the huge push for manufactors to go LED is environment preservation CCFL and EEFL are pretty toxic.
    Wonder if those LED shields are causing them to die premature due to best capture?
    replied
    Great news, how are the other LEDs, any of them showing brown tint for the heat?
    It is so sad that the LED is supposed to be an improvement from CCFL which required high voltage to operate, but they cut down on the LED design by not using proper heat management, so many of these TV with LED backlights are failing a lot.
  • Michale32086
    replied
    DING!!! DING!!!! DING!!!!
    I think I found the problem.
    A big black burn in the middle of one of the LEDs on the right side half-strip that didn't function..
    So, we now why THAT one doesn't work..
    Like I said above, I am going to operate under the assumption that the left side strips are good, I am just missing something on powering them up...
    Replacing one half-strip is going to run me about $25.. Worth it if I only have to replace one..
    Not so much if I have to replace 7...
    Anyways, thanx again... I'll follow up when the replacement comes in..
    EDIT: Is there a trick to snapping these LED covers back into place??
  • Michale32086
    replied
    Unfortunately, my little redneck battery tester thingy is not very reliable... I am going to dig around my shop tomorrow and see if I can find a 3V wall wart to use..
    Until then I am going to operate under the assumption that I, at the very least, have to replace the one right side half-strip...
    Thanx for all the help and replies.. Even if this doesn't pan out to fixing the TV, I learned a helluva lot..
    And THAT'S a win, no matter how ya slice it...
  • AK_777
    Sony KD-65A1 Repair – 4 Red Blinks Error
    by AK_777
    Hi everyone!
    I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
    Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
    02-20-2025, 04:15 PM
  • Sus256
    HISENSE 65E7KQ PRO - no boot
    by Sus256
    Hi all!
    HISENSE 65E7KQ PRO
    RSAG7.820.13512 - chassis
    MT9618BAATAB - cpu
    RSAG7.820.12059 - power
    HD650Y3U77 - panel
    KLM8G1GETF - emmc
    The TV does not turn on, the standby indicator is on. All voltages are present.
    Emms is dead. Not readable, not detected.
    Replaced emmc.
    But with another dump there is no launch
    Terminal log
    UART
    AC_ON
    RPMB key is not yet programmed
    HASH1_VERSION=0x00000000 64bit
    E-B
    FDE enabled
    layout pattern onebin by SAR7,0...
    06-01-2025, 02:11 AM
  • brithepi2k
    Samsung UE75TU7020k No picture, Standby blinks 2 times
    by brithepi2k
    My Samsung UE75TU7020k lights up fine when one of the ribbon cables are disconnected from the main board, lights stay on but not getting half a picture, I do the same with the other ribbon and put the other one in and lights stay on but not getting half a picture. The standby light flashes 2 times then reboots then it then tries to come back on again and just keeps looping until I take either one of the ribbon tables out (doesn’t matter which one I take out it stays lit when either one is out). I’ve tested the backlights but all working with none shorting out, I’ve replaced the main board...
    04-23-2025, 10:05 AM
  • Caimano
    hp Pavilion 14 CE-1XXX 5 fast 3 slow blinks or cmos checksum error if restarted immediately after shutdown or suspend
    by Caimano
    MB G7AD-2G DAG7ADMB8D0 REV D
    Processor i5 8265U
    AFAIK schematics or boardview are not available for this MB, but I used a similar board as a reference (G7AL-2G)
    Laptop came in not booting with caps lock blinking 3 fast- 2 slow indicating RAM error. Charging works fine. Found bad soldering on the only ram socket present (2 outer left pins and 2 outer right pins).
    Once soldered the laptop started fine and I was able to install Windows 11, upgrade BIOS to version F30 from Windows without a problem, BUT I found a strange and annoying...
    02-06-2024, 10:14 AM
  • Grunder
    Samsung UA55NU7100 2 blinks then reboots
    by Grunder
    Hi please some assistance with my Samsung UA55NU7100 that is stuck in reboot.
    I've read the post by Itelite on a Samsung UA65NU6900 with the same problem but this main board is different and doesn't have the 25v VGH voltage which was the problem that he had.
    There is no legend indicating voltages on the socket/ cable going to the main board just a link marked 11.80 volts. This voltage reads 12.71v. Pins 3 to 9 also 12.71v. Pins 2,6,8,10,11 & 12 all 0.0v. Pin 1 fluctuates 3.01 to 0.0 volts and pin 4 fluctuates 3.25 to 0.0 volts.
    The cpu gets very hot after 10...
    01-26-2024, 07:43 AM
